Old 05-08-2020, 05:14 PM   #1
ziad.k
Drives: Stock Toyota GT86
Angry Notchy Automatic Transmission
Hello Everyone,
I'm new to the forum, i'm glad i found a forum where i can read and share my experience about this car!
So my car have around 85K KM on it, i was driving my car without any issues, until 2-3 days ago, the shifting between gears up and down sometimes feels notchy, i went to a local mechanic and we checked the Tranny oil and damn it lacks a little bit, so we added around 1.5 Killos, after adding i drove it around but it still got the same feeling, sometimes it shifts smoothly, and sometime it just notch a little bit, so do you think something got broken inside the Transmission? currently i've drove around 300KM after refill but it's still notchy.
I don't mind having this notchy feeling as long as it does not go worse, so do you think this will go worse or it will stay as it is ? or will it heal after a while?
Note: The notchy feeling appears on all gears.
Thanks for your help!
ziad.k is offline   Reply With Quote
Old 05-08-2020, 06:03 PM   #2
86TOYO2k17
Drives: 2017 toyota 86
You need to follow the transmission leveling procedure to make sure it is at the precise level.
Old 05-08-2020, 07:14 PM   #3
Decep
Drives: 2013 FR-S Series 10
You're also almost at 60k, i would probably drain and refill the ATF.
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers
Corsa Catback
Edelbrock Supercharger installed @ 50k
Old 05-09-2020, 12:32 AM   #4
humfrz
^ there you go.
Old 05-09-2020, 12:58 AM   #5
ziad.k
Hello, i did not find any precise instruction on the internet everyone kept saying refull untill it start dripping out from the fill hole and that's what i did
Already did oil change at 60KM and bought OEM ATF Oil. it was called Toyota WS, as far as i remember!
Could it be something else ? i mean not the tranny? can you help me diagnose the issue ?? i have a Launch Scanner (forgot the model) but it's a decent one, i checked if there is any faulty Codes in the tranny and the engine, there is absolutely nothing.
Old 05-09-2020, 10:41 AM   #6
Halo_2
Drives: 2014 MY15 86 GTS
It's on here, you have way too much oil in there.
Halo_2 is offline   Reply With Quote
Old 05-09-2020, 03:39 PM   #7
ziad.k
Please link! thank you very much!
Old 05-09-2020, 03:44 PM   #8
radroach
Drives: car
Toyota and Lexus has a specific fill procedure for their automatic transmissions. The fluid needs to be leveled at a specific temperature. I would guess best approximated by just turning the car on for 30 seconds?
https://demos.starbase7.net/t3Portal..._rm_index.html
See under sections Drivetrain > Automatic Transmission Fluid > Replacement
Old 05-09-2020, 03:49 PM   #9
ls1ac
ls1ac's Avatar
I wonder what notchy means in an auto? hard shift ,slow shift , hesitation , jerky, Only up shift, only down shift, both? Using the paddles, Not using them? Cold, hot?
Old 05-09-2020, 03:53 PM   #10
radroach
Drives: car
@ls1ac sounds about right but also add drivetrain lash clunks from the transmission and differential and subframe mounts going worn.
Old 05-09-2020, 04:13 PM   #11
ziad.k
it's a hard shift that makes you feel a notch feeling it happens when it release the old gear and moves into the new one from high to low or from low to high, cold.... hot.. it does not mater, it just appear randomly sometime it shift smoothly sometimes you can feel the tranny shacking while shifting.
Okay i'm not a mechanic but i was reading here that i might need to change the release bearing ? does the Automatic version of the 86 come with this bearing ? if yes is there a way i can make sure of it ? because my car never had a major repair before and i don't want to play around with it...
https://86speed.com/revised-oem-toyota-release-bearing-frs-brz-86
and thank you for the help, i love this car and i don't want to ignore the issue and make it get worse...
Old 05-09-2020, 04:57 PM   #12
86TOYO2k17
It is in the owners manual as well as been written out on these forums a dozen times. Several of which by me. The transmission is run on hydraulic pressure if the level is not filled to the precise amount it will not run correctly.
There is a procedure to get the dash into tranny temp mode, i just use a scangauge to tell me the precise temp so i skipped that step. Otherwise it is pretty simple,
Drain fluid from drain hole, add 2.1 US quarts of ATF , start car and slowly shift from P-R-N-D-N-R-P stop for 10seconds at each point, 20 seconds on D, repeat twice.
If doing a full “flush” you will need to repeat this 4 total times. Most people just do this once every 15k miles. If going 60k+ its recommended to do the entire “flush” so do it 4 times.
Now to properly level it you will need to have the car turned on and bring the trans temp up to 108F and quickly level it as you can not go above 117F or you need to stop and cooldown/restart. Once temp is at 108F with the car still on pull the leveling plug (note this is not the fill plug or drain plug) the fluid should come out of the leveling plug if it does not add more to fill plug if it does come out you will want to replug the leveling plug when the fluid is draining out as a very thin thread basically just before it would start to drip/dribble out instead of be a solid stream but still very thin like a thread.
While doing this I face-timed another phone so i could look at trans temp so i could lay under car and watch it hit 108F and make sure i had level plug capped before 117F.
If this process is not followed 100% you will most likely have weird transmission problems.
Old 05-09-2020, 05:19 PM   #13
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Take it to a mechanic/dealer.
Old 05-09-2020, 06:56 PM   #14
Halo_2
Thats what the OP did.
Transmission doesn't want to go into 1st, notchy changes. Freude am Fahren Engine, Exhaust, Transmission 26 10-14-2017 11:30 PM
Automatic Transmission devinclfalcons Engine, Exhaust, Transmission 60 04-29-2014 09:42 PM
notchy/gritty transmission. every gear grinding prest1ge Engine, Exhaust, Transmission 41 12-09-2012 06:45 PM
Automatic Transmission :( Almighty Bob Southern California 14 11-06-2012 01:13 PM
topspeed difference between manual transmission and automatic transmission torquemada BRZ First-Gen (2012+) — General Topics 51 05-04-2012 07:54 PM
