Old 07-23-2012, 10:33 PM   #15
whataboutbob
AutoX-10/10ths every run
I like the look lowered. Hope you find a good solution to the camber issues.
Old 07-23-2012, 10:35 PM   #16
jamal
jamal's Avatar
Drives: Legacy GT
There are three options
1. raise the car because it's too low
2. get whiteline bushings (you might also need the adjustable toe link)
3. get cusco lower arms (you might still also need the whiteline toe link)
jamal is offline   Reply With Quote
Old 07-23-2012, 10:40 PM   #17
fatoni
Originally Posted by project.sth View Post
Uh? Yeah I think I know all of that. I'm a car mecanic. It mess up the camber and the toe... I was asking if anyone notice the same negative camber reaction to take my choise on ordering parts or lift it up before I'll go to the alignment.
I was hoping for some referance from other people that it's.
Anyway, the FR-S don't have rear camber adjusment ( check the shop manual, it really don't have ) and if someone have already buy the Cusco lower arm I would really know how many degres it can correct.
google camber bolt. i have never heard of a car in history that used a double wishbone and didnt have camber bolts. with the multilink, you should have more adjustability than you do than the fronts
Old 07-23-2012, 10:51 PM   #18
Juanito08
Juanito08's Avatar
Drives: Scion Fr-s
How does the car ride on these coils? Please let me know, thinking about getting them
Juanito08 is offline   Reply With Quote
Old 07-23-2012, 10:51 PM   #19
Stav
Stav's Avatar
Drives: 13' FR-S Argento,74' Alfa GTV
Hi project.sth,
Yes the rear has no factory camber, it is the same as a GRB WRX/STi rear suspension so much so that the Cusco part number is exactlly the same part to fit the GRB/FRS/BRZ to correct your camber issue.
It will easily correct the -2.5 degrees of camber and give you a nicer piece and looks much better especially from the rear.
I am installing the KW V3's this coming Friday as well as the rear camber correction from Cusco or Whiteline.
We are in Mississauga and are the master warehouse for most major suspension companies. We keep the Cusco and Whiteline products in stock in our Mississauga location so that you don't have to deal with the border and all its brokerage and taxes. We ship all over Canada next day UPS so if your ready for it give me a call or pm.
Thank you
Stav is offline   Reply With Quote
Old 07-23-2012, 10:56 PM   #20
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
Originally Posted by Stav View Post
Hi project.sth,
Thank you
I will add you to my contact list if you dont mind and will soon get parts ftom you im sure for ease over border bullshit and especially for someone having stock and not dropshipping
Silverdub is offline   Reply With Quote
Old 07-23-2012, 11:01 PM   #21
Stav
Stav's Avatar
yes sir, already accepted. The nice part when we ship to PQ there is only GST not QST..... so only 7% tax.
Old 07-23-2012, 11:26 PM   #22
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
Rear Camber kit...http://ft86speedfactory.com/index.ph...roducts_id=215
Will pull +/- .75 camber. Bring you back to a -1.25 give or take a bit which is much more manageable. You could always raise it up a bit as well. Looks a bit too low. Holler with any questions.
FT-86 SpeedFactory is offline   Reply With Quote
Old 07-24-2012, 01:13 AM   #23
86design
Attack By Demons
86design's Avatar
Drives: 2022 BRZ (pre ordered)
could you take a pic from the back ?
whiteline sells camber kit for the rear!!!
#attackbydemons #imcomingbackbish
86design is offline   Reply With Quote
Old 07-24-2012, 06:44 AM   #24
trueno86power
[||•]=(86)=[•||]
trueno86power's Avatar
Drives: 2017 Toyota 86
Hi project.sth,
Thank you
Ahhhh finally answer! I'll pm you.
Really close as stock if you don't put the damper too high. For now I run 15 front and back and it's just a little bit stiffer but that it's.
trueno86power
GR | TOM'S | TRD
2017 Toyota 86
trueno86power is offline   Reply With Quote
The Following User Says Thank You to trueno86power For This Useful Post:
Juanito08 (07-24-2012)
Old 07-24-2012, 08:23 AM   #25
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
I'm in the same boat. I got my car aligned though so its only the rear wheels that have crazy camber (-2.3*). $500+ is a bit much IMO for a camber adjustment, and the Whiteline bolts don't adjust enough for my liking.
Sent from my Nexus S using Tapatalk 2
Parting out HERE
civicdrivr is offline   Reply With Quote
Old 07-24-2012, 09:33 AM   #26
trueno86power
[||•]=(86)=[•||]
Thanks a lot for the result of rear camber. -2.3 don't bother me that much as I will track it. How you lowered as me?
trueno86power
GR | TOM'S | TRD
2017 Toyota 86
Old 07-24-2012, 09:58 AM   #27
Synack
Boosted
Synack's Avatar
Drives: Sideways
Does anyone know the stock camber for front and rear? I'll likely be lowering mine 1.5" and won't even need a camber adjustment. I like the way it sits with negative camber and I drift so it will need it as well.
Sent from my Galaxy Nexus
Nismo 370Z 300whp -> FR-S Turbo 450whp on E85 -> Z06 Corvette 500whp
Synack is offline   Reply With Quote
Old 07-24-2012, 04:06 PM   #28
Touge Factory
Touge Factory's Avatar
Drives: ZN6
Send a message via AIM to Touge Factory
Stock camber up front was near 0 degrees, which isn't the best for MacPherson style suspension. We'd recommend adding camber up front for better performance.
Eccentric bolts will be able to assist with dialing out some camber, but will not dial out -2.5 degrees.
Depending on the aggressiveness of the eccentric bolt, you might be able adjust .5 to 2 degrees of camber, however we'd recommend installing adjustable camber arms with high quality bearings.
Touge Factory is offline   Reply With Quote
RS*R Sports-i Coilover system installed (pics) R0ME0 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 139 02-05-2015 03:38 PM
Camber plates Captain Snooze AUSTRALIA 7 07-02-2012 06:51 PM
Camber arms? skoodge Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 06-24-2012 10:09 PM
Excessive negative camber? MTeator Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 06-22-2012 10:30 AM
Drove the 86GT and NC miata back to back on GT5 Hanzo FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 39 01-07-2012 12:56 PM
