| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#15 |
Drives: Crapcan
@geraldjust likely best chance at answering this.
#16 |
Famous Potatoes
Drives: '15 ultramarine
A piece of black tape on the dash?
| The Following User Says Thank You to Sapphireho For This Useful Post: | Ohio Enthusiast (05-29-2020) |
#17 | |
Drives: GR86 Trueno Edition
Meanwhile, is this (amazon) the OEM one shown on subaru website? Thanks |
#18 | |
Drives: MR2, Sliver BRZ
So when i designed the tracbox was because one of my friends that would go on track and switch out his tires from his street setup to burnables he had the light pop up. which he did not mind but the problem arose that once he put his street ones the light would remain on for a very very long time until the car saw the tires. so i designed is so when he first booted up his car it would reset the TPMS system allowing the car to be able to find the sensors again quicker. so if your never going to run sensors maybe black tape will be your best friend and cheap too. but if you still want it to be functional (if you street your car too) then maybe the box will be for you.
Always looking to tinker with something..
| The Following 4 Users Say Thank You to geraldjust For This Useful Post: |
#19 | |
Drives: 2018 BRZ
![]() Yeah, I guess I'll go with the tape in the dash - I don't need all the other features of the track box (except locking on speed), so can't justify the cost. Thanks a lot for the help! |
#20 | |
ProCrastinationConsultant
and any time any of them fails, it requires bringing the car in for service to pull the wheel, remove the tire, replace the sensor, reinstall the tire, re-balance the tire, and reinstall on the car, and re-program to the car. around me, that's about $150-300 per wheel, plus the cost of the new sensor. it adds up quick to satisfy the demands of a single angry orange light on the dash that can be more easily 'repaired' with a $2 roll of black tape...
| The Following 2 Users Say Thank You to soundman98 For This Useful Post: | churchx (05-31-2020), Ohio Enthusiast (05-30-2020) |
#21 |
Drives: 2014 GT86
I sometimes feel luckied out regarding TPMS with having early EUDM twin not having it at all.
![]() BTW .. instrument cluster cannot be modified itself? As in, so what if light is lit .. if no power comes to led that should show it? Also as there are visual mods for change of dash place .. there might be also ones w/o cutout for TPMS light. |
#22 |
Drives: GR Corolla
I've also read that some wheels are not compatible with TPMS sensors. Can't remember why tho. On both my cars, I just live with the light being on. I regularly check my tire pressure anyway.
#23 | |
#24 |
I agree with you guys that a tape is the cheapest solution. I am just not comfortable to put a tape on a brand new car and not use the function.
#25 |
my sensors 'fell out' when i replaced my tires. they somehow teleported to a ziplock baggie on my spare parts shelf.
it's better to not mess with voodoo like that, and just use the standard rubber valve inserts!
#26 |
Drives: 2018 BRZ
Much ado about nothing - I got my summer tires mounted on my new Enkeis (with the stock wheels relegated to winter duty) and got the TPMS light right away when starting the car. While driving I don't notice the light, even when I glance down to the instrument cluster to check the speed. I'll probably live with it, and if it really bothers my I'll put some tape over it.
| Oil light blinks for 1-2 seconds when coming to a stop/complete stop | kev0 | Engine, Exhaust, Transmission | 27 | 07-09-2019 11:30 PM |
| Any way to turn on an audible chime for the TPMS warning light? | PureRedBRZ17 | Issues | Warranty | Recalls / TSB | 27 | 04-26-2019 12:40 AM |
| NEED HELP!! TPMS light on. with TPMS installed on aftermarket rims+tires | Figo | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 9 | 09-23-2013 08:11 AM |
| TPMS warning light | FRSowner | Scion FR-S / Toyota 86 GT86 General Forum | 6 | 12-30-2012 08:24 PM |
| TPMS warning light **New Info** | sdiver68 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 29 | 10-11-2012 07:25 PM |
