Old 07-24-2012, 10:50 AM   #29
Apex Chase
El Presidente
Apex Chase's Avatar
Drives: it like I stole it!
Originally Posted by SUB-FT86 View Post
I would say the auto in this car can handle another 40 lb ft of torque which is all I would care for. In the IS250 the auto handles 184 lb ft which is 33 lb ft more than what the FRS engine produces. I think 40lb ft and a slightly more aggressive final drive(4.5) would make a difference enough for me.
Easily. They are not going to put a transmission in a car that is just barely adequate for the power output. Slap a trans cooler on it and forget about it. I am right there with you on the final drive upgrade.
Apex Chase is offline   Reply With Quote
Old 07-24-2012, 11:07 AM   #30
TouchMyHonda
Vtec Jesus
TouchMyHonda's Avatar
Is the transmission different between the IS 250 and 350?
TouchMyHonda is offline   Reply With Quote
Old 07-24-2012, 01:08 PM   #31
SUB-FT86
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
You mean the auto's? Or the manual's? I think its different but I'll do some research.
SUB-FT86 is offline   Reply With Quote
Old 07-24-2012, 01:09 PM   #32
TouchMyHonda
Vtec Jesus
I meant to say Manuals. Sorry.
Old 07-24-2012, 01:36 PM   #33
SUB-FT86
86 Member
I think its a revised IS250 manual transmission.
Old 07-24-2012, 02:10 PM   #34
TouchMyHonda
Vtec Jesus
Got it. Also, I think from what I have searched, the IS350 actually never came with a Manual transmission. Correct?
Old 07-24-2012, 03:26 PM   #35
SUB-FT86
86 Member
Correct. Only the 250
Old 07-25-2012, 10:43 AM   #36
Extreme86
Live Free, Drive Hard
Extreme86's Avatar
Drives: 13 BRZ, 19 WRX, 10 GMC, 20 RAV4
Originally Posted by AJUSA.com View Post
The Airaid system is really coming along quite nicely and is sure to be one of the most developed systems on the market when released. No AFR problems, no CELs, proven power, priced below the other systems on the market, easy installs! Airaid is a company that really "gets it" when it comes to building intake systems.
Check out the progress of the system here: www.ft86club.com/forums/showthread.php?t=8104
I've been following the progress on the AIRAID system and went ahead and pre-ordered from AJUSA.com. Last year I bought an AIRAID system for my 5.3L p/u truck and noted immediate gains in fuel efficiency, acceleration and improved underhood sound...in conjuction with exhaust, wheel, tire and ECU mods.
While using a modified air intake alone, HP and torque gains may be modest as discussed in this tread, I do tend to agree with @Max Schnell and @Apex Chase that intake, exhaust, pully and ECU mods will all work together to achieve and demonstrate measurable performance gains. For those of us not going the $5000+ turbo route, the intake system cannot be ignored.
The way I see it, the choices are:
1. Stock system with stock air filter - $0 - no gain.
2. Replace the panel filter - $40+ up - modest HP gain.
3. After market air intake - $210+ up - slightly more modest HP gain.
I had intended to follow approach #2 but, today I pulled the trigger on an AIRAID system because it is a good deal for what looks to be a quality Researched & Developed system. This particular deal expires tomorrow, 7/26, so for about $210 after coupon code and rebate...it is worth it to me.
AIRAID Pre-order thread:
http://www.ft86club.com/forums/showt...471#post335471
Extreme86 is offline   Reply With Quote
Old 07-26-2012, 07:09 PM   #37
Acc
Old Schooler
Drives: GD, GC, NPS50
Its about about Sound HP......if it makes you happy then get it. Just always remember to replace/clean/re-oil your filter regularly =]
Acc is offline   Reply With Quote
OptionJDM- Exhaust systems OptionJDM Engine, Exhaust, Bolt-Ons 29 09-04-2012 04:37 PM
drive-by-wire systems... Axel Other Vehicles & General Automotive Discussions 6 01-15-2010 01:41 PM
