Old 07-23-2012, 01:29 PM   #15
milenko11
Drives: no
Was it two pieces because of the air bag?
milenko11 is offline   Reply With Quote
Old 07-23-2012, 01:38 PM   #16
Gen
Drives: Scion FR-S
There's no air bag behind it.
Gen is offline   Reply With Quote
Old 07-23-2012, 01:55 PM   #17
xcelir8brz
Drives: 2013 BRZ Limited
It's in the dash above the console panels.
xcelir8brz is offline   Reply With Quote
Old 07-23-2012, 02:15 PM   #18
MrH
Drives: 20 Outback XT, 23 BRZ on order
Pure guess, but I would say its so the radio surround would be different from the remaining pieces, making it less expensive for them to vary the size of the radio.
This thought just occurred to me, but is the size of the opening in the BRZ the same as the FR-S? If not (if Subaru doesn't use a Toyota-wide radio) we may have the start of a solution to the gap/fitment issue with aftermarket radios. (I know, wishful thinking)
No, that's not it at all. The radio size is a standard double DIN unit. Same size in both.
They did it in two pieces due to mold flow. Injection molding that as one piece would be difficult due to the asymmetry and large opening in the middle.
Nothing to do with the airbags either, as someone else suggested. The airbag on the passenger side deploys out of the top of the dash.
MrH is offline   Reply With Quote
Old 07-23-2012, 02:49 PM   #19
Your explanation makes sense. I
was just guessing based on the fact that the radios are only a standard 2DIN height, but not width. Toyota radios are "extra wide" and cannot be replaced by an aftermarket radio without using a trim panel, so it was wishful thinking on my part that the Subaru version required a different (narrower) trim piece that was a standard 2DIN width.
This did make me think though that if you were going to wrap the trim pieces anyway, it wouldn't be too difficult to fill the gap in and make it look like it was the correct size for an aftermarket radio.
Old 07-23-2012, 03:35 PM   #20
adprokid
adprokid's Avatar
Drives: ZN6 / GDB-G
I think that the glossy cf panel will reflect the sun light while driving, it can very be annoying
adprokid is offline   Reply With Quote
Old 07-23-2012, 03:49 PM   #21
MrH
Oh, my mistake then. I didn't realize Toyota did something that wasn't double DIN but close to it. Sitting in both, at first glance, I assumed they were both double DIN, but you know what happens when you assume.
Yeah, you could fill the gap if need be. If I were wrapping them in something other than carbon fiber though (some sort of fabric), I would probably still keep them separate. I'm guessing the back side wasn't designed for it to pop off as one piece, and it might make future disassembly more difficult.
The Following User Says Thank You to MrH For This Useful Post:
Dadhawk (07-23-2012)
Old 07-23-2012, 11:27 PM   #22
Entropy
Oversteer > Understeer
Entropy's Avatar
Drives: GT86
Where can I buy that shift knob!?
Entropy is offline   Reply With Quote
Old 07-24-2012, 11:00 AM   #23
Z0rr0
Drives: 2013 Raven 6MT FR-S
It's the STI titanium knob. I've had it for 4 years. Great feel, but it gets hot in the sun..:eek:
Z0rr0 is offline   Reply With Quote
Old 07-24-2012, 11:02 AM   #24
Z0rr0
When the panels are bonded, they still come off and go back on the dashboard easily. No reason to leave them as 2 pieces.
Old 07-24-2012, 11:09 AM   #25
Jidonsu
Drives: Scion FR-S | 6MT | Ultramarine
How much to do mine if I ship it to you?
Jidonsu is offline   Reply With Quote
Old 07-24-2012, 11:18 AM   #26
ImAwesome
Drives: 99' M3, 13' SWP Brz
I've been looking into doing this myself. can't wait to see the end result
ImAwesome is offline   Reply With Quote
Old 08-04-2012, 11:52 PM   #27
MrBodyMassage
Drives: 1994 Toyota MR2 Turbo, WRB BRZ Lim
Have you gotten the clear on yet?
MrBodyMassage is offline   Reply With Quote
Old 08-05-2012, 02:03 PM   #28
MrH
Good to know. I haven't taken them off yet personally. Keeping them two pieces would make it easier to wrap though if you're wrapping it with a skin.
Interior trim trim clips (Dash Trim Panel) ubersoph Cosmetic Modification (Interior/Exterior/Lighting) 4 08-11-2022 07:47 AM
Wheel Directory: Enkei RPF1 17x8.0 +45 track_warrior Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 163 03-17-2022 02:00 AM
Toyota Service Bulletin: Body Panel Fitting Issues ahausheer Issues | Warranty | Recalls / TSB 99 03-07-2017 12:21 PM
Is this what they mean by panel fitment issues? ahquit Issues | Warranty | Recalls / TSB 7 08-21-2012 03:19 PM
Trade my black dash plastic for your silver dash plastic thread. F3dzo Southeast 0 07-17-2012 10:06 PM
