Old 06-18-2020, 07:53 PM   #1
zero_limits
Drives: Subaru BRZ 2017 PP
Do I need aftermarket bolts to install an uel header?
Hi,
I just bought a used uel ft86 catted header, along with a pair of new grimspeed gaskets.
I currently have the stock overpipe, will I need any additional hardware such as additional/different bolts to mount the new header? or can I reuse the original bolts that connect the header to the overpipe when installing the new header?
Thank you!
zero_limits is offline   Reply With Quote
Old 06-18-2020, 07:55 PM   #2
Howaitoguru
Howaitoguru's Avatar
Drives: 2016 Subaru BRZ
Originally Posted by zero_limits View Post
Hi,
Thank you!
I would just go ahead and go to fastenal and get some new ones if I were you. You don’t have to but why not.
Howaitoguru is offline   Reply With Quote
Old 06-18-2020, 07:56 PM   #3
Ashikabi
Ashikabi's Avatar
Hi,
Thank you!
You'll need new bolts
Sent from my ONEPLUS A5010 using Tapatalk
Old 06-18-2020, 08:12 PM   #4
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
You don’t. I’ve had my header off 3 times and still on stock nuts. Just make sure they’re not chewed up and the thread is smooth and clean.
The Following User Says Thank You to Yoshoobaroo For This Useful Post:
humfrz (06-18-2020)
Old 06-18-2020, 08:13 PM   #5
86MLR
86MLR's Avatar
I used the same OEM nuts and swapped out the header about 5 times.
Last time also had a turbo manifold hanging off it.
If you use a torque wrench and tighten the nuts up properly you wont need new ones.
The Following User Says Thank You to 86MLR For This Useful Post:
humfrz (06-18-2020)
what are these 2 bolts I got in my ace header box? Breadman DIY (Do-It-Yourself) Guides 6 05-21-2018 12:23 PM
OEM exhaust manifold gaskets ok for aftermarket header install? giorgi0424 Engine, Exhaust, Transmission 3 02-22-2017 11:43 AM
Who has Open Flash Header (or aftermarket UEL header) in the GTA with stock exhaust? alanhung85 CANADA 6 10-21-2014 11:41 PM
Gutted cat stock header vs aftermarket catless header NA application stevo585 Engine, Exhaust, Transmission 8 04-04-2014 05:12 PM
Aftermarket camber bolts safe? was385 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 04-19-2013 12:30 PM
