Old 06-08-2020, 11:39 AM   #1
pope
has a funny hat
Drives: 2014 BRZ Limited
Identify This Connector
I am almost finished rebuilding a salvage BRZ Limited with front end damage.
The radiator support front cut I purchased from a local yard had some wiring harness scraps attached. This connector was part of the right side bundle that splits to feed the fans, horns, headlight, crash sensor, etc.
My car does not have this connector on it. There are signs that a previous owner made alterations to the wiring harness. There is also crash damage that severed some wiring (different color wires though).
So, I am trying to determine if this connector was:
a. an option my car did not have
b. removed by a previous owner for some reason, or
c. severed by the collision and to a part I didn’t know I need to find
pope is offline   Reply With Quote
Old 06-08-2020, 12:07 PM   #2
Opie
Opie's Avatar
Drives: 2020 GMC Canyon Denali Diesel
Turn Signal/Foglight I'm pretty sure...
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
Opie is offline   Reply With Quote
Old 06-08-2020, 12:35 PM   #3
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Pretty sure you are correct.
Opie (06-08-2020)
Old 06-08-2020, 12:55 PM   #4
I'm not so sure
Signal
Fog
Old 06-08-2020, 12:57 PM   #5
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I'm not so sure
Signal
Fog
All the connectors on my car are grey. Pretty sure OP's picture is the fog.
Old 06-08-2020, 01:01 PM   #6
Found it!
It is fog but not the one that hooks up to the lights
https://onlineparts.toyotasouthatlan...SABEgLTtvD_BwE
NoHaveMSG (06-08-2020), Opie (06-09-2020)
Old 06-08-2020, 02:30 PM   #7
pope
has a funny hat
My car and the front cut both have these three connectors on both sides, I’ve been assuming they are (left to right): Headlight, Foglight, Side Marker. (Lights are on order but haven’t arrived yet).
The front cut had the connector from the original post only on the right side.
Old 06-08-2020, 07:59 PM   #8
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
@pope @Tcoat
That is the front turn signal connector for FRS. That 3-pin end connects to the the bulb holder on the signal itself.
Where the wires are snipped you would find the 4-pin connector, with 4 pinouts being: 1. Turn Signal (blinking), 2. Turn Running (steady, at night), 3. Fog, 4. Ground
See thread for additional pictures: https://www.ft86club.com/forums/showthread.php?t=19169
You can see how to access the fog power via Toyota's instruction manual for FRS Fog Lights: PT413-18130.pdf
EndlessAzure is offline   Reply With Quote
The Following 2 Users Say Thank You to EndlessAzure For This Useful Post:
Opie (06-09-2020), Tcoat (06-08-2020)
Old 06-08-2020, 08:36 PM   #9
Originally Posted by EndlessAzure View Post
@pope @Tcoat
Damnit! I had the wrong end!
Old 06-08-2020, 08:46 PM   #10
pope
has a funny hat
@EndlessAzure Thank you for identifying it.
Thank you to everyone that attempted to identify it.
It sounds like it shouldn’t be relevant to my car, so I won’t worry about it.
Old 06-11-2020, 06:29 PM   #11
pope
has a funny hat
Well. I figured out that the connector isn’t what we thought. It’s the connector for the levelers on the factory headlights.
Just found the wires folded up and taped over in part of the harness on the car. Then I watched a bunch of Youtube headlight videos until I found one that showed the connector. Not sure i’ll go to the trouble of fixing the wiring since I’m not using OEM headlights.
The Following 2 Users Say Thank You to pope For This Useful Post:
EndlessAzure (06-11-2020), NoHaveMSG (06-11-2020)
Old 06-20-2020, 12:56 AM   #12
Suparu
Drives: 2013 BRZ Limited
Yeah I can confirm that. I recently replaced my 2013 BRZ headlights with 2017 BRZ headlights and had to re-pin the turn signals. The turn signals’ wires are in the main connector for the headlights. That pic of the triangular 3-pin connector is for the leveler.
Suparu is offline   Reply With Quote
Whats the name of this connector (3rd brake light connector) Chimera Cosmetic Modification (Interior/Exterior/Lighting) 4 01-10-2017 06:13 PM
Can you identify this bolt? junkyard Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 14 08-29-2016 12:07 PM
Help me identify this part! ATESIX Scion FR-S / Toyota 86 GT86 General Forum 6 07-14-2015 07:50 AM
Can't identify this car Bg8780 Other Vehicles & General Automotive Discussions 23 11-19-2013 04:31 PM
Help me identify this car jimmillion Other Vehicles & General Automotive Discussions 14 09-13-2012 10:09 AM
