Old 08-13-2019, 10:42 AM   #29
atomicalex
Drives: 2018 BRZ Limited Perf Pack
Ok, now have on good authority that there may be Aisin options. I have a lot of research to do.
If anyone is interested, PM me, I will give you a task.
edit - not to take away from MFactory. But I work in the metalworking industry. They are not kidding about needing to make a lot of parts to make this work. This is a huge ass headache for them for a part that is highly specialized, much more so than a short 6th.
www.atomicalex.com
2018 BRZ Limited Perf Pack 6MT, a couple of motorcycles, and a stick shift station wagon
atomicalex is offline   Reply With Quote
The Following 2 Users Say Thank You to atomicalex For This Useful Post:
Spawn_Of_Creation (08-13-2019), Ultramaroon (08-13-2019)
Old 08-13-2019, 03:18 PM   #30
jcw99
Drives: swp mt '14 brz premium
I found that a Nissan Silvia S15 had an AZ6 with a .767 6th gear. The thread is on Grassroots Motorsports. I don't have many computer skills and my wife's at work so I can't provide a link. It was dated 9/27/2011.
jcw99 is offline   Reply With Quote
The Following 2 Users Say Thank You to jcw99 For This Useful Post:
atomicalex (08-13-2019), Ultramaroon (08-13-2019)
Old 08-13-2019, 05:01 PM   #31
jcw99
goofed up
Just realized we have .767 already and we're looking for .687. I didn't see anything higher than .767 so my search didn't help us.
The Following User Says Thank You to jcw99 For This Useful Post:
atomicalex (08-14-2019)
Old 07-20-2020, 02:33 PM   #32
airrick
Drives: TRD R.S. 1.0 FRS
This ever materialize?
airrick is offline   Reply With Quote
Old 07-20-2020, 08:50 PM   #33
chipmunk
Drives: _
Isn't it already tall enough...?Name:  20200720_194838.jpg
Sent from a potato
chipmunk is offline   Reply With Quote
Old 07-21-2020, 02:23 AM   #34
86TOYO2k17
Drives: 2017 toyota 86
Feel like a slightly taller 1st and 2nd with a 3.9 FD would make the gearing perfect. Would make 6th taller too.
Old 07-21-2020, 08:40 AM   #35
Spawn_Of_Creation
Human
Drives: 2015 BRZ Black
There are already taller 1st and 2nd mfactory gears, and shorter 6th.
"Always listen to experts. They'll tell you what can't be done, and why. Then do it." - The Notebooks of Lazarus Long
Spawn_Of_Creation is offline   Reply With Quote
Old 07-21-2020, 09:34 AM   #36
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
I feel like it's so much more work to change gears in the trans vs a differential. If you're not making them stronger, why touch them? Any change in a lower gear makes the gear above it unbalanced I'd think.
Not being combative; just discussing
Wally86 (07-21-2020)
Old 07-21-2020, 09:55 AM   #37
86TOYO2k17
Yup, and doing the 1-2 with a FD would be perfect. no need for 6th swap.
spacing on the 1-2 and 2-3 could be better. 3-4 and 4-5 are pretty good as is.
Old 07-21-2020, 12:26 PM   #38
PulsarBeeerz
Drives: JRSC BRZ SOLD
It would much slower NA, but great for turbo kitted cars.
PulsarBeeerz is offline   Reply With Quote
Old 07-21-2020, 01:46 PM   #39
86TOYO2k17
not necessarily, each shift with a 4.1 FD when you otherwise wouldn't have had to shift with a 3.9 FD you lose the mechanical torque advantage until you would have to shift with the 3.9FD. from 0mph to x mph a more aggressive FD will generally be faster true and by roughly the % difference of the numerical value although usually a little less, so less then 5% in this case,
BUT,
From any given speed to any given speed it can vary which one is actually faster because of the need to shift vs not needing to etc... you can't just blanket statement one is ALWAYS faster, and even from 0-x mph it would be less then 5% slower not MUCH slower.
BUT,
with a taller 1-2 gear to stay in peak power band in 2-3 gears longer it would more then make up for any mechanical torque lost with the 3.9 FD while still giving you a mechanical torque advantage when you otherwise would have shifted but now don't from the 3.9 FD, so win win.
So yeah it would be good for both NA as you could still do 0-110mph in 4th and FI will allow you to use 5th to about 135mph. Even without FI 5th gear NA with a 4.1 is disappointing unless you go to 4.56+ FD, but then top speed in 5th now drops to almost what 4th was with a 3.9FD but requires 1 more shift to do so and MPG/RPM in 6th become that much worse.
Old 07-21-2020, 04:53 PM   #40
Spawn_Of_Creation
Human
This is why some people want the taller 6th to use a as a sacrificial gear for cruising and mpg.
Old 07-21-2020, 05:15 PM   #41
86TOYO2k17
Yup. And an alternative is taller FD swap. Paired with taller 1-2 gears would be perfect.
Old 10-05-2020, 03:12 PM   #42
Jdmjunkie
Drives: Scion FR-S 10 Series
Do we have a tally of how many people are still interested? I this goes through count me in!
Jdmjunkie is offline   Reply With Quote
Taller 6th gear? tshrey Engine, Exhaust, Transmission 6 10-24-2017 06:09 AM
Do Automatics have Taller Gears ItzYaBoyBugZ Scion FR-S / Toyota 86 GT86 General Forum 19 05-31-2015 01:42 PM
taller final drive ratio SuperDave Engine, Exhaust, Transmission 17 10-26-2014 04:37 PM
Anyone running taller tires? cactus Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 02-04-2014 04:22 AM
Would a taller / larger oil filter improve oil cooling? brillo Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 6 05-14-2013 04:18 AM
