Old 06-09-2020, 02:48 PM   #253
JBezugs
Good Job Subaru!
JBezugs's Avatar
Drives: '18 440i GC, '24 CX-50 Meridian
Gonna bump this up to the top as I see many more people are running this header out in the wild! How are y'all enjoying it? I was planning a local dyno day earlier this year to compare the gains vs a stock vehicle on the same dyno/same day to have more data for everyone, but due to COVID that obviously couldn't happen.
I still wholeheartedly recommend this header if you're looking for an EL option. My car is still sounding and driving awesome.
Hope everyone is staying safe!
JBezugs is offline   Reply With Quote
Old 06-09-2020, 03:39 PM   #254
TMF
TMF's Avatar
Drives: '14 FRS TT5
I don't recall if I posted my dyno numbers after I went to E85, but here are my numbers.
You'll probably say, "these look low!" and "there's no comparison!", which are both accurate statements. But the one constant here is that these dyno runs were conducted in compliance with NASA's dyno testing procedures, which usually read low.
Also, the only sounds you need are at full throttle
Follow my NASA TT5 build here: JHill Motorsports
TMF is offline   Reply With Quote
The Following 7 Users Say Thank You to TMF For This Useful Post:
Cephas (10-14-2020), Hades (10-13-2020), JBezugs (06-09-2020), NoHaveMSG (06-12-2020), Pat (06-09-2020), solidONE (06-09-2020), Tanstin (06-14-2020)
Old 06-09-2020, 04:15 PM   #255
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
That G-spot at 4555rpms
Intent > Content
Old 06-09-2020, 04:21 PM   #256
JBezugs
Good Job Subaru!
JBezugs's Avatar
I also have the same G spot on my dyno run
That’s where vtak kicks in.
The Following User Says Thank You to JBezugs For This Useful Post:
Old 06-09-2020, 04:24 PM   #257
solidONE
solidONE's Avatar
I got a G-Mound, you know what they say about torque curves.. its like shoes size. "motion of the ocean" and things like that. Know what I mean? *wink*
"looking at the torque cure, you packin some long tubes" know what I'm sayn'?
Edit: *crickets*
Intent > Content
Old 06-11-2020, 02:40 AM   #258
jflogerzi
jflogerzi's Avatar
Just do it. Beside the ace350's these are fantastic headers. Love them with my boosted twin. And they are cheaper to boot than the ace headers
2013 Series 10 FRS #553
Old 06-11-2020, 09:04 AM   #259
Code Monkey
Drives: Subaru BRZ
Nevermind the numbers, with ACE headers peak hp is usually around 7,400 rpm and the tq stays flat until around 7,000 rpm (my dyno sheet). Can JDL achieve that, or are you limited by class rules and had to detune at higher rpms?
Code Monkey is offline   Reply With Quote
The Following User Says Thank You to Code Monkey For This Useful Post:
solidONE (06-11-2020)
Old 06-11-2020, 11:18 PM   #260
solidONE
solidONE's Avatar
I think after 6.5k the cat back plays in a bit more. Can it maintain the torque a at higher RPM with an open exhaust? I would think the 949 guys would know, but I dont think they dyno or tuned to "max out" the output on a dyno graph. Same G-spot peak. Cam timing similar?
Intent > Content
The Following User Says Thank You to solidONE For This Useful Post:
Code Monkey (06-12-2020)
Old 06-12-2020, 07:39 AM   #261
Code Monkey
Drives: Subaru BRZ
@TMF, are you still on this exhaust? My tune is a road racing tune as well.
zberz (06-14-2020)
Old 06-12-2020, 11:01 AM   #262
jflogerzi
jflogerzi's Avatar
Here is my Dyno pull with Zach at csg
https://www.instagram.com/p/B8sJ1XDn...d=ty42p88y5tfo
https://www.instagram.com/p/B8sOU-0n...d=klqnb0pf9upg
Sprintex 210 +69mm pulley IC, flex fuel
JDL 4-2-1, stock op/fp with extra ultra vibrant resonator and mxp sp exhaust
Old 06-12-2020, 11:25 AM   #263
Celica00
Celica00's Avatar
Drives: 86
Jeez @TMF when you went into that turn going 125MPH, I just about had a heart attack vicariously. What brakes are you using?
Celica00 is offline   Reply With Quote
Old 06-12-2020, 11:47 AM   #264
solidONE
solidONE's Avatar
IT is odd that the torqu tapers off sharply on that dyno. Maybe timing is being pulled at 6400rpms.
Intent > Content
Old 06-12-2020, 12:46 PM   #265
JBezugs
Good Job Subaru!
JBezugs's Avatar
JDL 4-2-1 EL header
It’s certainly possible. For reference; here’s my dyno from earlier in the thread. Unfortunately this was only a 7100rpm run but the torque holds on pretty well, with a slight taper past 6750 but not as steep of a fall-off.
OnPoint Dyno’s Dynapack reads very similarly to the CSG Dynapack (that is to say, low) based on the numbers I’ve seen from both.
Old 06-16-2020, 08:39 AM   #266
TMF
TMF's Avatar
Drives: '14 FRS TT5
Now ya'll have me concerned, I don't know why I didn't see the torque completely falling off on the graph. That was a 5th gear pull, not sure that should make a difference though, although it is a lot of strain on the engine.
And yes, I'm still on the same exhaust setup (JDL 4-2-1 EL header, JDL overpipe, JDL catless frontpipe w/ single resonator, Tanabe Concept G catback).
Might need to follow up with my tuner on that.
Haha yea, that turn is a hair raiser.
OEM brakes, Carbotech XP12 pads in the front, XP8 in the rear. I don't see a reason to upgrade brakes on this car other than reducing consumables. I am on Hoosier R7's as well, so that helps too
The Following User Says Thank You to TMF For This Useful Post:
Code Monkey (06-16-2020)
JDL UEL header/Nameless header-back exhaust (Atlanta area) carbon_raven Engine, Exhaust, Bolt-Ons 16 05-09-2015 02:26 AM
Who has Open Flash Header (or aftermarket UEL header) in the GTA with stock exhaust? alanhung85 CANADA 6 10-21-2014 10:41 PM
RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP NickFRS Engine, Exhaust, Transmission 44 04-19-2014 05:42 PM
Top Gear Solutions| HKS Header |Borla EL & UEL Headers| Agency Power Header| + MORE! TopGearSolutions Engine, Exhaust, Bolt-Ons 82 04-14-2014 08:16 PM
Gutted cat stock header vs aftermarket catless header NA application stevo585 Engine, Exhaust, Transmission 8 04-04-2014 04:12 PM
