Old 11-22-2016, 11:13 PM   #1
tofurun
tofurun's Avatar
Drives: 2014 BRZ Limited 6MT
Uneven Tire Wear
Ok some im sure a lot of u guys on this part of the forum can answer this for me. Tracked the car and the sidewall tread section is alot more worn then the rest of the tire. Tires are re71r.
Car started to develop a slight bounce under light acceleration between 35-40. Took off tires and got them re balanced. Rotated the front to the rear. Now i get the same thing under light acceleration between 45-50.
Is this a symptom of the extra wear on the outer edges of the tires from hard cornering or do i need to start looking other places. I dont think a normal driver would notice it but im pretty good at knowing when something is "off" on my car.
tofurun is offline   Reply With Quote
Old 11-22-2016, 11:20 PM   #2
cjd
cjd's Avatar
Drives: 2017 BRZ
What's your camber? Heavy wear on the outside edge, as well as uneven wear on the center rib, are both common - especially if you have less than ideal camber (>3f/2+r)
Old 11-23-2016, 12:45 AM   #3
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
What kind of tire pressures did you have on the track?
With out pics I'm guessing you have some feathering on the outside treads. From my experience that is due to heavy braking while turning. I can bet your tires where screaming during your runs.
Uneven wear with AP Racing Sprint BBK ATL BRZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 57 09-05-2016 11:55 AM
Strange tire wear PandaBRZ Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 04-18-2016 03:22 AM
Tire Wear question bacon_cheese_beer Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 27 12-08-2014 03:51 AM
Tire Wear Help babykwiss Tracking / Autocross / HPDE / Drifting 10 07-14-2014 12:31 PM
question about tire wear driver01 Tracking / Autocross / HPDE / Drifting 8 08-05-2012 10:50 PM
