Old 10-13-2017, 02:53 AM   #15
Sonnyman
Drives: 2015 FR-S Release Series 1.0
Sorry for bringing this back from the dead, but yea wish I could see the pictures too. Need this fix in my life, just wanna confirm by the pictures.
Sonnyman is offline   Reply With Quote
Old 10-13-2017, 10:37 AM   #16
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
Could also buy the Raceseng reverse lockout, or any aftermarket lockout that has the extra o-ring inside it. Dampens the vibrations.
I had a cheap aftermarket aluminum lockout before and the rattle drove me nuts at certain RPMs, changing to oa Raceseng one helped.
Old 10-19-2017, 03:20 AM   #17
MaXimus
Meh!
MaXimus's Avatar
Drives: Satin White, 86, Manual
+1
RAYS TE37V 17X9 / MICHELIN 245/40/R17 / KW V3 / RACESENG TOP HATS / MOTUL 5.1 + BRAIDED LINES / FERODO DS2500 BRAKE PADS / NEXUS 7 IN DASH / VDS UEL HEADERS / CRAWFORD POWER BLOCKS/ K&N DROP IN FILTER / Custom 3 inch header back catless exhaust / Varex 3in Muffler / HT AUTO LIP KIT / VALENTI TAIL LIGHTS / MORIMOTO PROJECTOR + HID.
MaXimus is offline   Reply With Quote
Old 10-19-2017, 02:30 PM   #18
fanuel fierros
Drives: 2013 scion frs
heres what i did... i used Allen key to remove screw and pulled out the spring inside with a thin screw driver (i had already grease spring previous to pic). i greased the shit out of it with wheel bearing grease the super thick kind. the first time i pullout spring it was completely dry.
also note that when you grease the spring and thread the screw back in place grease will come out of the holes where the lock out attaches to the shifter when you pull up on the reverse lock out. i just kept pulling up on the lockout until no grease came out.
in my opinion its 1000 times better i mean there is still some noise at like 7k but i can live with it. hope this helps guys!
fanuel fierros is offline   Reply With Quote
The Following 4 Users Say Thank You to fanuel fierros For This Useful Post:
MJones_RB (06-26-2020), PerCompLLC (04-06-2023), Prodigalson (04-19-2019), SuperTom (05-19-2018)
Old 06-02-2020, 11:02 PM   #19
nico_rsx
Drives: BRZ 2017 Pure Red, MT
@fanuel fierros
Is this the OEM shifter?
nico_rsx is offline   Reply With Quote
Old 06-14-2020, 01:54 PM   #20
gpvecchi
gpvecchi's Avatar
Sorry to re-up, my STi short shifter rattle definetly comes from the spring. I tried to follow the instructions, but it seems that I dont have the allen key on top.
Anyone has the same shifter and issue and managed to fix it?
Old 06-15-2020, 10:37 AM   #21
tehShirt
tehShirt's Avatar
Drives: 2014 Subaru Forester
If you remove the reverse lockout from the OEM/STI shifter, there is a cable inside that you can grease. Mine was rattling from there, as well as from the washer/pin on the bottom linkage.
tehShirt is offline   Reply With Quote
Old 06-15-2020, 05:42 PM   #22
gpvecchi
gpvecchi's Avatar
So, no spring in the STi short shifter? Mine definetly rattles from the internal of the reverse lockuot. Keep it firm, gently put lever under tension doesn't anything, I just have to keep reverse lockout lifted to stop rattle.
No other way to lubricate it?
Old 06-16-2020, 01:40 PM   #23
tehShirt
tehShirt's Avatar
If you remove the reverse lockout, and these plastic pieces, you can grease the cable area underneath. I had the same "lift to eliminate rattle" issue as you and this fixed it.
Old 06-16-2020, 05:55 PM   #24
gpvecchi
gpvecchi's Avatar
You mean to put grese into those two slots?
Old 06-17-2020, 12:27 PM   #25
tehShirt
tehShirt's Avatar
If you remove the two white pieces, you can see the reverse lockout cable. You can put grease around the cable to stop the rattling.
The Following 3 Users Say Thank You to tehShirt For This Useful Post:
gpvecchi (06-17-2020), MJones_RB (06-26-2020), PerCompLLC (04-06-2023)
Beatrush Reverse Lockout Lever simpleisbest Cosmetic Modification (Interior/Exterior/Lighting) 37 04-16-2015 11:19 PM
Shift Knobs and our Reverse Lockout Chewie4299 Cosmetic Modification (Interior/Exterior/Lighting) 19 07-28-2013 01:23 PM
FR_S/BRZ Reverse Lockout Lever brzadrian BRZ First-Gen (2012+) — General Topics 20 06-20-2013 05:07 PM
Reverse lockout vibration SubaSteve Issues | Warranty | Recalls / TSB 4 03-23-2013 02:26 PM
Aftermarket Reverse Lockout Ring Available? was385 Cosmetic Modification (Interior/Exterior/Lighting) 9 02-17-2013 03:28 PM
