Old 07-28-2020, 09:03 PM   #1
daniloneil8
Minimum steps for Replacing wheel studs. Front vs. Rear.
I just want to clear up some confusion in the archives.
For front studs, you need to remove the caliper and the rotor.
Then you have free access to remove and replace studs.
For rear studs, you need to remove the caliper and the rotor.
Then you need to rotate the hub to find that clear open spot where you can remove and replace each stud.
Is this above correct?
Are all these steps required?
Do you even need to remove rotors to replace broken wheel studs?
This guy does not
daniloneil8 is offline   Reply With Quote
Old 07-28-2020, 09:40 PM   #2
Joveen
Joveen's Avatar
Drives: Bone stock
Yea the front is easy. The rear kinda more involved but still simple.
Sent from my SM-N960U using Tapatalk
Joveen is offline   Reply With Quote
Old 07-28-2020, 10:02 PM   #3
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Pound stud out
Pound stud in
That's less complicated than what you proposed! Just make sure nothing is in the way and you're good.
humfrz (07-28-2020)
Old 07-28-2020, 10:16 PM   #4
Originally Posted by DarkPira7e View Post
Pound stud out
Pound stud in
That is no good without a 15 minute video, in full color, and using pretty gloves -
DarkPira7e (07-28-2020), JohnJuan (07-29-2020)
Old 07-29-2020, 01:53 AM   #5
KR-S
Sporadic Member
KR-S's Avatar
Drives: 2016 Halo FR-S M/T
Pound stud out
Pound stud in
Ehhh, I found the ball joint method to be much more effective and straightforward in my opinion. Just gotta watch where your washers are.
I mainly watched @justinco's video instead of the linked video; haven't watched the above video admittedly but Justin's video is clear enough such that it helped with my removing the wheel studs.
Depends on if you're installing regular wheel studs or extended wheel studs. The latter requires disconnecting the axle from the wheel hub, and the axle is a bitch to remove if the car has several years on it already.
The Following User Says Thank You to KR-S For This Useful Post:
justinco (08-05-2020)
Old 07-29-2020, 06:30 AM   #6
Joveen
Joveen's Avatar
Drives: Bone stock
. I didnt remove mine.
Old 07-29-2020, 08:56 AM   #7
Takumi788
JHerbert Racing
Takumi788's Avatar
Drives: 2013 Scion FRS
If you do plan to remove the entire rear hub, make sure you remove the ABS sensor BEFORE sliding the axle inwards. The ABS sensor fits in a groove of the axle and you will break it otherwise.
- #813 2013 Scion FRS Build Thread
- JHerbert Racing Website
Takumi788 is offline   Reply With Quote
The Following User Says Thank You to Takumi788 For This Useful Post:
Wally86 (07-29-2020)
Old 07-29-2020, 09:46 AM   #8
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
I just installed 2.5" ARP and did not remove the rear hub.
The nipples on the end are the only thing stopping them from going in.
RToyo86 is online now   Reply With Quote
Old 07-29-2020, 09:58 AM   #9
YamahaR86
JDM Vaping Stance Nation
YamahaR86's Avatar
Drives: 2013 White
That's what I did. Removed caliper and rotor, used HF press tool since I couldn't get it out by hammering.
Exactly as you described for the rear, had to rotate it a little to find the sweet spot to get the bolt out.
Clueless
YamahaR86 is offline   Reply With Quote
Old 07-29-2020, 10:00 AM   #10
KnightRyderx2
Drives: 2014 FR-S
This guy does not
You got it right, its just that simple. The only thing in the rear is you have to find that spot behind the hub where it can be removed. Also use a small sledge, 3 pound, makes it easier to remove them.
The video is fine but whats 2 more minutes to remove the rotor.
I had to replace a couple at the rear and it took 20 minutes, not a complicated job.
KnightRyderx2 is offline   Reply With Quote
Old 07-29-2020, 10:13 AM   #11
Grady
Grady's Avatar
The Following User Says Thank You to Grady For This Useful Post:
soundman98 (07-29-2020)
Old 07-29-2020, 06:32 PM   #12
jflogerzi
jflogerzi's Avatar
Saved for the future when a stud finally breaks on me
2013 Series 10 FRS #553
Old 07-29-2020, 09:42 PM   #13
daniloneil8
I am only referring to OEM studs, not extenders.
In that case, rear OEM stud is same as front?
Just pound out and pull in, and just need to find that gap?
Nothing special about the rear?
The Following User Says Thank You to daniloneil8 For This Useful Post:
finch1750 (08-04-2020)
Old 07-30-2020, 08:53 AM   #14
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Yes. I've done both front and rear and the studs are the same. The rear is just a tiny bit trickier because of other stuff that gets in the way on the back side of the hub. I personally use the ball joint press method, but if you are comfortable with pound and pull, go for it.
Subaru field engineer says OEM wheel studs only good for 75 to 80 wheel changes Pat Tracking / Autocross / HPDE / Drifting 86 07-16-2021 10:50 AM
FS: 20 OEM Wheel Studs (new) skylinekin Brakes, Suspension, Chassis 1 02-24-2020 09:33 PM
Want to install ARP wheel studs in front...any recommendations? VVT4ME Northwest 3 05-25-2017 02:36 AM
Stoptech Front 328x28 - Minimum spacer size with OEM wheels ? asnatlas Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 01-13-2017 11:38 PM
ARP Wheel studs and 10mm hubcentric wheel spacers S1CNSTY_SUBIE Wheels and Tires 3 04-17-2015 08:31 AM
