Old 05-25-2020, 12:17 AM   #1
hpanju
hpanju's Avatar
Drives: 2016 Subaru BRZ
VLAND Headlights
Hi guys, looking to purchase some VLANDS for my 2016 pre facelift BRZ. Im very new to the whole lighting and electrical aspect of things, can I buy the headlights (they dont come with bulbs), and then buy just a set of bulbs separately, or do I need a full HID kit (whatever that is). I understand they only take h7, d2s, and d2h bulbs.
hpanju is offline   Reply With Quote
Old 05-25-2020, 07:56 AM   #2
Guest
Drives: 2017 BRZ PP
You'll need a full HID kit. So bulbs, ballasts, wiring.
Guest is offline   Reply With Quote
Old 05-25-2020, 08:21 AM   #3
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Just be prepared, the Vlands’ light output is a lot worse than the stock BRZ lights.
Old 05-25-2020, 11:36 AM   #4
Bowflex
Drives: Scion FR-S
These are the same as VLands and come with a HID kit. I finally pulled the trigger on them today. 10% off with the MDS10 promo code that expires today. They are backordered again but hopefully they get a new shipment next month.
https://www.ft86speedfactory.com/olm...2013-ft86.html
Bowflex is offline   Reply With Quote
Old 05-25-2020, 06:23 PM   #5
hpanju
hpanju's Avatar
I talked to my guy and he said they’re on backorder until late August
The Following User Says Thank You to hpanju For This Useful Post:
Bowflex (05-25-2020)
Old 05-25-2020, 06:26 PM   #6
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
H7 can be used, but the housings are made for D2H, so the H7 bulb doesn't fit well. No OEM DxS bulb will fit because of the bulk to the bulbs and the housing.
Buy a HID kit for D2H with an H7 power adapter and a standard relay kit (not a canbus adapter).
Not at all.
This is running a 6500k bulb. I since have changed to a 5500k, but I doubt there is much difference between my output and the OEM setup.
Here are some bad pictures (iPhone 6). These headlights allow for better output than many OEM HID headlights.
Old 05-25-2020, 06:40 PM   #7
hpanju
hpanju's Avatar
Not at all.
I’m assuming those pictures are vlands with an HID kit installed cause I’ve heard halogens in VLANDs sucks
Old 05-25-2020, 06:47 PM   #8
sharpsicle
Certs You Dont Care About
sharpsicle's Avatar
Drives: 2013 Galaxy Blue BRZ
Not at all.
Absolutely they are a lot worse out of the box with the standard halogen bulb. Obviously if you put a new HID kit on it will increase output, just like any other housing.
sharpsicle is offline   Reply With Quote
Old 05-25-2020, 06:49 PM   #9
Irace86.2.0
I actually ran a Sylvania Ultra White bulb for a while before my HID kit came in, and it isn't as bright or white, but the cutoff is the same. In order for it to fit I had to file down a tab. Maybe others don't file it down, so the bulb sits crooked, and it doesn't project well.
The problem with filing down the tab is that the D2H bulbs use the tab to orient the bulb correctly in the housing, so it takes more effort to align them later. I suggest just getting the D2H kit. Check out my build for pictures of where I mounted them.
https://www.sylvania-automotive.com/...erstar_zxe.jsp
Old 05-25-2020, 06:53 PM   #10
Irace86.2.0
My kit didn't even come with a bulb. I think some vendors throw in a bulb, but saying the headlights are worse is like saying aftermarket wheels are worse than the stock rims because the aftermarket rims come with no tires or because some vendors includes the rims with some crapped tires.
We are talking about the headlights--not the bulbs. The headlights are good.
The Following User Says Thank You to Irace86.2.0 For This Useful Post:
DriveDriftDogfight86 (08-04-2020)
Old 05-25-2020, 08:12 PM   #11
sharpsicle
sharpsicle's Avatar
...saying the headlights are worse is like saying aftermarket wheels are worse than the stock rims because the aftermarket rims come with no tires or because some vendors includes the rims with some crapped tires.
I would stand by that as well. Wheel is only as good as the tire that's on it. Aesthetics without proper function is good only if the car never moves. If you have to make an additional investment to get the advertised function, it's worth bringing up.
Old 05-25-2020, 08:41 PM   #12
Irace86.2.0
All aftermarket headlights are pretty much the same--SpecD, Winjet, etc--H7 or HID. For some reason these headlights get a lot of negative comments from people who don't own them.
Old 05-25-2020, 09:01 PM   #13
Bowflex
Drives: Scion FR-S
That's unfortunate. Thanks for the heads up. I knew I should've bought them a few weeks ago when they came back in stock.
Old 05-26-2020, 03:31 AM   #14
gpvecchi
gpvecchi's Avatar
Any options for those who come from 2017+ bi-led setup?
Vland Headlights for 10 Series FRS JDMPR725 Electronics | Audio | NAV | Infotainment 3 04-04-2021 06:18 PM
OLM HID headlights (looks like VLAND for BRZ’s) Suparu Cosmetic Modification (Interior/Exterior/Lighting) 3 01-23-2020 07:55 PM
Vland headlights question gpvecchi Cosmetic Modification (Interior/Exterior/Lighting) 17 09-27-2019 01:43 AM
WTB SPEC D OR VLAND HEADLIGHTS tk1.frs Want-To-Buy Requests 0 08-18-2019 07:10 PM
FS BNIB Vland headlights statik Exterior Parts (Aero, Lighting, Etc.) 2 07-04-2019 01:56 PM
