#15 | |
Drives: FR-S Turbo
Thank you for the tip! I presume I need to remove the sensors to clean out in there. Are we thinking compressed air or will brake parts cleaner do the trick ? |
#17 |
Drives: Black BRZ - STX
I once had a wheel speed sensor going bad and it would randomly put me into limp mode. Was that happening to you when you lights came on? If I recall I couldn't go over about 4000 rpm.
Either way, I've had a rear sensor go bad for no apparent reason. Consider logging some wheel speed data and see if any of them are doing anything wacky. I my case, one sensor would give a couple intermittent readings that were way lower than the other 3 and causing the lights to come on. The issue became more repeatable as my speed increased. Last edited by RRslip; 07-20-2020 at 02:15 PM. |
| The Following User Says Thank You to RRslip For This Useful Post: | Turbo (07-21-2020) |
#18 | |
Drives: FR-S Turbo
I'm not sure - as soon as the dash lit up I putted back to the pits and parked it. Thanks for the wheel speed tip!
| ABS/traction control failure help | Turbo | Issues | Warranty | Recalls / TSB | 11 | 07-14-2020 12:15 AM |
| How to disable Traction Control (TC) and Vehicle Stability Control (VSC) Completely | Sigh-on-Rice | DIY (Do-It-Yourself) Guides | 58 | 03-02-2015 01:48 PM |
| Traction Control vs. Stabilization Control vs. Sport Question | MurderRider | Scion FR-S / Toyota 86 GT86 General Forum | 26 | 08-07-2014 12:56 PM |
| Why does my BRZ have LESS traction with traction control on??? | BRZnut | BRZ First-Gen (2012+) — General Topics | 19 | 12-16-2013 03:28 PM |
| Disabling Traction Control (TC) and Vehicle Stability Control (VSC) Completely | BabyGodzillaGTi-R | BRZ First-Gen (2012+) — General Topics | 40 | 04-25-2012 11:20 AM |
