Old 07-17-2020, 12:50 AM   #18565
iag48st
Drives: 10Series 0945
Originally Posted by N_Raged View Post
Replaced my clutch pedal assist spring with the MTEC spring hoping that it would help me smoothen out my release. Not sure how I feel about it... It's definitely different to enough that I have to relearn how to be smooth. There is more modulation where the stock clutch spring was numb. I guess this is why people do this mod or remove the spring altogether.
Full disclosure: I learned to drive stick on this car last year, so I'm still somewhat of a novice. However since then I've driven three other manual cars that are each very different, so I do have some frame of reference.
The best thing I ever did to this car was adjust the clutch pedal to grab almost immediately. Made it easier to drive
iag48st is offline   Reply With Quote
Old 07-17-2020, 03:43 PM   #18566
MJones_RB
MJones_RB's Avatar
Drives: Scion FR-S Series 10 #2462
I went from an Integra GS-R to my FR-S and the difference between the two clutches was dramatic. The helper spring took all of the effort and nuance out of the clutch, which would help beginner drivers buy annoy seasoned veterans. I did eventually change out the stock spring with the MTEC one and it did bring back some of the feel. I also changed out the shifter springs for the MTEC ones and that helped reduce some of the notchiness.
MJones_RB is offline   Reply With Quote
Old 07-17-2020, 06:07 PM   #18567
dpfarr
Drives: BRZ ts
Anyone use an adhesive protector for their front lip? Suggestions welcome.
dpfarr is offline   Reply With Quote
Old 07-18-2020, 01:12 AM   #18568
JohnH
Professional wrench
Drives: 2020 BRZ ST RS
yes! I am far from a manual trans novice and this thing was just not quite right. I adjusted the rod above the gas pedal so that there is a little bit of free play and it grabs closer to the floor. I actually had it start to engage about half an inch off the floor but that was too much. Makes it drive quite a bit more normal now
JohnH is offline   Reply With Quote
Old 07-18-2020, 05:25 AM   #18569
oliverthom707
Drives: gergegr
Is there power up there behind the mirror so that you can hard-wire the v1 up in the headliner? mobdro tubemate
oliverthom707 is offline   Reply With Quote
Old 07-18-2020, 08:43 AM   #18570
soundman98
ProCrastinationConsultant
soundman98's Avatar
not that i would use. there's power for the dome light constant-on, and there's power for the mirror. but i would run a 3-conductor off the radio power connections for that function. because i'd rather lose the radio than the dome light or mirror with my garage door buttons in a problem.
Old 07-18-2020, 09:37 AM   #18571
JD001
JD001's Avatar
Drives: Subaru BRZ
She was treated to the sixth year service and new boots.. driving really nice. The tyres quieter than the old set and the bumps are more rounded, however only driven about 20miles (from the garage to home).
The Following 2 Users Say Thank You to JD001 For This Useful Post:
MJones_RB (07-20-2020), spike021 (07-18-2020)
Old 07-18-2020, 08:30 PM   #18572
juenedgi
juenedgi's Avatar
Drives: 2018 Subaru BRZ with PP
Finally recieved my front lip from Japan. It's the Toyota 86 GR front spoiler with bumper side fins. I've always loved the look of the lip since it came out on the 86 GRMN.
Fast forward to 2019, I got the BRZ yet still wanted that front lip. I obtained it through Yahoo Auctions. Just test fitting for now. I know that the 2017+ 86 and BRZ have different holes to drill for the lip. I will need to "mold" the front lip towards the bumper. You can see the gap near the fangs of the bumper. Pics below:
juenedgi is offline   Reply With Quote
The Following 3 Users Say Thank You to juenedgi For This Useful Post:
JonAvalon (07-19-2020), new2subaru (07-19-2020), norcalpb (07-25-2020)
Old 07-18-2020, 09:45 PM   #18573
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
New wheels. O.Z. Alleggerita 17 x 8.
The Following 3 Users Say Thank You to dragoontwo For This Useful Post:
MJones_RB (07-20-2020), N_Raged (07-18-2020), weederr33 (07-26-2020)
Old 07-18-2020, 09:54 PM   #18574
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
Installed my jdl ultra quiet front pipe, some spacers to fix rub at full lock, and fixed an issue with a backout exhaust bolt
Old 07-21-2020, 01:09 AM   #18575
fillthee
Drives: 2013 brz
Installed these headlights, diode dynamics always on module, and JDM sidemarkers (cant get them to clip in properly though)
fillthee is offline   Reply With Quote
The Following User Says Thank You to fillthee For This Useful Post:
juenedgi (07-21-2020)
Old 07-21-2020, 02:25 PM   #18576
wolffbite
Just the tip
wolffbite's Avatar
Drives: 2017 DGM BRZ
Installed my custom emblems! Super happy with how they look. @pete39sp on instagram made them for me around Christmas and I just got around to putting them on.
Up close photos of the trunk really show just how bad the orange peel is on the factory paint here
I did get a matching one made for my steering wheel airbag emblem, but after looking up how badly I would have to hack at it I didn't feel comfortable doing that. So that emblem is just decorating a file cabinet in my room with a bunch of other car parts stickers.
wolffbite is offline   Reply With Quote
The Following 5 Users Say Thank You to wolffbite For This Useful Post:
Dadhawk (07-21-2020), JonAvalon (07-22-2020), juenedgi (07-21-2020), thomasmryan (07-25-2020), Wally86 (07-21-2020)
Old 07-21-2020, 03:11 PM   #18577
Wally86
Be Kind
Wally86's Avatar
Drives: 2020 86
He just shipped mine on saturday and I can't wait to get them! I got a completely different design but yours look amazing too!
[Insert clever signature here]
IG | WhiskyBlog | Photography
Wally86 is offline   Reply With Quote
The Following User Says Thank You to Wally86 For This Useful Post:
wolffbite (07-27-2020)
Old 07-25-2020, 08:26 PM   #18578
Grady
Grady's Avatar
Finally getting to do a track day next Friday. Getting everything ready.
Replaced brake fluid.
Adjusted Ohlins coil overs.
Installed new MPS Cup 2 tires.
Checked alignment.
The Following 2 Users Say Thank You to Grady For This Useful Post:
Breezio (07-28-2020), Clipdat (07-25-2020)
