Old 06-22-2020, 07:49 AM   #1
djezlee
Drives: 2017 BRZ Limited
Upside Down Airlift Airtank
Guys... I purposely and admittedly mounted my air tank upside down and attached it to the rear deck for aesthetics... the question is, how do I drain it now without removing the whole tank? Or are there better air tanks available with a 1/4" drain hole on the other side?
djezlee is offline   Reply With Quote
Old 06-22-2020, 09:55 PM   #2
soundman98
ProCrastinationConsultant
soundman98's Avatar
if you flip the car over, the tank will be the right direction
Old 06-23-2020, 06:37 AM   #3
Drill a hole then shove a screw with a rubber washer in it.
Old 06-23-2020, 06:51 AM   #4
thomasmryan
thomasmryan's Avatar
Drives: hyper blue
put a tube on the drain that extends to within 1mm of the bottom of the tank. limebug and other sell a self venting dryer with a metal housing that installs between the pump and tank. that gets rid of most of the condensate.
thomasmryan is offline   Reply With Quote
Old 06-30-2020, 02:00 AM   #5
djezlee
lol
Old 06-30-2020, 02:01 AM   #6
djezlee
seriously?! or are you messing with me?
Old 06-30-2020, 02:07 AM   #7
djezlee
Is this the dryer you were referring to? https://www.limebug.com/product/view...to-14-ptc#temp
Old 06-30-2020, 07:08 AM   #8
thomasmryan
Drives: hyper blue
yes.
but eventually you will still need some method to drain the tank.
Old 07-04-2020, 05:53 PM   #9
Grady
Grady's Avatar
Don't worry about it! the tank will self drain the water out once it rusts a hole in the bottom.
air bags, air tank, airlift, airlift performance
Airlift 3p kit J_Nasty Brakes, Suspension, Chassis 1 05-31-2019 03:24 PM
Boneheaded move. Installed RCE rear yellows upside down Last Lemming Alive Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 06-25-2018 01:48 PM
Help: Rydeen Duo backup cam image upside down o PNA Electronics | Audio | NAV | Infotainment 4 03-10-2017 11:38 PM
Upside down: Oil on road + wet = game over :( softgrip BRZ First-Gen (2012+) — General Topics 36 09-02-2016 09:19 PM
Images uploaded into garage are flipped upside down AllDayJonRay Site Announcements / Questions / Issues 6 04-17-2014 05:34 PM
