| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
Drives: 2022' GR86 Premium 6MT
My plugs are wet =(
Hi all, wondering if any of you have had any issues with your spark plug tube seals?
Just got my plugs done by the guys over at ptuning here in Virginia. Tech noted that there was traces of oil in the spark plug wells, and clearly my old plugs have oil on them. Having a hard time finding the OEM Parts online, also wondering the severity of this sort of thing and how I should go about it. Plan on taking the car back within the next 5k miles or so but still a bit paranoid.
22' Toyota GR86 - Trueno Blue - M/T (CURRENT)
18' Toyota 86 GT Black - Moonslate Gray - M/T (SOLD) 13' Scion FRS - Ultramarine - A/T (SOLD) |
#2 |
Rust bucket enthusiast
Which plugs? Was it oil, or excess fuel? Was it on the tip, or on the threads, or just in the plug wells? The cause aside, wet plug tips are going to damn you. You will start losing performance, and eventually start having misfires as the plug will fail to spark at all when it's too soaked.
You'll need to prioritize fixing this regardless; if oil is going anywhere it's not supposed to, it becomes a fire hazard to some degree, especially on the passenger side on the engine. |
| The Following User Says Thank You to DarkPira7e For This Useful Post: | VoltsFRS2013 (06-30-2020) |
#3 | |
Each spark plug had a tiny bit of oil on the threads. Tech mentioned it to the service writer to advise me to do them sometime. Obviously I have no way of knowing how long the oil has been trickling into the spark plug tubes, however I have had these plugs pictured in the car for 73,xxx miles. New ones went in today, doing a follow up in a few weeks to get these gaskets switched out.
#4 | |
| The Following 3 Users Say Thank You to DarkPira7e For This Useful Post: |
#5 | |
As I said, the tech said no VC leak just tube seals and said with the condition he saw it in I'm totally good for another 10-20k if I keep an eye on my oil. I always change my oil every 3500-4000 miles or 2-3 months, whatever comes first. (Just did an oil change today with Eneos 0w-20 and Subaru Black filter after I got the new plugs in) That's also the weird part, I never burn oil. I would expect to be burning some sort of oil but I don't. The main reason why i posted was to see if anyone else had any issues haha. ![]()
| The Following User Says Thank You to VoltsFRS2013 For This Useful Post: | DarkPira7e (06-30-2020) |
#6 |
What @DarkPira7e said.
About burning oil, no more oil that can work its way down the plug threads, you wouldn't notice it as "burning". If you have a minor external leak, it may take about 200,000 miles of driving to leak out a quart. |
| The Following 2 Users Say Thank You to humfrz For This Useful Post: | alphasaur (06-30-2020), VoltsFRS2013 (06-30-2020) |
#7 |
The Dictater
Drives: '13 Red Scion FRS
| The Following 2 Users Say Thank You to Spuds For This Useful Post: | soundman98 (06-30-2020), VoltsFRS2013 (06-30-2020) |
#8 |
Drives: brz
anti seize??
#9 |
The plug tips look great. Clean the tubes clean the boots clean around the heads.. look at them in 1k and see where the oil is. In the tube around the boot???
| The Following User Says Thank You to ls1ac For This Useful Post: | VoltsFRS2013 (06-30-2020) |
#10 |
Drives: 2005 Toyota Camry
damnit the clickbait title made me come in here... wait, sorry, wrong thread.
| The Following 6 Users Say Thank You to mav1178 For This Useful Post: | alphasaur (06-30-2020), JonAvalon (06-30-2020), soundman98 (07-01-2020), Spuds (06-30-2020), tehShirt (07-01-2020), VoltsFRS2013 (06-30-2020) |
#11 | |
Mekanik lvl 99
#12 |
10-4. Will do! Car will be going back to the shop soon anyways. I’m going to watch my oil levels.
#13 |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
The oil and hydrocarbon deposits are on the inside of the crush washer on the plug.
There's always going to be particles forced up the threads by explosions in the cylinder. The tip is burning clean. As long as the crush washer is performing and there's no oil on the outside of the plug or the igniter coil, you'll be fine.
"I gotta rock." -- Charley Brown |
| The Following User Says Thank You to bcj For This Useful Post: | VoltsFRS2013 (07-01-2020) |
#14 | |
I check my oil pretty regularly and never notice any variance. Bought the seals today, going to get it done sometime in the next month or so most likely.
| spark plugs | Legend@wheels | Engine, Exhaust, Transmission | 3 | 12-12-2018 12:13 AM |
| FR-S freeze plugs | Jeshbud | Engine, Exhaust, Transmission | 40 | 10-25-2018 11:09 PM |
| PLUGS? | Im_SPEED | Forced Induction | 5 | 09-03-2016 07:44 PM |
| Help! From check engine light to fouled plugs back to check engine + plugs refouling | larchamb | Issues | Warranty | Recalls / TSB | 44 | 04-03-2016 09:39 AM |
| Where do these plugs go from? | Z3D | BRZ First-Gen (2012+) — General Topics | 10 | 02-18-2013 10:59 AM |
