Old 05-26-2020, 09:28 AM   #15
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Originally Posted by gpvecchi View Post
Any options for those who come from 2017+ bi-led setup?
https://www.theretrofitsource.com/scion-frs-morimoto-xb-heads-B-LF470?quantity=1
Expensive, but probably the best optics available for our platform.
The Following User Says Thank You to Yoshoobaroo For This Useful Post:
gpvecchi (05-26-2020)
Old 05-26-2020, 03:51 PM   #16
gpvecchi
gpvecchi's Avatar
Thanks, but I don't like the design...
Old 05-26-2020, 04:25 PM   #17
Yoshoobaroo
TRACKBREAD
It'd be cool if one of the aftermarket parts houses would do a controlled comparison between the different options. Take one headlight each, strap them all to a bench and hook them up to 12V, and take detailed pics of the light patterns with all of them on (at the same time so WB and exposure don't change between shots).
I'd love to see the relative intensity, cutoff, and most importantly the hotspot pattern on a whole lineup (Stock Halogen, Stock HID/LED, VLAND halogen, VLAND HID, OLM, MORIMOTO, etc.)
@FT-86 SpeedFactory maybe? Got some time to kill for a new video for the community?
Old 05-27-2020, 04:06 AM   #18
Sam86
Drives: Toyota 86 GTS
H7 can be used, but the housings are made for D2H, so the H7 bulb doesn't fit well. No OEM DxS bulb will fit because of the bulk to the bulbs and the housing.
Buy a HID kit for D2H with an H7 power adapter and a standard relay kit (not a canbus adapter).
Not at all.
This is running a 6500k bulb. I since have changed to a 5500k, but I doubt there is much difference between my output and the OEM setup.
Here are some bad pictures (iPhone 6). These headlights allow for better output than many OEM HID headlights.
What do you do with the ballast? I have my D2H HID kit with ballast and am still waiting for the VLAND housing to arrive. Doing the install myself and am not sure where people attach the ballasts. Do people just use double side tape? screw it into the side? just leave it hanging?
Was looking around my engine bay and there doesn't seem to be many flat surfaces large enough to attach it to besides on my driver side with that plastic electrical box
Sam86 is offline   Reply With Quote
Old 05-27-2020, 08:21 AM   #19
Yoshoobaroo
TRACKBREAD
I usually tape them to the underside of the headlight housing if there is room. If not I've seen them mounted anywhere near the headlight that doesn't really get wet. the 3M automotive mounting tape works well, but screws are easier to remove.
Sam86 (05-27-2020)
Old 05-27-2020, 08:34 AM   #20
Sam86
Thanks i'll try your method when it arrives
Old 05-27-2020, 12:12 PM   #21
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
I have pictures on my build page. I double sided taped them and screwed them into the spot on the headlights where the OEM headlights mount them. The ignitors are mounted there too.
The relay I mounted vertically as instructed to a hole I drilled by the fuse box and mounted with a rivet.
The Following 2 Users Say Thank You to Irace86.2.0 For This Useful Post:
Sam86 (05-28-2020), Yoshoobaroo (05-27-2020)
Old 05-27-2020, 12:22 PM   #22
Yoshoobaroo
TRACKBREAD
That’s usually my favorite spot for them.
Separate ignitors are still a thing?
Old 05-27-2020, 04:09 PM   #23
Irace86.2.0
They are for the Morimoto TRS kit.
The Following User Says Thank You to Irace86.2.0 For This Useful Post:
Old 12-03-2020, 09:54 AM   #24
Will BRZ
Damn that's crazy...
Drives: 2015 BRZ
Which one of these two would you recommend?
https://www.vland-official.com/produ...-12v-55w-6000k
https://www.diodedynamics.com/d2h-hi...rsion-kit.html
Or is there another kit you think works best? Looking for a kit that comes with everything I need and bulbs would be preferred, but I can also get my own. Only have the Vland headlights installed so far.
Thanks!
Will BRZ is offline   Reply With Quote
Old 12-03-2020, 10:57 AM   #25
Irace86.2.0
Thanks!
Some people find the cheap ones just as good as the expensive ones. It is really up to you. I bought a Morimoto kit from theretrofitsource.
Will BRZ (12-03-2020)
Old 12-03-2020, 12:10 PM   #26
Will BRZ
Drives: 2015 BRZ
Got it. Assuming this one?
https://www.theretrofitsource.com/d2...D2H?quantity=1
Big price difference than the Diode Dynamics one lol may just go with Vland one.
Old 12-03-2020, 12:30 PM   #27
Irace86.2.0
That link was just the bulbs. This is the full ballasts n bulbs n harness:
Vland Headlights for 10 Series FRS JDMPR725 Electronics | Audio | NAV | Infotainment 3 04-04-2021 06:18 PM
OLM HID headlights (looks like VLAND for BRZ’s) Suparu Cosmetic Modification (Interior/Exterior/Lighting) 3 01-23-2020 07:55 PM
Vland headlights question gpvecchi Cosmetic Modification (Interior/Exterior/Lighting) 17 09-27-2019 01:43 AM
WTB SPEC D OR VLAND HEADLIGHTS tk1.frs Want-To-Buy Requests 0 08-18-2019 07:10 PM
FS BNIB Vland headlights statik Exterior Parts (Aero, Lighting, Etc.) 2 07-04-2019 01:56 PM
