Old 07-29-2020, 11:48 AM   #43
mrg666
pessimistic skeptic
mrg666's Avatar
Originally Posted by weederr33 View Post
Then I will keep telling you that!!!! Weight loss, no matter what is always better. Stop with your fact checking.
I wish there was an aftermarket aluminum frame kit for 86. I would swap everything on to the aluminum frame while replacing with carbon fiber body panels and drive shaft. I wonder how much weight we could save.
Just like the frame replacement of Dodge Viper in Alex Rebuilds
Old 07-29-2020, 12:03 PM   #44
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Toyota Dynamic Force Engine
You now almost no modern car uses a frame anymore right?
The front subframe is aluminum-no it isn’t I was wrong-
The rear is steel, but I doubt you can make it much lighter than it is out of aluminum. Hood is aluminum. No gains there Trunk lid and doors are steel, might save a couple pounds there, but not 50lbs. Maybe 10-15. Fenders and roof are steel, but very thin, you can probably lose a couple pounds there too.
Point is, this car is very light as is. Throwing aluminum at it might not change much. Keep in mind also that this car is over a foot longer than the ND Miata, and that’s almost all in the wheelbase. There is nothing out there that is RWD and this size that is lighter than this car.
The Following 3 Users Say Thank You to Yoshoobaroo For This Useful Post:
dragoontwo (07-29-2020), mrg666 (07-29-2020), why? (07-30-2020)
Old 07-29-2020, 12:35 PM   #45
mrg666
pessimistic skeptic
mrg666's Avatar
Originally Posted by Yoshoobaroo View Post
Uhhhhhh. You now almost no modern car uses a frame anymore right?
Hood and roof are aluminum. No gains there
Point is, this car is very light as is. Throwing aluminum at it won’t change much. Keep in mind also that this car is over a foot longer than the ND Miata, and that’s almost all in the wheelbase. There is nothing out there that is RWD and this size that is lighter than this car.
I know, that is why I said "frame kit" not just frame. But I did not know front subframe was aluminum already. Thanks! Then, there are only fenders, doors, trunk, rear subframe, and drive shaft that can be replaced. Are you sure roof panel is aluminum? Mine started showing two tiny rust spots at the edge.
Edit: Did the magnet test; roof is definitely steel.
The Following User Says Thank You to mrg666 For This Useful Post:
Yoshoobaroo (07-29-2020)
Old 07-29-2020, 12:37 PM   #46
Yoshoobaroo
TRACKBREAD
Haha I just pulled out a magnet too! Correction, roof is steel
And sorry, I’m confusing it with my other car, front subframe is steel too. My bad.
I kind of like the idea of an aluminum subframe and suspension arms kit for the front and rear, but it would probably be very expensive.
The Following User Says Thank You to Yoshoobaroo For This Useful Post:
mrg666 (07-29-2020)
Old 07-30-2020, 02:37 AM   #47
RayRay88
Drives: 2017 86 860 Special Edition
Aluminum is all fun and games until you twist it like a pretzel. There's a reason why most manufacturers are going to high strength steel, the thickness to strength ratio for aluminum is drastically lower than steel. At time it's much lighter to just go with steel parts.
Low production/bespoke aluminum chassis' like Corvette's and Ferrari's need not apply.
RayRay88 is offline   Reply With Quote
Old 07-30-2020, 07:31 AM   #48
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
Some of these compounds are including all sorts of exotic metals too. When you can mix steel with tungsten and other materials to make it both stronger and lighter it is hard to beat.
why? is offline   Reply With Quote
Old 07-30-2020, 07:44 AM   #49
Yoshoobaroo
TRACKBREAD
Al: 6061 T6:
Yield strength: 276MPa
Density: 2700kg/m^3
~.102 MPa/kg
Steel: 980X high strength steel:
Yield strength: 550MPa
Density: 8000kg/m^3
~.069 MPa/kg
For a given weight aluminum is stronger than high strength steel. And 6061 isn’t even an exotic aluminum alloy. 7050 is twice as strong. For the same volume (thickness) 980X HS Steel is about twice as strong as 6061, but it’s over 3 times heavier. The only reason they pick steel over Al is cost.
