Old 07-23-2012, 07:08 PM   #1
trueno86power
[||•]=(86)=[•||]
trueno86power's Avatar
Drives: 2017 Toyota 86
Installed coilover; Too much camber in the back.
So this weekend I've installed my BC Coilovers. The only complain I have is I've got a lot of unwanted negative camber. I've lowered my car app. 2.5"
Since we can't ajust the rear camber OEM on our car I want to know if with the same or other suspension setup you got the same problem. Pictures are welcome.
So my wheels are 17X8 +38 on OEM tire.
The option could be the Cusco rear control arm but theirs is no spec of how much degre we can correct camber... I just don't want to spend 500$ and still have the same problem.
trueno86power
GR | TOM'S | TRD
2017 Toyota 86
trueno86power is offline   Reply With Quote
Old 07-23-2012, 07:32 PM   #2
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
Just get them and let me know....
Silverdub is offline   Reply With Quote
Old 07-23-2012, 07:35 PM   #3
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
I would think camber bolts would be able to adjust this enough
fatoni (07-23-2012)
Old 07-23-2012, 07:44 PM   #4
empower-auto
Kouki-Monster
empower-auto's Avatar
Did you just drop it and not get an alignment?
Rich Anderson
EMPOWER AUTO
empower-auto is offline   Reply With Quote
Old 07-23-2012, 08:03 PM   #5
trueno86power
[||•]=(86)=[•||]
Yup. But theirs is no rear camber adjustment OEM on this car. That's why I'm asking before I'll align it.
trueno86power
GR | TOM'S | TRD
2017 Toyota 86
Old 07-23-2012, 10:00 PM   #6
uspspro
Drives: DGM BRZ, MR-S 3.5L V6 swap (sold)
Whiteline makes a kit
uspspro is offline   Reply With Quote
Old 07-23-2012, 10:04 PM   #7
empower-auto
Kouki-Monster
I find it VERY hard to believe that there is none. I don't think that's even legal.
Also .. you messed up. Lowering doesn't only affect camber.
You should always align a car after changing the ride height. (Unless you hate tires and handling)
Rich Anderson
EMPOWER AUTO
Old 07-23-2012, 10:13 PM   #8
fatoni
yes there is. if anything there would be no oem adjustment on the front
Old 07-23-2012, 10:14 PM   #9
xwd
The BRZ/FR-S has NO way to adjust camber either front or rear stock. Yes it sounds awfully odd and it is, but it's the truth. The 2008-2012 Impreza with the same rear suspension setup also has no way to adjust camber in stock form. The way the multi-link suspension in the rear is setup, lowering the car will drastically change camber but like you said it effects other things as well. I've seen instances where on a GR STi lowering a car 1" gains almost 1 degree of camber...
I would say get some camber plates if you can or the whiteline/cusco/etc. parts which allow you to adjust camber elsewhere in the rear suspension. Maybe raise the car up until you can get the proper parts to align the car.
edit: I should say there is a crash bolt provision in the manual to adjust front camber, but it's just a straight shank bolt which is smaller than the upper strut hole, so you just adjust it freely and tighten it down. That's the only way to adjust camber.
Old 07-23-2012, 10:18 PM   #10
fatoni
how exactly are camber plates going to help a multilink? i dont get that at all
Old 07-23-2012, 10:19 PM   #11
Nitro22
Nitro22's Avatar
Drives: Scion FR-S (Hot Lava)
How much negative camber do you have?
Nitro22 is offline   Reply With Quote
Old 07-23-2012, 10:22 PM   #12
xwd
My bad, thinking too much back to the old impreza mcstrut on all four corners days. The easiest way is with the whiteline kit.
Old 07-23-2012, 10:25 PM   #13
trueno86power
[||•]=(86)=[•||]
Uh? Yeah I think I know all of that. I'm a car mecanic. It mess up the camber and the toe... I was asking if anyone notice the same negative camber reaction to take my choise on ordering parts or lift it up before I'll go to the alignment.
I was hoping for some referance from other people that it's.
Anyway, the FR-S don't have rear camber adjusment ( check the shop manual, it really don't have ) and if someone have already buy the Cusco lower arm I would really know how many degres it can correct.
trueno86power
GR | TOM'S | TRD
2017 Toyota 86
Old 07-23-2012, 10:27 PM   #14
trueno86power
[||•]=(86)=[•||]
I'll say close to -2.5 as you can see in the picture.
trueno86power
GR | TOM'S | TRD
2017 Toyota 86
RS*R Sports-i Coilover system installed (pics) R0ME0 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 139 02-05-2015 03:38 PM
Camber plates Captain Snooze AUSTRALIA 7 07-02-2012 06:51 PM
Camber arms? skoodge Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 06-24-2012 10:09 PM
Excessive negative camber? MTeator Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 06-22-2012 10:30 AM
Drove the 86GT and NC miata back to back on GT5 Hanzo FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 39 01-07-2012 12:56 PM
