Upside Down Airlift Airtank
Guys... I purposely and admittedly mounted my air tank upside down and attached it to the rear deck for aesthetics... the question is, how do I drain it now without removing the whole tank? :bonk::bonk::bonk: Or are there better air tanks available with a 1/4" drain hole on the other side?:iono:
if you flip the car over, the tank will be the right direction
Drill a hole then shove a screw with a rubber washer in it.
put a tube on the drain that extends to within 1mm of the bottom of the tank. limebug and other sell a self venting dryer with a metal housing that installs between the pump and tank. that gets rid of most of the condensate.
yes.
but eventually you will still need some method to drain the tank. |
Don't worry about it! the tank will self drain the water out once it rusts a hole in the bottom.
| All times are GMT -4. The time now is 07:58 PM. |
User Alert System provided by
