Old 05-31-2020, 10:48 PM   #1
mg92p
Drives: Subaru BRZ S 2013
Help preparing for Forced Induction
Hi all,
Just looking for some collective advice for preparation in going with turbocharged forced induction. Have already installed MCA Purple coilovers to fit wider rims and tyres on the car for more grip with the additional power.
What components of the exhaust are necessary to have prior to FI for the best gains? (OP/FP/Catback?)
What are the preferred oil cooling kit brands?
As i plan to run E85 Flex Fuel, what size injectors should i be looking to install?
Is a new fuel pump absolutely necessary?
I am wanting to collect as many of these items as possible prior to tuning the car with the turbo installed, as dyno tunes aren't cheap.
Any constructive advice would be great, Cheers.
mg92p is offline   Reply With Quote
Old 05-31-2020, 11:10 PM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
You should be communicating your goals with your tuner. When I was going to go FI the first thing I did was contact a known local tuner and ask questions.
Old 06-01-2020, 12:19 AM   #3
86TOYO2k17
Drives: 2017 toyota 86
Originally Posted by mg92p View Post
Hi all,
FI + sticky tires = not happy clutch
catless frontpipe, 2.75"-3" catback, but main restriction is the cat.
DIY behind fog light bezel
Depends on WHP, not a bad idea, but really need to ask tuner
same as above
Good idea
Talk to tuner
See red.
Old 06-01-2020, 09:08 AM   #4
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Talk to tuner
Old 06-01-2020, 06:32 PM   #5
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Hi all,
What is this for? DD, track, mix? What are your power expectations/goals?
The best gains, aka the most power, will be straight piping the exhaust system with a catless header.
My preference is the Jackson Racing radiator/oil cooler combo. Plenty of good oil coolers. Some have thermostatic plates or have other features for draining oil or whatever.
ID 1050s are best. 770s are enough for most who don't have built motors, and a pump isn't necessary. I am on E85 @ 12psi with 770s. I got a pump just for insurance.
You will need a clutch upgrade.
Old 06-02-2020, 12:57 PM   #6
MotoX16
MotoX16's Avatar
Drives: 2017 Subaru BRZ
Hi all,
I'm running a 245 ps4s and it'll spin first and a little in second, third up hooks (on dry road). Definitely will need a better clutch though, recommend the verus fork/pivot while youre in there
The more free flowing the better (e.g. catless, 3")
Plenty of options, preferably with a thermostat, located behind the fog light. JR dual cooler is nice too. Also look at a killer b oil pickup since the pan will have to come off for the turbo anyways
ID1050X's are great, depending on power goals something smaller would work fine too. As others have stated, discuss with the person whose tuning your car
Depending on power goals, maybe. Again, talk with tuner
Bigger injectors will require a tune so do that at the same time as turbo tuning
Do lots of research, ask lots of questions. There is plenty of great advice on this forum
See above
2017 Subaru BRZ PP
FBM Turbo Kit: GTX3076R - HRI FlexFuel Tune - 3" Turboback Exhaust - ID1000cc Injectors - Walbro 485 Fuel Pump - FBM Oil Pan - FBM Oil Cooler - Killer B Oil Pickup - FBM Catch Can - FBM Radiator w/Fan Shroud - Clutch Masters FX400 - Verus Clutch Fork/Pivot - IRP Shifter - Cusco Engine/Trans Mounts - RCE Yellow Springs - PS4S 245/40/17
MotoX16 is offline   Reply With Quote
Old 06-02-2020, 01:35 PM   #7
Lantanafrs2
Drives: 2013 frs red
Hi all,
You're looking to buy all those parts yet you're concerned about the price of the tune?
Lantanafrs2 is offline   Reply With Quote
Old 06-02-2020, 03:05 PM   #8
airrick
Drives: TRD R.S. 1.0 FRS
I think youre misunderstanding what he means. Dyno tunes are expensive. And everytime you get a new turbo part ie. BOV, bigger turbo, injectors, you would need a new dyno tune(since he trying to get the most gains).
