Drives: WRB 2017 BRZ Limited w/ PP
Boneheaded move. Installed RCE rear yellows upside down
So I just finished installing RCE yellows tonight. Test drive went great. However just on a hunch I looked at the rear springs and noticed the text on the springs is upside down. Does the rear spring direction matter?
Drives: 2015 FR-S
#3 | |
humfrz |
Yes there’s writing on the spring that should be right side up. RCE has “dead springs” at the bottom of the spring itself.
Think about it like the old Jeep meme only in reverse
| The Following 5 Users Say Thank You to Tcoat For This Useful Post: | churchx (06-24-2018), lantsalot (06-25-2018), Shark_Bait88 (06-25-2018), Spuds (06-23-2018), TachyonBomb (06-24-2018) |
#6 | |
My last question is this springs are a symmetrical, meaning the left one when looking from above us exactly like the right one - they’re not mirror images so which way do I rotate the assembly? Do I keep them both pointed the same direction so the lower pigtails point the same way or do I turn one 180 grease out. Or does it even matter. |
#7 | |
That’s weird your springs don’t say L or R on them, if they both look identical I don’t think it matters which side they go on. |
5mm? I guess that makes sense, allows them to move I guess and not bind. It didn’t say that in the instructions; and I’ve never done that on any other set of springs I have installed before; oh well I guess I’ll have to see if there are any issues in my the future since it’s all installed and online now.
#9 | |
https://www.ft86club.com/forums/showthread.php?t=116218 |
#10 |
Drives: Legacy GT
As long as they fit into the spring perches properly it doesn't matter. But I feel like it might not be in the lower perch on the strut quite right?
#12 |
Drives: 2014 GT86
I guess for ones not reading instructions it simpler is to lessen misinstallation cases with something clear to see, like stickers on springs with arrows pointing up, for installation direction
#13 |
Post installation:
No noises. Sharper transients in steering. Ride just a tad stiffer than stock. Alignment shop could get everything to spec but rear camber. Only 1/2 a degree more camber than stock, so no biggie. Drop doesn’t “look” dropped, but like it should have come from the factory. Just what I wanted. |
| The Following 2 Users Say Thank You to Last Lemming Alive For This Useful Post: | norcalpb (06-25-2018), Racecomp Engineering (06-27-2018) |
| Move stock front calipers to rear? | canyons | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 11 | 07-11-2016 02:50 PM |
| RCE yellows, stock dampers - springs move | Qadthane | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 8 | 04-20-2016 02:04 PM |
| RCE Yellows, WRX Rear Sway bar, trunk jack | Keenercarguy | Want-To-Buy Requests | 2 | 10-31-2015 04:14 PM |
| Feeler: RCE Yellows + Koni Yellows *PRE-ASSEMBLED* | raul | Brakes, Suspension, Chassis | 0 | 08-09-2013 03:22 PM |
| RCE Yellows + Koni Yellows + Whiteline Camber Adjustment Bushings | raul | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 15 | 05-24-2013 08:33 AM |
