Old 07-30-2020, 04:07 AM   #1
Ryan GT86
Ryan GT86's Avatar
Drives: 2019 Toyota 86
What's the easiest way to bed new XP10s and new rotors?
I'm getting new blank rotors (Stoptech/Centric for front/rear) all around along with new XP10 front pads (my current set of XP10 rears have plenty of life in them). What's the easiest way to bed them?
I was thinking of just doing multiple brake runs from 70 to 30 and one 80 to 20 brake run like I did for my XP10s onto the OEM rotors but I'm wondering if there's easier or better methods since I'll be on fresh rotors.
I know Carbotech's instructions are to use your first session on track to bed them in but I don't want to do that with other cars on the track that could be behind me.
Ryan GT86 is offline   Reply With Quote
Old 08-04-2020, 08:23 AM   #2
biggie
Drives: gt86
Carbotech instructions states that you need to heat them until some slight fade is noticeable, but in a 2 step approach.
I do several 70 to about 10 mph moderate intensity brake runs to put some heat in the pads and then several high intensity (threshold braking, so no ABS) with same speeds until brakes are fading. Park the car for at least 1h (no handbrake).
It's not easy but it's the right way (as per Carbotech).
biggie is offline   Reply With Quote
Old 08-04-2020, 10:31 AM   #3
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
That is mostly right. You need to drive for about 10-15 minutes without touching the brake if you can, to cool them down before parking. Otherwise you will stick a bunch of pad material to the rotor.
Personally my favorite way to bed XP10's is to throw them away and buy a real pad.
Old 08-04-2020, 02:14 PM   #4
norcalpb
norcalpb's Avatar
When I bed my brakes I like to do 4-8 (depending on pads) 50-20mph braking to get the brakes warmed up. Then I make a u turn without coming to a stop and do 4-8 60-10mph hard stops. When I start to see sparks I’ll do an intense brake 1 or 2 more times.
Like mentioned, make sure you end your hard braking going in a direction you won’t have to use your brakes at all. The worst thing you can do is ride the brakes or come to a full stop with the brakes pressed.
I am in the Bay Area too and I do it next to Redwood Canyon golf course. I drive past the course to the bridge, make a u turn and warm up the brakes. I then make a U turn at the golf course entrance and start my hard braking. Then I am facing the winding part of redwood road and I can cruise for 20 minutes without touching my brakes.
Sorry if this is TMI to your original question lol.
Old 08-04-2020, 07:31 PM   #5
Ryan GT86
Ryan GT86's Avatar
Thanks for the info guys. I'll bed them on some roads in an industrial section near me to avoid traffic.
Old 08-05-2020, 03:15 PM   #6
CounterSpace Garage
CounterSpace Garage's Avatar
Drives: Subaru BRZ / Toyota 86 Experts
You can bed them on the track. They run hot so it's easy to bring them up to temp in the first session while holding 70-80% pace without engaging ABS.
CounterSpace Garage is offline   Reply With Quote
Easiest oil cooler Qwimby1 Engine, Exhaust, Transmission 14 10-22-2018 09:45 PM
Carbotech XP10s & Centric rotors CrispyCheddar Brakes, Suspension, Chassis 4 07-12-2016 05:15 AM
Which SC kit is easiest to install? tzbang Forced Induction 51 11-10-2015 12:25 PM
Easiest oil change tzhu07 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 51 04-18-2014 10:27 AM
easiest color to keep looking clean? fatoni Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 25 10-10-2013 07:21 PM
