#15 |
Drives: Stock Toyota GT86
#16 |
Sittin' Sideways
Drives: 2016 Toyota FR-S
https://www.ft86club.com/forums/showthread.php?t=129898
This is the auto transmission fluid servicing procedure. It's very involved, and there is no getting around having to do it this way.
-O/D
2016 FR-S, Hot Lava |
#17 | |
#18 |
Drives: RS 2.0
Its a "feature" that makes the auto copy the notchy feel of the manual.
#19 |
Sittin' Sideways
You just made me realize, we never asked if he put the transmission in sport mode. Could be the actual "issue".
-O/D
#20 | |
Hmmmmmm could be, actually sports mode is not enabled, light is not on the dashboard, but maybe the car decided to go crazy, i will enable the mode and disable it back, hopefully things will go as expected! |
#21 |
tried it and nope, i don't know how i can explain it, i feel like the that is having a milliseconds of delay between each gear, which makes the car "notchs" which changing gears.
#22 | |
The mechanic changed the oil, and i think he did it in the wrong way :P |
#23 | |
Drives: 2017 toyota 86
Otherwise it is very quick, simple, and easy. Obviously more complicated than simply draining and refilling but not by much. I have done it several times with no issues. First when installing my DIY AT cooler i did 2 drain and fills, then again when i installed a stage 2 valve body and decided to switch to redline AT fluid i did it 4 more times to flush out the old fluid. But yes OP did not come close to following the procedure, and should resolve this known issue, before moving on to trying to resolve potential non issues. |
#24 | |
#25 | ||
Sittin' Sideways
No offense intended.Anything gets easier with repetition. I'm sure plenty of people would look at this procedure and find it to be a lot to deal with at first blush just to change transmission fluid along with the need to get the fluid level right. If I had the time, space, and patience to tackle it, I'd definitely give it a shot. Once upon a time I thought doing my own oil change was a big deal, too. Quote:
-O/D
#26 | |
Regarding the notchy feeling, i think we found the issue! but where the heck to buy this mount, please check out the video, and please enlighten me!, i called Toyota... damn they want to sell me the whole shaft for 500$.... |
#27 | |
Just get a low mileage used driveshaft on eBay for around 100$ |
#28 |
| Transmission doesn't want to go into 1st, notchy changes. | Freude am Fahren | Engine, Exhaust, Transmission | 26 | 10-14-2017 11:30 PM |
| Automatic Transmission | devinclfalcons | Engine, Exhaust, Transmission | 60 | 04-29-2014 09:42 PM |
| notchy/gritty transmission. every gear grinding | prest1ge | Engine, Exhaust, Transmission | 41 | 12-09-2012 06:45 PM |
| Automatic Transmission :( | Almighty Bob | Southern California | 14 | 11-06-2012 01:13 PM |
| topspeed difference between manual transmission and automatic transmission | torquemada | BRZ First-Gen (2012+) — General Topics | 51 | 05-04-2012 07:54 PM |
