Drives: 2017 BRZ
HKS V3 supercharger
Hi guys, since i have the supercharger kit on my car, the spark plugs had failed 3 times.
Just wondering is the oem plugs good enogh to handle 10 psi of boost ? Any recommendation for some good aftermarket plugs ? |
#2 |
Purist
Drives: 2013 FRS - Hot Lava
HKS Plugs
WTB: Everything Verus
RaceComp SS-1, Complete SuperPro bushings, TR Motorsport FF10 17x9 +45, GruppeS UEL, HKS Hi-Power V2, OFT(93/E85) |
#3 |
Drives: 2017 toyota 86
People are running 20+ Psi and 550+ whp on stock plugs. What was wrong with yours to make them fail? HKS plugs seem pretty good though. But if they went bad for any reason other then not being up to par (which I doubt is the reason) it will probably keep happening.
| The Following User Says Thank You to 86TOYO2k17 For This Useful Post: | CSG Mike (07-15-2020) |
#5 |
Agreed with others. Are they burning out or getting fouled
2013 Series 10 FRS #553
#6 |
Drives: 2015 Firestorm 08/05/15
I’d bet this is tied to tune / tune related. Follow up plsr when you get it sorted I’m curious as heck myself
#7 | |
Imperator
Drives: Supercharged 2013 BRZ Limited
I've had no problems with the OEM spark plugs, although I am running E85 (not sure if that makes a difference?). |
#8 |
pessimistic skeptic
That is probably a bad tune running too rich. I would get a proper retune with the new plugs.
#9 | |
Drives: 2013 Scion FR-S in White
When I had this car and used the default tune from HKS I decided to buy the HKS spark plugs. The only reasoning I had at the time was because that’s the part they used for their testing and I trusted the brand. (And I wanted something to play with on the car) After taking out the factory plugs I noticed they were a bit black and felt better about buying the HKS set. I am going to have to recommend you buy 5 though. After several hours of installing the plugs one of them was bad and it didn’t run right. I had to put an oem plug back in until the replacement arrived. Sent from my iPhone using Tapatalk |
| Tags |
| sparkplugs, supercharger |
| HKS V3 Supercharger | lunatic808 | Forced Induction | 1 | 04-07-2018 08:44 PM |
| HKS Supercharger GT Property Kit or HKS Supercharger V2? | Ragingft86 | Forced Induction | 5 | 12-10-2016 12:59 PM |
| Supercharger help | Scott_frs | Forced Induction | 2 | 01-16-2015 02:56 PM |
| HKS Supercharger Kit for FR-S & BRZ. | 1660 | Engine, Exhaust, Transmission | 6 | 11-27-2012 06:11 AM |
| supercharger? but by who? | carbonBLUE | Forced Induction | 14 | 11-02-2012 10:10 PM |
