Old 01-10-2020, 01:56 AM   #1
JDMPR725
Drives: 2013 Scion FRS (10-Series)
Vland Headlights for 10 Series FRS
I have a 2013 Scion FRS 10 Series model that came with 8 pin wiring harness for headlights. I'm looking for a correct wiring diagram for 10 series FRS models to read what each cable is for to wire my vland headlights.
Does anyone know where to find wiring diagrams for 10 series scion FRS models or do they have the same wiring layout as the regular base models?
Thanks!
JDMPR725 is offline   Reply With Quote
Old 01-10-2020, 03:07 PM   #2
Alpha86
Drives: 2013 Firestorm Red FRS
Are you trying to wire the 8pin to a 6pin? I recently ordered OLM sequential headlights which are pretty much identical to the Vlands, and they come with an 8pin to 6pin adapter. If this is what you're looking for, maybe you can get that adapter from FT86SF.
Alpha86 is offline   Reply With Quote
Old 01-12-2020, 04:59 AM   #3
JDMPR725
No, The wiring on my car is an 8 pin harness connector on both sides mainly for my headlight & high/low beam switch mechanism. The Vland headlights also have an 8 pin harness connector. The 6 pin to 8 pin harness connector adapter is included in the package but I don't have a 6 pin on the Vland connectors or in my 2013 Scion FRS 10-series. The adapter does come with wires which is the only source for turning signal wires out of the whole wiring for the aftermarket headlights.
I already do know what all the colors in the Vland headlights represent. My overall concern is that I don't know if Toyota/Scion/Subaru made a different wiring scheme on each of their FRS/BRZ/86 models. I will post a picture of how my wiring currently is in my car in the attachments section.
Old 04-04-2021, 06:18 PM   #4
ICauseCalamity
Drives: Totaled 2013 Toyota Corolla
Necro post
Any update on this? I have a 10 Series as well and want to swap out to the Spec D headlights to make an RGB boomerang.
ICauseCalamity is offline   Reply With Quote
frs, vland, wiring diagram, wiring harness
Vland headlights question gpvecchi Cosmetic Modification (Interior/Exterior/Lighting) 17 09-27-2019 01:43 AM
WTB SPEC D OR VLAND HEADLIGHTS tk1.frs Want-To-Buy Requests 0 09-16-2019 11:37 PM
WTB SPEC D OR VLAND HEADLIGHTS tk1.frs Want-To-Buy Requests 0 08-18-2019 07:10 PM
FRS Led Conversion (Vland Headlights) Help Michael41197 Electronics | Audio | NAV | Infotainment 2 07-05-2019 07:44 PM
FS BNIB Vland headlights statik Exterior Parts (Aero, Lighting, Etc.) 2 07-04-2019 01:56 PM
