Old 05-15-2020, 01:47 PM   #1
Spacemane969
Spacemane969's Avatar
Drives: 2013 ARGENTO A/T
Play in SPC LCA bushing
I noticed this the other day while installing new coilovers. Is this normal? Sorry for the quality. The video is the rear LCA attached only to the hub.
https://imgur.com/a/EgUHiBq
Spacemane969 is offline   Reply With Quote
Old 05-15-2020, 02:42 PM   #2
ActionMaxon
Professional Auto Fixer
ActionMaxon's Avatar
Drives: 2016 Oceanic FR-S as Designed
Seems like a tremendous amount of movement. Is it cracked and splitting?
Work Hard. Play Hard.
2016 Oceanic
ActionMaxon is offline   Reply With Quote
Old 05-15-2020, 03:24 PM   #3
Grady
Grady's Avatar
Terrible video! Try putting the light behind you next time.
I am guessing that is a end bearing Those will wear out and need replaced. Rotational movement on that is not an issue you need to check it for play in and out.
The Following User Says Thank You to Grady For This Useful Post:
strat61caster (05-16-2020)
Old 05-16-2020, 03:27 AM   #4
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
That's the spherical joint in the wheel hub, not the spc lca, it's supposed to have multiple degrees of freedom. As long as you don't have unusual noises back there it's probably fine.
ineedyourdiddly
Spacemane969 (05-17-2020)
Old 05-16-2020, 09:01 AM   #5
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
Can't see video because imgur is being a shit, but I don't think I could see the video even if imgur was allowing me, just from the thumbnail I can tell that I wouldn't be able to see a thing.
The rear lca has the wheel end joint pressed into the knuckle, I've seen a few of those go bad on foresters, it should rotate freely, but axial and lateral play are a big no-no. Even if there is no noise, play in that spherical joint means bad alignment.
https://www.whiteline.com.au/product...63412&sq=24130
Old 05-17-2020, 02:21 PM   #6
Spacemane969
Thanks. As @strat61caster mentioned I incorrectly labeled it in the title. But it seems there are a couple of opinions on the normal movement of these hub joints. For me it moves on all axes but I have no noises what so ever. Just wondering if it could lead to a mushy or soft driving feel.
Old 05-17-2020, 03:29 PM   #7
strat61caster
Movement in an undesired axis would be wear, which means it's loose, which means it would make noise when loaded and unloaded.
ineedyourdiddly
Rear Lower Control Arm Solid Bushing vs Rubber Bushing NVH Infinity Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 12-28-2023 10:12 AM
WTB: Mtec Springs/Trans Mount Bushing/Rear Shift Bushing 86dev Want-To-Buy Requests 2 03-14-2018 04:07 PM
Whiteline bushing inserts vs. full bushing replacements mhiscott Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 12-15-2015 12:45 PM
Whiteline transmission bushing and Perrin shifter bushing review. Superhatch Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 12-09-2012 09:40 PM
How its going to play out 47corolla Scion FR-S / Toyota 86 GT86 General Forum 18 04-25-2012 07:05 PM
