Old 06-07-2016, 10:38 AM   #1
asnatlas
Drives: 2013 - BRZ - SWP
Post Stoptech Front 328x28 - Minimum spacer size with OEM wheels ?
Originally Posted by F1point4 View Post
OEM Wheel
17x7 ET48: http://www.ft86club.com/forums/showp...39&postcount=3
Stoptech Front 328x28 ST40M Kit
20121012-86OEMWheelBBKTemplates-4 by VictorN07, on Flickr
Anyone know minimum spacer size needed for the Stoptech Front 328x28 ST40M Kit with OEM wheels ?
asnatlas is offline   Reply With Quote
Old 06-07-2016, 12:28 PM   #2
Sleepless
Sleepless's Avatar
Drives: 2016 FR-S
I believe it is 10mm.
BTW - When I did the math to convert to longer wheel studs and the cost of the spacers, it added up to close to the cost of 4 excellent new wheels with the correct offset. So, I just got the wheels.
Sleepless is offline   Reply With Quote
The Following 2 Users Say Thank You to Sleepless For This Useful Post:
asnatlas (06-07-2016), continuecrushing (06-07-2016)
Old 06-07-2016, 01:58 PM   #3
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
The spacer you need exceeds what you can safely use on the stock studs, if it answers your question.
So you're stuck between choosing 5-10mm w/ extended studs, or 15mm bolt-on, or proper wheels.
-alex
Old 06-07-2016, 02:18 PM   #4
asnatlas
The reason I am asking is because I have two sets of OEMs wheels that I was planning on using for track and AutoX. If I just need 5-10mm spacers on the front I should be able to get away with the Ichiba Version 1 Wheel Spacers for like $95-ish ??
They also have the Ichiba Version 2 Wheel Spacers in 15mm...
I already have 18s, but wanted to be able to use both sets of OEMs wheels for Track / autoX with the Stoptech Front 328x28 ST40M Kit up front...
Old 06-07-2016, 02:20 PM   #5
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
this is a big one, I did the same thing a while back and was like well this just won't be worth it so I just got the right stuff (new wheels lol) from the get go.
Old 06-07-2016, 06:14 PM   #6
mav1178
mav1178's Avatar
Wheels with proper BBK clearance > slip-on spacers with long studs > bolt-on spacers
That is the preference.
For track, 9 out of 10 groups won't even let you run on track with a spacer.
-alex
The Following User Says Thank You to mav1178 For This Useful Post:
continuecrushing (06-11-2016)
Old 06-14-2016, 03:03 PM   #7
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
I am currently running stock wheels with this BBK. I got a 12 mm spacer to make sure they fit, and I am pretty sure the minimum has to be less than 10mm. There is plenty of space with the 12 mm spacer. Now, I cannot tell if it'll be good enough with 5mm....
The Following User Says Thank You to Sportsguy83 For This Useful Post:
asnatlas (06-14-2016)
Old 06-14-2016, 03:16 PM   #8
asnatlas
Post
I printed out the Stoptech BBK wheel fitment template (ST-40 - 328x28) and I am going to check it with 5mm to see if it will work. I will post pics when I do that...
The Following 3 Users Say Thank You to asnatlas For This Useful Post:
86ft.lb (10-12-2016), CxG (06-24-2016), Sportsguy83 (06-14-2016)
Old 01-13-2017, 11:38 PM   #9
ein86
I hit cones.
Drives: 2015 FRS
Random bump.. I just installed mine and tried the stock wheel with a 5mm spacer, does not work, the edge of the caliper closest to the hub hits the spokes. 10mm works like a champ...
ein86 is offline   Reply With Quote
Wheel Spacer Size?? tonytduc Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 52 11-03-2018 03:36 AM
StopTech Big Brake Kit 328x28 Weights and Pics :) FT-86 SpeedFactory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 40 11-21-2016 08:55 PM
Sold: Stoptech 328x28 BBK industrial Brakes, Suspension, Chassis 9 06-28-2016 08:41 PM
FS: NC Stoptech 328x28 ST40 BBK - Silver/Slotted - Brand new in Box KNS Brakes Brakes, Suspension, Chassis 3 02-21-2015 12:50 PM
