Old 12-10-2018, 05:28 AM   #15
Trust86
Drives: 2016 Halo FRS
They would be my first choice bc of the data, just curious, also I do like the looks of trackspec more.
Trust86 is offline   Reply With Quote
Old 12-10-2018, 06:01 AM   #16
Hawk77FT
Drives: GTS 86
I looked at trackspec but ended up with Verus ones as I like the classic look but also are very functional. On a hot day I can see the heat coming out !
Hawk77FT is offline   Reply With Quote
Old 12-10-2018, 07:55 PM   #17
scion fr-s
scion fr-s's Avatar
Drives: 2017 PP BRZ
Originally Posted by djezlee View Post
Any recommendation for hood vents? I will be installing a FI kit soon and would like to address the heat issue in advance. I am not sure which brand of vents are actually functional for venting the heat. I am also concerned about downforce or damage from rain water.
Aftermarket hood?
http://seiboncarbon.com/products/tsi...ubaru-brz.html
scion fr-s is offline   Reply With Quote
Old 12-11-2018, 06:41 AM   #18
djezlee
Drives: 2017 BRZ Limited
Originally Posted by scion fr-s View Post
Shipping an aftermarket hood to Germany is not practical for me.
djezlee is offline   Reply With Quote
Old 12-11-2018, 07:34 AM   #19
86MLR
86MLR's Avatar
If you don't mind cutting up some support there are some OEM knock offs like the Focus RS and Sierra Cosworth.
I used the Sierra vents on a old Celica, mounted them as far forward as I could so they were just behind the radiator.
They worked a treat and looked OEM (ish).
Plus they were pretty cheap, I think I paid $100 for a pair.
Personally I'm not a fan of the sheet metal vents, they look like vents you would find on a tin shed which were purchased at the local hardware store.
Well, that's what I think, opinions, as always, will vary.
Old 12-11-2018, 02:20 PM   #20
Axis2011KR
Drives: 2JZ 2015 FR-S, 2015 F250 on 40's
I don't think you can go wrong with any of the three companies hood vents that were mentioned but I would like some more information on the rain guards and their actual necessity.
I daily mine and it rains a lot near ATL, I've read at least one case where someone with a vented hood had water pooling on part of the engine and it caused an issue. I'd like to know if that is the exception and not the rule.
Does anyone have some decent mileage on these that drives them in the rain frequently without rain guards?
Axis2011KR is offline   Reply With Quote
Old 12-11-2018, 03:33 PM   #21
RFB
RFB's Avatar
Drives: FRS
My experience -
Verus vents, in Kanadian summer AND winter.
I installed only the 2 inner large ones due to the exposed supercharger air filter getting wet, due to the outer drivers side vent that would pour water directly onto the filter, (worse with the rain guard due to the flow of the rain guard).
No water gets in while running in the rain, until parked for several hours in rain then the accumulated water under the hood would make my supercharger belt squeal on start up.
For belt longevity, if overnight parking, I cover the vents with a strip of garbage bag or grocery bag.
A covered air filter would allow for all 4 vents, but an alternator cover and belt cover to allow rain to flow around would be a good idea in lousy climates. IMHO
RFB is offline   Reply With Quote
The Following User Says Thank You to RFB For This Useful Post:
Axis2011KR (12-11-2018)
Old 01-15-2019, 04:58 AM   #22
djezlee
Thanks for everyone's opinion. CSGMike is right about the rain guards blocking the heat, but I went with the Verus anyways. I'll start with just the center two and add the outer two vents if necessary later down the line. I will post pics of the install, if I do it myself... More likely I will have a bodyshop do it for me.
Old 01-15-2019, 04:59 AM   #23
djezlee
Thumbs up
Originally Posted by Takumi788 View Post
The Verus rain guards are easily removable
Thanks man! Hearing this made all of the difference!
The Following User Says Thank You to djezlee For This Useful Post:
Takumi788 (01-15-2019)
Old 01-15-2019, 02:41 PM   #24
CounterSpace Garage
CounterSpace Garage's Avatar
Drives: Subaru BRZ / Toyota 86 Experts
Here's hood vent data in some hot weather conditions used in actual racing.
https://www.counterspacegarage.com/b...its-data-2017/
The vents have been banned with the updated ruleset for QTCC due to being too effective. The result is racers are adding bigger splitters to compensate for the change in aero characteristics.
CounterSpace Garage is offline   Reply With Quote
The Following 2 Users Say Thank You to CounterSpace Garage For This Useful Post:
botbs (05-24-2020), Joveen (05-24-2020)
Old 05-24-2020, 10:38 PM   #25
botbs
botbs's Avatar
Drives: 18 BRZ tS, 27 GRMN 86
Thanks for the testing data! I do like the track spec vents but one reason on why I dont want to cut my hood because is easier to resell the car after.
What do you think of this MPH Hood? Any comments in terms of cooling wise? Thanks!
https://www.ft86club.com/forums/showthread.php?t=116268
botbs is offline   Reply With Quote
Old 05-24-2020, 11:39 PM   #26
Contender
Drives: 2017 Toyota 86
GTR scopes look awesome but, not sure how effective they are.
Contender is offline   Reply With Quote
Old 05-25-2020, 02:34 PM   #27
CounterSpace Garage
They're very light and actually quite nice. Customer delivery is unknown to us. Some people received their orders quickly and others have still been waiting for them. Venting has to be done with well implemented ideas. MPH makes it so the air has nowhere else to go but through the vents. There are some vented hoods which have almost zero venting effect other than seeing heat coming out of the vents at the traffic light. Some vents work in very low speeds, but that's about it.
It's dependent on a few factors, but in the case of this car, a large vented area is important for proper extraction, otherwise, it's just a duct for air to escape under low speeds.
The Following User Says Thank You to CounterSpace Garage For This Useful Post:
botbs (05-25-2020)
Old 05-25-2020, 04:15 PM   #28
BRZ_88
Imperator
Drives: Supercharged 2013 BRZ Limited
BRZ_88 is offline   Reply With Quote
Painted Hood Vents? CatDaddysBBQ Cosmetic Modification (Interior/Exterior/Lighting) 1 10-15-2018 06:36 PM
Wtb: hood vents or carbon fiber vented hood Pooponwindows Want-To-Buy Requests 0 05-25-2018 01:24 PM
Best way to seal off vents in cf hood so they are for looks? Frs32907 Cosmetic Modification (Interior/Exterior/Lighting) 2 04-01-2014 01:25 AM
Hood Vents and Weather Cjymiller Cosmetic Modification (Interior/Exterior/Lighting) 13 10-20-2013 01:31 PM
CF hood with vents vs. Rain BrzRacer Cosmetic Modification (Interior/Exterior/Lighting) 11 02-05-2013 09:50 AM
