Old 07-20-2020, 03:00 PM   #1
02maher
02maher's Avatar
Drives: Gt86 2013
Low Beam Headlight not working
Hi people, my Low beam headlights won't work but the high beam turns on instead
Some mechanic which I don't wanna go back to because of his extremely poor services might have done something while checking for another issue.
Any ideas what could the reason be?
02maher is offline   Reply With Quote
Old 07-22-2020, 04:39 AM   #2
02maher
02maher's Avatar
Drives: Gt86 2013
Alright so apparently someone stole one of my relays... I placed another one and it worked.
Old 07-22-2020, 08:17 AM   #3
02maher
02maher's Avatar
Drives: Gt86 2013
I have another problem after I changed my ecu and ecm the headlights leds (part of the high beam) are on when the switch is off... when the switch is on low beam then it turns off. So can can never have all lights off except when I lift the hand breaks.
Does anybody know how to program the headlight to be completely off?
beam, electrical, fuse, headlight, relay
Headlight projector not working ZialandB Cosmetic Modification (Interior/Exterior/Lighting) 3 03-11-2020 06:06 PM
Driver Side High Beam Not Working username404 Electronics | Audio | NAV | Infotainment 16 08-08-2017 04:53 PM
Right low beam not working. zman Issues | Warranty | Recalls / TSB 13 03-14-2016 09:08 PM
Low Beam Lights Not Working acwells25 Issues | Warranty | Recalls / TSB 2 02-03-2016 11:46 AM
FS: Brand New GT86 Headlight LHD Beam Pattern nigel-jdmparts Exterior Parts - Lighting 4 08-21-2014 12:48 PM
