#15 |
Drives: 2016 Halo FRS
They would be my first choice bc of the data, just curious, also I do like the looks of trackspec more.
#16 |
Drives: GTS 86
I looked at trackspec but ended up with Verus ones as I like the classic look but also are very functional. On a hot day I can see the heat coming out !
#17 | |
Drives: 2017 PP BRZ
http://seiboncarbon.com/products/tsi...ubaru-brz.html |
#18 | |
Drives: 2017 BRZ Limited
Shipping an aftermarket hood to Germany is not practical for me. |
#19 |
If you don't mind cutting up some support there are some OEM knock offs like the Focus RS and Sierra Cosworth.
I used the Sierra vents on a old Celica, mounted them as far forward as I could so they were just behind the radiator. They worked a treat and looked OEM (ish). Plus they were pretty cheap, I think I paid $100 for a pair. Personally I'm not a fan of the sheet metal vents, they look like vents you would find on a tin shed which were purchased at the local hardware store. Well, that's what I think, opinions, as always, will vary.
http://www.ft86club.com/forums/showthread.php?t=133311 I'm only here for the biscuits |
#20 |
Drives: 2JZ 2015 FR-S, 2015 F250 on 40's
I don't think you can go wrong with any of the three companies hood vents that were mentioned but I would like some more information on the rain guards and their actual necessity.
I daily mine and it rains a lot near ATL, I've read at least one case where someone with a vented hood had water pooling on part of the engine and it caused an issue. I'd like to know if that is the exception and not the rule. Does anyone have some decent mileage on these that drives them in the rain frequently without rain guards? |
#21 | |
Drives: FRS
Verus vents, in Kanadian summer AND winter. I installed only the 2 inner large ones due to the exposed supercharger air filter getting wet, due to the outer drivers side vent that would pour water directly onto the filter, (worse with the rain guard due to the flow of the rain guard). No water gets in while running in the rain, until parked for several hours in rain then the accumulated water under the hood would make my supercharger belt squeal on start up. For belt longevity, if overnight parking, I cover the vents with a strip of garbage bag or grocery bag. A covered air filter would allow for all 4 vents, but an alternator cover and belt cover to allow rain to flow around would be a good idea in lousy climates. IMHO
| The Following User Says Thank You to RFB For This Useful Post: | Axis2011KR (12-11-2018) |
#22 |
Thanks for everyone's opinion. CSGMike is right about the rain guards blocking the heat, but I went with the Verus anyways. I'll start with just the center two and add the outer two vents if necessary later down the line. I will post pics of the install, if I do it myself... More likely I will have a bodyshop do it for me.
#24 |
Drives: Subaru BRZ / Toyota 86 Experts
Here's hood vent data in some hot weather conditions used in actual racing.
https://www.counterspacegarage.com/b...its-data-2017/ The vents have been banned with the updated ruleset for QTCC due to being too effective. The result is racers are adding bigger splitters to compensate for the change in aero characteristics. |
#25 | |
Drives: 18 BRZ tS, 27 GRMN 86
What do you think of this MPH Hood? Any comments in terms of cooling wise? Thanks! https://www.ft86club.com/forums/showthread.php?t=116268 |
#26 |
Drives: 2017 Toyota 86
GTR scopes look awesome but, not sure how effective they are.
#27 | |
It's dependent on a few factors, but in the case of this car, a large vented area is important for proper extraction, otherwise, it's just a duct for air to escape under low speeds. |
| The Following User Says Thank You to CounterSpace Garage For This Useful Post: | botbs (05-25-2020) |
#28 |
Imperator
Drives: Supercharged 2013 BRZ Limited
| Painted Hood Vents? | CatDaddysBBQ | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 10-15-2018 06:36 PM |
| Wtb: hood vents or carbon fiber vented hood | Pooponwindows | Want-To-Buy Requests | 0 | 05-25-2018 01:24 PM |
| Best way to seal off vents in cf hood so they are for looks? | Frs32907 | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 04-01-2014 01:25 AM |
| Hood Vents and Weather | Cjymiller | Cosmetic Modification (Interior/Exterior/Lighting) | 13 | 10-20-2013 01:31 PM |
| CF hood with vents vs. Rain | BrzRacer | Cosmetic Modification (Interior/Exterior/Lighting) | 11 | 02-05-2013 09:50 AM |
