Old 07-02-2020, 04:20 AM   #43
86TOYO2k17
Drives: 2017 toyota 86
Get a used V1 openflash tablet for under 350$ while your at it toss in a high flow K&N filter. Flash to a stage 1 w/ the filter should add a solid 5whp across the powerband and help a little with response. But the main reason for the OFT is to datalog to make sure your afr and ltft / stft are good. You can also use it to modify throttle mapping, tip in, response, etc... this should get your DBW as close to DBC as physically possible.
There is also a procedure you can do after a fresh reflash to learn both throttle position as well as fuel trims much faster otherwise about 10 heat cycles / 100 miles is needed for everything to sort out.
Old 07-02-2020, 04:20 PM   #44
dagle
Drives: assphalt FRS, couple s2000's
there's already a K&N filter present and point taken on the OFT but that'll be a last resort if all else fails. i'd like to leave the ECU stock since i don't have any speed/power goals for the car and would like to keep it that way so i can ignore tuning or monitoring things (old guy move). I have a separate rig to tinker with and would like to keep the FRS so stock that i can have my oil changed at the dealership regularly.
dagle is offline   Reply With Quote
Old 07-02-2020, 05:24 PM   #45
Originally Posted by Summerwolf View Post
Oh, please. Go on. Regale us with at least one tale.
HEY! you talken to me?
Old 07-03-2020, 01:26 AM   #46
soundman98
ProCrastinationConsultant
soundman98's Avatar
I think you bought the wrong car for your stubborn driving style. This isn't a car that takes kindly to bludgeoning like an old chevy...
Old 07-04-2020, 01:36 AM   #47
dagle
huh interesting. what component in the car doesn't like bludgeoning? or are you just asserting something based on your naive perception of cars?
*can see that you're naive because of your little tagline saying boost is whack lol (clearly you have no idea what you're talking about)
Old 07-04-2020, 03:44 AM   #48
Spawn_Of_Creation
Human
Drives: 2015 BRZ Black
I know people have swapped to the metal intake manifold and done a 72mm throttle body and portmatched for increase response. Doing this will require a tune which you can tune out issues with the stock tune.
I had good experiences with low down throttle response using the oft with Wayno's DI tune for a dd application.
"Always listen to experts. They'll tell you what can't be done, and why. Then do it." - The Notebooks of Lazarus Long
Spawn_Of_Creation is offline   Reply With Quote
Old 07-04-2020, 10:16 AM   #49
soundman98
soundman98's Avatar
there's this thing called a joke.
i love how you've done nothing but attack just about anyone that posts in this thread based on minute pieces of information that apparently don't measure up to your massive ego.
Old 07-04-2020, 12:13 PM   #50
dagle
so I’m the one attacking you when you start with asserting that my driving style is stubborn and implying I’m bludgeoning the car? Lol
Old 07-04-2020, 03:11 PM   #51
Skip the spring and go straight for the slave cylinder. Throttle response is hampered by VSC. It is part of the control circuit in all modes except the test mode which, ironically, exists to make the car safe for a dynamometer. Look up "pedal dance."
dagle (07-04-2020), Spuds (07-04-2020)
Old 07-04-2020, 04:59 PM   #52
dagle
i seent the pedal dance and hope i can avoid using it regularly haha. what could i do for the slave? or do you mean replace the slave with a simpler/buffer one?
Old 07-04-2020, 05:05 PM   #53
@Ultramaroon will be back shortly to learn you about how to modify the slave cylinder -
dagle (07-04-2020)
Old 07-04-2020, 05:23 PM   #54
dagle
haha i just went through his authored posts and think i found it. knocking off the spring is free and 5-10 minutes, this requires ordering parts and stuff :p ill see if the short fix leaves me wanting more from the pedal still (it's not a stock clutch, and i would bet it requires slightly more pedal pressure than stock).
Old 07-04-2020, 07:58 PM   #55
Spring removal changes one thing. It makes the pedal feel heavier. Raising the gearing on the clutch makes the pedal feel heavier because it shortens the engagement arc.
Old 07-04-2020, 08:22 PM   #56
dagle
right, i'm hoping with the spring removal and adjusting the pedal slightly shorter it'll feel more familiar to me. i'm sure it's not heavy enough to bother me compared to my twin disc or custom pressure plate with 3/8" TOB fingers lol. if im still not happy with it, i'll order the CMC and spend some time following your diy guide. (thanks for that btw!)
Improve throttle response ChrisD BRZ First-Gen (2012+) — General Topics 80 10-05-2020 07:50 PM
OFT v4.03 throttle response Tristor Software Tuning 29 09-22-2019 04:51 PM
OFT throttle response MyGT86Yas Software Tuning 6 02-26-2018 05:44 AM
Does the throttle response improve? pr086 Scion FR-S / Toyota 86 GT86 General Forum 36 12-01-2012 01:06 PM
How's the throttle response? SFTiofoso Scion FR-S / Toyota 86 GT86 General Forum 9 08-14-2012 11:50 AM
