Old 07-17-2020, 01:46 PM   #15
Turbo
Drives: FR-S Turbo
The wheel speed sensor goes into a slot that reads "teeth". Make sure it's all clean in there on all 4 corners.
Thank you for the tip!
I presume I need to remove the sensors to clean out in there. Are we thinking compressed air or will brake parts cleaner do the trick ?
Turbo is offline   Reply With Quote
Old 07-17-2020, 02:49 PM   #16
CSG Mike
CSG Mike's Avatar
air should be fine
Turbo (07-17-2020)
Old 07-20-2020, 01:59 PM   #17
RRslip
Drives: Black BRZ - STX
I once had a wheel speed sensor going bad and it would randomly put me into limp mode. Was that happening to you when you lights came on? If I recall I couldn't go over about 4000 rpm.
Either way, I've had a rear sensor go bad for no apparent reason. Consider logging some wheel speed data and see if any of them are doing anything wacky. I my case, one sensor would give a couple intermittent readings that were way lower than the other 3 and causing the lights to come on. The issue became more repeatable as my speed increased.
RRslip is offline   Reply With Quote
The Following User Says Thank You to RRslip For This Useful Post:
Turbo (07-21-2020)
Old 07-21-2020, 11:47 AM   #18
Turbo
Drives: FR-S Turbo
I'm not sure - as soon as the dash lit up I putted back to the pits and parked it.
Thanks for the wheel speed tip!
ABS/traction control failure help Turbo Issues | Warranty | Recalls / TSB 11 07-14-2020 12:15 AM
How to disable Traction Control (TC) and Vehicle Stability Control (VSC) Completely Sigh-on-Rice DIY (Do-It-Yourself) Guides 58 03-02-2015 01:48 PM
Traction Control vs. Stabilization Control vs. Sport Question MurderRider Scion FR-S / Toyota 86 GT86 General Forum 26 08-07-2014 12:56 PM
Why does my BRZ have LESS traction with traction control on??? BRZnut BRZ First-Gen (2012+) — General Topics 19 12-16-2013 03:28 PM
Disabling Traction Control (TC) and Vehicle Stability Control (VSC) Completely BabyGodzillaGTi-R BRZ First-Gen (2012+) — General Topics 40 04-25-2012 11:20 AM
