| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
Drives: 2013 scion frs
I am trying to figure out what the width of these wheels are
The wheel is a 17 inch xxr wheel I need to know the width
#2 |
If you take one off, most will have the dimensions cast on the inside rim.
Go to most any tire store and they will have a caliper to tell the width. |
| The Following User Says Thank You to ls1ac For This Useful Post: | DarkPira7e (07-31-2020) |
#3 |
[insert cool phrase here]
Drives: BRZ Premium
Do you have a long block of wood? Do you have a tape measure?
Take the wheel off. Lay it down on the ground. With the block of wood put it flush on the rim. Then measure from the bottom to the bottom part of the wood black where it touches the rim. That should give you an estimate on how wide the rim is. Or tell us or post up the tire size.
Weekend fun/track car - '91 MR2 Turbo Gen3 Old daily driver - '88 MR2 Supercharged |
#4 |
Drives: 2014 FR-S Monogram
Remember wheel widths are measured from bead to bead. A 17x8 might measure close to 9 inches total overall width, for example. Best to check for a stamping or label on the inside of the wheel.
#5 |
The Dictater
Drives: '13 Red Scion FRS
Hmmm. Two first post members in the first page, the second an advertisement... Totally doesn't smell like low tide...
| The Following User Says Thank You to Spuds For This Useful Post: | venturaII (08-10-2020) |
| Rocket bunny v3 width | Body kit or wheels first? | nik25 | Cosmetic Modification (Interior/Exterior/Lighting) | 22 | 11-03-2019 03:02 AM |
| Closest to OEM Wheels width and offset | impossible | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 27 | 08-23-2014 02:24 PM |
| WTB (SoCal) 17" (width and offset can vary) wheels | jonbonazza | Wheels and Tires | 0 | 02-28-2014 08:43 PM |
| Correct tire width for each wheel width | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 08-16-2012 02:03 PM |
| Tire Width vs Wheel Width | Synack | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 40 | 08-12-2012 11:21 PM |
