Old 05-08-2020, 05:55 PM   #1
Longuy
Drives: 2013 FRS
Nightmare Diagnosis - idle would pulse from 500 to 2000rpm 2-3 times then stall
Symptoms: After winter storage Reinstalled battery, drove car for around ¼ tank of gas, parked for the night, in the morning drove to work without issue. When leaving work car idled rough and had no power, put on 4 way flashers and made it home (work is a 10 min drive from home). Check engine light (CEL) did come on during drive home.
ECU scan came back with PO50A* error. Cleared error. Tried starting car, it would start, but idle would pulse from 500 to 2000rpm 2-3 times then stall. No other CEL.
Solution
Primary Issue: Faulty Mass Air Flow (running rich unspent fuel ran into catalytic converters)
Secondary Issue: Catalytic Converters Melted which plugged exhaust
*Error Code P050A is defined as Cold Start Idle Air Control System Performance.
Longuy is offline   Reply With Quote
Old 05-08-2020, 08:07 PM   #2
Overdrive
Sittin' Sideways
Overdrive's Avatar
Drives: 2016 Toyota FR-S
...yikes. That sounds like zero fun.
Are you able to hook the car up to a battery tender when you store it so that you don't have to remove the battery from the car? Did you put any fuel stabilizer in the tank when you stored it?
-O/D
2016 FR-S, Hot Lava
Overdrive is offline   Reply With Quote
Old 05-08-2020, 08:37 PM   #3
Are your primary and secondary issues confirmed or theoretical?
Old 05-08-2020, 08:51 PM   #4
soundman98
ProCrastinationConsultant
soundman98's Avatar
mouse house in the exhaust?
Old 05-08-2020, 09:14 PM   #5
Longuy
Drives: 2013 FRS
yeah we did put fuel stabilizer in..the car was stored to far from power and on a farm.
Old 05-08-2020, 09:16 PM   #6
Longuy
Drives: 2013 FRS
They guys at Touge tuning/Guelph Subaru confirmed this
Old 05-08-2020, 09:25 PM   #7
Longuy
Drives: 2013 FRS
second thing I thought of after bad gas(we siphon the gas out also)... There was a mouse nest (suspect shrew bc no wire damage) under the intake too furthering the confusion. Touge Tuning traced all the wiring harness with no evidence of chewed wires. That wasn't cheap.
Old 05-08-2020, 09:29 PM   #8
And potentially the air box. Wouldn't be the first.
Old 05-08-2020, 09:38 PM   #9
Longuy
Drives: 2013 FRS
MAF Spec is 2.21-2.69 kohms - Tested at 1.9 kohms
Here is the exhaust
Old 05-08-2020, 10:11 PM   #10
soundman98
soundman98's Avatar
what is it? i mean, i understand it's plugged, but with what?
Old 05-08-2020, 10:30 PM   #11
Longuy
Drives: 2013 FRS
It's the front pipe, with the second Catalytic converter. The first Catalytic converter carbon melted into the second, ruined the over pipe. Replaced it with a Tomei header and invidia overpipe and high flow catalytic converter front pipe. it now has that subie purr
Old 05-08-2020, 10:34 PM   #12
Longuy
Drives: 2013 FRS
fortunately it has a Jackson racing supercharger system which has a modified air intake and cone air filter
Old 05-08-2020, 10:38 PM   #13
soundman98
soundman98's Avatar
so a mouse house wasn't all that far off
Old 05-08-2020, 10:49 PM   #14
Here is the exhaust
Well that sure ain't pretty!
How to lower direct pulse width below .88 solidsnake11 Software Tuning 2 03-29-2020 12:34 AM
Low idle/dip and stall/loss of power GoZ21 Issues | Warranty | Recalls / TSB 5 12-08-2017 06:50 AM
Frs low idle dip and dies multiple times in a row Dogster70 Issues | Warranty | Recalls / TSB 7 11-17-2017 06:44 PM
Rough Idle/Stall/CEL/SL - next steps? CAnemone Northern California 3 08-26-2016 12:55 PM
Turbo Rough Idle & Stall BRZtoni Forced Induction 40 05-25-2016 05:28 PM
