Old 07-25-2020, 12:49 AM   #29
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
What alignment would be ideal for my driving style (daily and canyons and hooning)? Like I know I can’t adjust much as is, but say I could adjust anything then what is the ideal setup for me? Like back to factory specs would be good? How much camber is ideal? Obviously no camber is needed to go straight down the road, and shouldn’t there be some dynamic camber under cornering suspension compression, right? Would a basic alignment place know the stock specs, or do I need to supply that or my wishes? Just looking to be prepared.
Old 07-25-2020, 01:47 AM   #30
Decep
Drives: 2013 FR-S Series 10
Find a place that accepts custom alignments, a lot of places just want to put it on the rack and make sure the numbers are green and make the quick buck.
With lowering you should be able to get -2 degrees front with camber bolts easily enough. Lower control arms in the rear is recommended for adjusting rear camber.
I'd say -2F -1.5R is a good starting point but honestly if you can tell a huge difference on the street between -2 degrees and -1 degrees you are probably gonna get your car impounded at some point. I prefer zero toe but a teeny bit of toe in helps stability
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers
Corsa Catback
Edelbrock Supercharger installed @ 50k
The Following 2 Users Say Thank You to Decep For This Useful Post:
Irace86.2.0 (07-25-2020), Yoshoobaroo (07-25-2020)
Old 07-25-2020, 08:52 AM   #31
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
This should be pretty good for a ~1” lowered car. Toe is the most important here, you want 0 up front ideally. The steering in this car is precise enough that it won’t be unstable at speed. Camber and Caster will be what it is most likely, it’s not adjustable on this car. They can adjust the front a tiny bit by shifting the strut mounts in the bolt holes, but they likely won’t.
None of the tires show center wear. It is progressive from the inside out.
That’s good! Pressure should be okay then! We do have to keep in mind than the range of acceptable tire pressure is pretty wide.
The Following 3 Users Say Thank You to Yoshoobaroo For This Useful Post:
Irace86.2.0 (07-25-2020), Jdmjunkie (07-25-2020), Racecomp Engineering (07-25-2020)
Old 07-25-2020, 02:20 PM   #32
JD001
JD001's Avatar
Drives: Subaru BRZ
Another thing to check is the condition of your shocks. If they're knackered then you can experience some strange wear patterns on the tyre.
Old 07-29-2020, 08:58 PM   #33
Irace86.2.0
UPDATE: I took the car in for the alignment. Here are the results. I am ordering some Michelin Pilot 4S, so I have them ready. I think the toe is part of the problem, but because the left front is so good and the right front is so bad, and the toe seems to be both bad, I can only conclude that perhaps it is just the driving style.
I was explaining to the technician how the left rear kicks out to the left under heavy throttle like 99% of the time, and how I thought it does it less with traction control on, which leads me to believe it is the VSC, and he said that could be the case. I asked how I could have such bad wear on one and good wear on the other, and the technician says in the US we make more right hand turns, which makes sense like I am much more likely to make a power slide on right hand turns from a stop (for fun) than during wider and longer left hand turns. Maybe that could explain some of it. I don't know.
The Following User Says Thank You to Irace86.2.0 For This Useful Post:
Thefalls (08-01-2020)
Old 07-30-2020, 01:59 AM   #34
RayRay88
Drives: 2017 86 860 Special Edition
Looks like Toe was all your issues, that plus slightly over inflated tire pressures. 35/38 cold pressures can easily become over-inflation after 15-20mins of highway driving. Old tires are also very sensitive to bad toe/camber and will start wearing unevenly.
I'm still shocked people make suspension changes and think it's ok to drive without an alignment.
RayRay88 is offline   Reply With Quote
The Following 3 Users Say Thank You to RayRay88 For This Useful Post:
Irace86.2.0 (07-30-2020), JD001 (07-30-2020), p1l0t (07-30-2020)
Old 07-30-2020, 09:39 AM   #35
The "before" was not good.
- Andrew
Old 07-30-2020, 12:50 PM   #36
Irace86.2.0
0.9” drop, and I’m oversized on my tires by 3%, so it is about a 0.5” drop in chassis to ground height and less than an inch in drop from chassis to hub. I figured that wasn’t exactly large enough to make much difference in toe. I’m still surprised 0.04 degree of toe difference between the right and left front was enough to destroy a tire and leave a tire looking fairly new.
Old 07-30-2020, 04:13 PM   #37
RayRay88
Toe will exacerbate any underlying issues like over inflation, old heat cycled tires etc,
The "chassis to hub/ground height" is irrelevant and not a constant or tangible measurement.
Makes sense, most people, like yourself, don't understand how suspensions work. This is why I think there should be more disclaimers everywhere in instruction manuals and DIY's. if you make any change to your suspension geometry you should get an alignment. Best err on the side of caution rather than destroy your tires. $100 is good insurance when spending $500-$800 on tires, not to mention better handling.
The Following User Says Thank You to RayRay88 For This Useful Post:
Jdmjunkie (07-30-2020)
Old 07-30-2020, 05:40 PM   #38
Irace86.2.0
So that toe difference is difference enough to explain no wear versus terrible wear? Interesting.
Old 07-30-2020, 06:22 PM   #39
itschris
Drives: '14
When looking at front toe, just look at the total. You'll naturally compensate with the steering wheel so it's even side to side. There is no difference left to right, except how centered the steering wheel was when the shop performed the alignment.
Even though you have very little camber, wear from toe out + neg camber is going to compound. -0.9 deg * half the total toe out is going to cause way more inside edge wear than -0.4 deg * half the total toe out.
You might notice some outside edge wear now that your toe is zeroed, but high tire pressures could hide it. Watch it and think about camber bolts if you notice any appearing.
itschris is offline   Reply With Quote
The Following 2 Users Say Thank You to itschris For This Useful Post:
Irace86.2.0 (07-30-2020), RayRay88 (07-30-2020)
Old 07-30-2020, 08:27 PM   #40
Irace86.2.0
I see. I missed that, as I was just fixed on the absolute and relative measurements by themselves, which didn’t look egregious, but that makes sense. The camber wasn’t that big and neither was the difference, and the toe wasn’t much different, so I didn’t even put two and two together that the synergistic effect would make the difference. Thanks.
Old 08-01-2020, 12:28 PM   #41
Thefalls
Thefalls's Avatar
Drives: Corolla GT
Your Tech is right in what he said. I have noticed the same thing. Left rear has more wear due to same driving style.
Thefalls is offline   Reply With Quote
The Following User Says Thank You to Thefalls For This Useful Post:
Irace86.2.0 (08-01-2020)
How does my tire wear look? R_E_L Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 09-08-2018 07:34 AM
tire wear oppiee Tracking / Autocross / HPDE / Drifting 9 08-29-2017 12:55 PM
Tire Wear? Flo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 01-10-2017 03:19 PM
Uneven Tire Wear tofurun Tracking / Autocross / HPDE / Drifting 2 11-22-2016 11:45 PM
Uneven wear with AP Racing Sprint BBK ATL BRZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 57 09-05-2016 10:55 AM