Keep in mind that 6061 is a fairly weak Aluminum Alloy and 980X is the strongest SAE HSS used in automotive applications.
why? (08-01-2020)
Old 07-30-2020, 10:31 AM   #50
Ernest72
I think the complaining about the torque comes from the fact that, despite everyone thinking they are a race car driver, many just drive normally most of the time. So if you spend a lot of time under 4K then the car is fairly normal. Plus you will be beat off the line by any car with more torque.
I switch back and forth between the BRZ and The WRX, and you really notice how much slower it is if you drive the same way. On the other hand if I am above 5k on my WRX we are heading for 100mph. The BRZ steering, lightweight and ability to wind it out really make it fun. I personally feel the BRZ only needs a little more torque, if I had the power from the WRX, it would minimize the amount of time I am at high rpms. There are days that I drive my WRX and I never go higher than 4K. And on twisty roads it’s tough to get higher rpm because there is no room for that speed.
We need a small electric supercharger to increase low end torque and skip high end. This would be best for DD and spirited mountain twisty runs. We will not get it because racing always wants and needs high end.
The Following User Says Thank You to Ernest72 For This Useful Post:
Ohio Enthusiast (07-30-2020)
Old 07-30-2020, 11:04 AM   #51
Yoshoobaroo
TRACKBREAD
I’d rather put that electric motor in the bell housing, like a RWD CRZ. Add a small battery pack in the trunk to balance it out and done.
mrg666 (07-30-2020), Ohio Enthusiast (07-30-2020), why? (08-01-2020)
Old 07-30-2020, 12:21 PM   #52
RayRay88
Al: 6061 T6:
Density: 2700kg/m^3
~.102 MPa/kg
Density: 8000kg/m^3
~.069 MPa/kg
That's a fairly blanket statement, especially when you ignore Tensile strength. Aluminum has its place depending on part geometry but for most high volume, low cost options steel is much better suited. I do agree that cost is most definitely a factor but in the real world aluminum parts are usually not 3 times lighter, maybe 25-50% lighter for most automotive chassis applications.
Old 07-30-2020, 12:30 PM   #53
Yoshoobaroo
TRACKBREAD
Correct, if you made aluminum parts 3 times lighter than steel they would be weaker than steel.
My math shows they’re about 33% lighter than equivalent steel, which is about what you see in cars like older BMWs, where both steel and aluminum control arms are available as OEM parts.
Steel arm: ~1.5 lb
Al arm: ~1 lb
Old 07-30-2020, 12:35 PM   #54
RayRay88
Steel arm: ~1.5 lb
Al arm: ~1 lb
Yup, and that gap/savings shrinks even smaller when you get to chassis panels and stamping's with awkward cross sections and geometry's.
Old 07-30-2020, 02:19 PM   #55
Yoshoobaroo
TRACKBREAD
Yea aluminum doesn’t stamp that well. Much better to make structural parts with extrusions and castings.
I’m not suggesting an aluminum unibody. Those are expensive, like high end Audi’s and Jags use. But aluminum front subframe and aluminum control arms can help. You probably won’t do better than 20 pounds, but hey, it’s 20 pounds. The control arms are nice because you’re shedding off some sprung weight.
Old 07-30-2020, 06:46 PM   #56
Ernest72
I’ll take that.
Toyota 2AZ-FE Engine Swap srscion Engine Swaps 54 10-26-2020 11:13 PM
FS: Toyota OEM engine oil n0m0h0s Mechanical Maintenance and Tools 14 03-28-2013 02:26 PM
Toyota Engine Name Plate GT86drifter Scion FR-S / Toyota 86 GT86 General Forum 13 10-26-2012 07:48 PM
FT-86 / FR-S engine will be Toyota 2l turbo!! Slide Engine, Exhaust, Transmission 114 07-07-2011 11:58 PM
