Old 11-30-2017, 05:36 PM   #1
GoZ21
GoZ21's Avatar
Drives: 2013 Asphalt Frs
Exclamation Low idle/dip and stall/loss of power
A little background on the car first:
Engine is bone stock, no tune either 70k mi
I drive mostly highway miles, regular maintenance
CEL for EVAP system
The car has been idling extremely low (around 5-600) and will dip often and stall im also experiencing an obvious dip in power and sometimes when i go to start the car i will have to leave the key turned forward for about 3 seconds before i get any ignition. Are these all related?
GoZ21 is offline   Reply With Quote
Old 11-30-2017, 07:02 PM   #2
humfrz
CEL for EVAP system
Does your car have an AT .. ?? If so, there is a TSB that deals with idle issues.
Is the CEL still present .. ?? If so, what is the code .. ??
Do you have the original battery .. ?? If so, it may be weak. I'd suggest you check it :
http://www.aa1car.com/library/battery_runs_down.htm
.....and maybe have it "load tested" at a battery shop.
You may try re-booting the ECU (disconnect the battery ..... then hook it back up .... ).
Are all those symptoms related ... ?? Hell, I don't know ...... I ain't no mechanic ..... not anymore .....
humfrz
Old 12-01-2017, 06:48 PM   #3
alan.chalkley
Drives: 4wd zooks
CEL for EVAP system
I had this problem twice after the regular maintenance.
My guestimate is that way too much throttle body cleaner spray was used during maintennance.
It cleared itself after about 50km of driving.
For some reason i assume that when a perfectly running car is taken in for regular scheduled maintenance , it should come out still running perfectly after the "skilled apprentice technician" has bestowed their expertise.
alan.chalkley is offline   Reply With Quote
Old 12-01-2017, 07:23 PM   #4
All of those symptoms including the EVAP CEL could be the result of a vacuum leak. They can be a bitch to find though.
Old 12-02-2017, 02:57 AM   #5
humfrz
What's that old saying ..... "an assumption is the mother of all fuckups" ......or something like that ......
humfrz
Old 12-08-2017, 06:50 AM   #6
alan.chalkley
Drives: 4wd zooks
humfrz
The "skilled technician" has a solution for too much spray.
Disconnect and reconnect the battery , so the car goes to relearn fuel trim and is in veg state for the next 200kms , by then the excess spray is gone and the idle is back to normal.
cel, idle dip, power loss
Rough Idle/Stall/CEL/SL - next steps? CAnemone Northern California 3 08-26-2016 12:55 PM
Turbo Rough Idle & Stall BRZtoni Forced Induction 40 05-25-2016 05:28 PM
Loss of power/stall under light throttle. Model Citizen Forced Induction 49 10-21-2014 08:50 AM
Hi rev power loss? lbroskee Scion FR-S / Toyota 86 GT86 General Forum 3 09-29-2012 09:47 PM
CEL, Loss of Traction Light, Loss of Power pituala Issues | Warranty | Recalls / TSB 19 09-05-2012 11:23 AM
