Old 06-08-2020, 03:04 AM   #1
Aydrian
Drives: 2015 Black Scion Fr-s
Scratch when accelerating and shifting
I keep having this scratching sound when I press the pedal all the way down suddenly or when I shift at a high rpm I read online if could be the heat shields but I have replaced the headers, over pipe, and front pipe and it’s still doing this any ideas ?
Aydrian is offline   Reply With Quote
Old 06-08-2020, 03:27 AM   #2
I can't sort out that sound you are referring to.
What is the last thing you did to your car before it started making that sound?
I'd suggest you start there.
Old 06-08-2020, 01:35 PM   #3
Aydrian
It’s been doing it for a while since even before I did any modifications but I did my headers last and it hard to catch on video but you can hear it at 4seconds on the video
The Following User Says Thank You to Aydrian For This Useful Post:
humfrz (06-08-2020)
Old 06-08-2020, 01:36 PM   #4
radroach
Drives: car
Lets get this out of the way: That shifter, whew..
The Following 7 Users Say Thank You to radroach For This Useful Post:
alphasaur (06-08-2020), Decep (06-09-2020), Grady (06-09-2020), humfrz (06-08-2020), JD001 (06-08-2020), soundman98 (06-08-2020), Spuds (06-08-2020)
Old 06-08-2020, 01:49 PM   #5
NARFALICIOUS
NARFALICIOUS's Avatar
Drives: 88 Supra 1JZ, 16 FRS, 25 GR Corolla
have you checked if the new over pipe is rubbing?
NARFALICIOUS
Noob Poster
1988 | 2016
NARFALICIOUS is offline   Reply With Quote
The Following User Says Thank You to NARFALICIOUS For This Useful Post:
Aydrian (06-08-2020)
Old 06-08-2020, 04:01 PM   #6
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Can't hear anything. Based on the timing I'm curious if it's the syncro grinding (would not happen if it's just when you press the clutch down suddenly though). For what it's worth, that is not high RPM that you're shifting at. Sounds like about 2700 rpm.
Have you done anything with your transmission/clutch/clutch pedal? Maybe your pedal needs to be adjusted if you've modified this system at all
Old 06-08-2020, 04:04 PM   #7
alphasaur
friendly
Drives: 17' 86
yeah probably the shifter
Seek comfort in discomfort.
alphasaur is offline   Reply With Quote
Old 06-08-2020, 06:12 PM   #8
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Mine has done that since new. It is likely the sound of air quickly entering the intake plenum through an opening throttle. Purse your lips and quickly breath in, makes about the same sound. Don't hyperventilate though...
Old 06-08-2020, 07:59 PM   #9
Aydrian
I haven’t done anything it’s all stock on the transmission but it does it sometimes when I hit the gas all the way down like if the engine moves sudden it’s makes the noise
Old 06-08-2020, 08:29 PM   #10
DarkPira7e
DarkPira7e's Avatar
Could be motor mounts, transmission mounts, diff mounts, or all three. Mine had a lot of drivetrain lash. I haven't driven my car since bolting these in but I got new engine mounts, transmission mount, diff bushings and subframe bushings. I also got a carbon fiber driveshaft.
There are a lot of places to upgrade and spend money on, you'll need to pick your battles
Old 06-08-2020, 11:11 PM   #11
I'm surprised that weapon is legal in Arizona -
Old 06-09-2020, 12:50 AM   #12
Spuds
The Dictater
Spuds's Avatar
That's what she said.
The Following User Says Thank You to Spuds For This Useful Post:
humfrz (06-09-2020)
Old 06-09-2020, 01:12 AM   #13
Ooooooo ....... I think she could handle it -
Old 08-18-2020, 08:12 PM   #14
Aydrian
UPDATE : I've notice it only doesn't do it when the car is cold and it only does it when going into second and third gear anything above that it won't. It does it when I switch gears above 2k rpm.
VVT goes off for 1 second accelerating in 6th tomm.brz Software Tuning 16 10-31-2018 12:44 PM
Not accelerating Fresh31 Issues | Warranty | Recalls / TSB 15 03-17-2018 06:05 PM
Pop noise when accelerating sometimes Jfheisenberg Engine, Exhaust, Transmission 5 10-09-2017 08:39 PM
Please help.. Car not accelerating Joseph Issues | Warranty | Recalls / TSB 9 09-08-2015 12:55 PM
shifting and down shifting feel Lowellrenzo Scion FR-S / Toyota 86 GT86 General Forum 23 07-08-2012 06:09 PM
