06-12-2020, 12:46 PM | #267 | |
Good Job Subaru!
Drives: '17 BRZ, '24 CX-50
JDL 4-2-1 EL header
It’s certainly possible. For reference; here’s my dyno from earlier in the thread. Unfortunately this was only a 7100rpm run but the torque holds on pretty well, with a slight taper past 6750 but not as steep of a fall-off. OnPoint Dyno’s Dynapack reads very similarly to the CSG Dynapack (that is to say, low) based on the numbers I’ve seen from both.
06-16-2020, 08:39 AM | #268 | |||
Drives: '14 FRS TT5
And yes, I'm still on the same exhaust setup (JDL 4-2-1 EL header, JDL overpipe, JDL catless frontpipe w/ single resonator, Tanabe Concept G catback). Might need to follow up with my tuner on that. Quote:
OEM brakes, Carbotech XP12 pads in the front, XP8 in the rear. I don't see a reason to upgrade brakes on this car other than reducing consumables. I am on Hoosier R7's as well, so that helps too
Follow my NASA TT5 build here: JHill Motorsports
The Following User Says Thank You to TMF For This Useful Post: | Code Monkey (06-16-2020) |
06-16-2020, 08:42 AM | #269 | |
Drives: '14 FRS TT5
Still curious what is going on with the E85 graph though.
06-16-2020, 10:06 AM | #270 | |
Good Job Subaru!
I'd be curious as well, the torque fall off is earlier than normal and quite significant.
10-13-2020, 01:31 PM | #271 | |
Drives: 2013 Scion FRS
Nice torque curve! I'm assuming that is the 93 dyno. I'm thinking with these headers I can get to ~190whp avg. with e85. This would give me more WHP for competition and not need to run a wing (I'm not sure which way would be faster, but I've read a lot saying > HP is better than the aero in these classes). |
10-13-2020, 10:17 PM | #272 | |
Drives: '14 FRS TT5
10-13-2020, 11:27 PM | #273 |
Ah, thanks. So similar to all the other headers on the market. The torque curve is still good, though. It sounds like there's really not any headers that can do ~180whp avg. on 91/93 with NASA corrections (maybe ace but doubtful).
10-14-2020, 12:58 AM | #274 |
Drives: JRSC BRZ SOLD
949 Racing ran the Ace 350 and the JDL 4-2-1, but stuck with the JDL because it had a similar power band to ACE with less drop off at 7000+.
The Following User Says Thank You to PulsarBeeerz For This Useful Post: | Hades (10-14-2020) |
10-14-2020, 03:33 PM | #276 |
Drives: AP2 S2000, 91 Miata 1.8L Rotrex 5MT
Let's say they spent a lot more time tuning the ACE and got it within the margin of error of the JDL, is there any reason to buy the now way more expensive ACE350 over the JDL 4-2-1?
This is a genuine question, because between the higher price, the near requirement of buying motor mounts, and the need for some clearancing, it doesn’t make too much sense to me.
2022 Hyundai Elantra N 6MT SCCA TT S3//Will be back in an 86 eventually
10-14-2020, 04:22 PM | #277 | |
Many folks will spend the difference on the JDL 4-2-1 and call it a day, and still have fantastic results. I believe 949 already had a pre-existing relationship with JDL (JDL makes fantastic Miata headers as well), and used the Ace as a stop-gap until their 4-2-1 arrived. CSG has both the JDL 4-2-1 and Ace in their catalog, and *tries* to stock both, but both are almost always backordered. |
10-14-2020, 04:33 PM | #278 | |
So I wouldn't be doing my due diligence without asking for proof of that claim. I remember a JDL 4-1 vs 350 dyno and confusion of a JDL UEL as a 4-2-1 dyno. Still hoping to see a comparison of the JDL vs ACE. Not trying to press you or anything but as neither header is what this community would consider inexpensive at $1400-2K gotta know all the info. lol Last edited by PulsarBeeerz; 10-14-2020 at 04:44 PM. |
The Following User Says Thank You to PulsarBeeerz For This Useful Post: | Goingnowherefast (10-14-2020) |
10-14-2020, 04:57 PM | #279 | |
The engineer in me also says we could use some data to substantiate this claims.
10-14-2020, 05:05 PM | #280 |
One day, someone will fund some dyno time and purchase both headers to back to back test on the same dyno!
I would do it the same way i purchasd 5 ace headers for my own testing, but I'm turbo now, and the 4-2-1 came out after i boosted, so it's not really viable for me at the moment. Any volunteers? I bet if someone local purchased both and a tune, CSG may comp the dyno time for the sake of comparison. |
Similar Threads | ||||
JDL UEL header/Nameless header-back exhaust (Atlanta area) | carbon_raven | Engine, Exhaust, Bolt-Ons | 16 | 05-09-2015 02:26 AM |
Who has Open Flash Header (or aftermarket UEL header) in the GTA with stock exhaust? | alanhung85 | CANADA | 6 | 10-21-2014 10:41 PM |
RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP | NickFRS | Engine, Exhaust, Transmission | 44 | 04-19-2014 05:42 PM |
Top Gear Solutions| HKS Header |Borla EL & UEL Headers| Agency Power Header| + MORE! | TopGearSolutions | Engine, Exhaust, Bolt-Ons | 82 | 04-14-2014 08:16 PM |
Gutted cat stock header vs aftermarket catless header NA application | stevo585 | Engine, Exhaust, Transmission | 8 | 04-04-2014 04:12 PM |