Concerned about the price of the tune because he wants to do it once, so yea if youre thinking he’s gonna tune multiple times, uhh dang thats some cash i guess.
airrick is offline   Reply With Quote
The Following 2 Users Say Thank You to airrick For This Useful Post:
Fullcoverage (06-06-2020), Griever423 (06-03-2020)
Old 06-02-2020, 08:50 PM   #9
Lantanafrs2
^good point
Old 06-06-2020, 12:01 AM   #10
mg92p
^^ this. What's the point of tuning every time i get a new part. Would rather do it all at once.
Old 06-06-2020, 12:36 AM   #11
86MLR
86MLR's Avatar
What system you using?
Power goals?
Internet power points?
Street only?
Track only?
Street and track?
Do you have a budget for spare or upgraded gearbox if your going to "send it"?
Same for stock engine?
My 2017 86 made 270hpatw, AVO, 2.5" overpipe, stock decatted front pipe, stock cat back, stock airfilter, oil temps were fine with only a Forester heat exchanger.
Clutch didn't slip either.
What you use the car for will determine the additional required parts or upgrades.
Talk to the guy who is going to tune the car, and by that I mean on a dyno, with a tuner who is actually good.
Not all tuners are good, they all say they are though.
Don't skimp out on the tuning, this is the most part of the build, both for power and, more importantly, reliability.
Don't look for a big number, look for a tuner who will get the best out of your car with a safe and reliable tune.
Enjoy
Old 06-06-2020, 03:34 AM   #12
airrick
Yup, if youre dyno tuning all the more, they'll be more expensive since you'll need to schedule an appointment for time for the dyno and all that. I chose a E-tune with a well-known tuner. What really matter is the tuner is good, a dyno will always help with tuning, but if your tuner is actually good, shouldn't be the end of the world.
The Following User Says Thank You to airrick For This Useful Post:
BRZ_88 (06-06-2020)
Old 06-06-2020, 04:03 AM   #13
BRZ_88
Imperator
Drives: Supercharged 2013 BRZ Limited
Hi all,
Prior to supercharging, I did what you're doing and got wide rear wheels and stiffer coils.
I opted for E85, if you want to go that route too you will need a new fuel pump and injectors. Injector size really depends on what turbo/SC kit you're running.
I'm not sure what regulations are like where you are, but catless headers will give you a noticable power (and noise) increase, if that's not an option a hi flow cat will help too but they aren't cheap. After a lot of research I found that catbacks don't really do a lot for the money, I just got an axleback for the sound and weight saving.
Tuning wise I got an Ecutek E tune through FT86. You send your tuner a full list of parts you're installing, then he'll give you a starting tune so you can send him logs and he'll tweak it until it's right.
BRZ_88 is offline   Reply With Quote
Old 06-06-2020, 10:33 AM   #14
DarkPira7e
DarkPira7e's Avatar
E tunes are decent, but the advantage in the dyno tuning is real time safety. If something wasn't working right, the tuner could notice right away. "Oh stop, it shouldn't be hesitating here" or "whoa hold up that afr is way lean" isn't possible when they just send a basemap and say "send it and hopefully you installed everything perfectly"
The Following 2 Users Say Thank You to DarkPira7e For This Useful Post:
airrick (06-06-2020), Tcoat (06-06-2020)
Forced Induction James The Giant Mid-Atlantic 4 03-17-2017 12:00 PM
Most *fun* forced induction bfrank1972 Forced Induction 45 12-22-2016 11:36 AM
Forced induction for ATs? Lokutus Forced Induction 10 02-26-2013 03:42 PM
NOS or Forced Induction? v3rgil AFRICA 1 11-08-2012 07:17 AM
6AT (+) Forced Induction RYU Forced Induction 18 09-09-2012 11:14 PM
