Old 05-04-2020, 10:56 AM   #15
Pil
Drives: 86
Originally Posted by Opie View Post
How many miles on the car? Any chance of carbon buildup causing valves to not seat?
About 35,000 miles.
I have oil catch can that should mitigate carbon buildup.
Pil is offline   Reply With Quote
Old 05-04-2020, 11:25 AM   #16
Opie
Opie's Avatar
Drives: 2020 GMC Canyon Denali Diesel
Originally Posted by Pil View Post
About 35,000 miles.
What is strange is that so many of the valves are leaking, of the actual valve spring failures I've seen there is usually only 1 broken, only once have I seen 2 in the same engine...never seen more than that...
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
Opie is offline   Reply With Quote
Old 05-04-2020, 11:54 AM   #17
Pil
Drives: 86
Do you have any insight as to why this may be?
Up till the misfiring at the traffic jam, the car was behaving normally and before that it had a track day 2 weeks prior with no incidents.
Old 05-04-2020, 12:37 PM   #18
Opie
Opie's Avatar
That's why I was asking about carbon build up on the valves, other possibilities are bent valves (ever get any water in the engine?) or burnt valves (is it tuned or running E85?, Money shift on track?)
Old 05-04-2020, 01:51 PM   #19
Now THAT sounds like a diagnosis out of the 50s -
Maybe an Italian tune up is in order?
OK,OK, I'll go away -
Opie (05-04-2020)
Old 05-04-2020, 02:22 PM   #20
Have they performed a compression test - or did I miss something?
Old 05-04-2020, 02:59 PM   #21
Lantanafrs2
Drives: 2013 frs red
Watch the video. They're filming the actual leakdown
Lantanafrs2 is offline   Reply With Quote
The Following 2 Users Say Thank You to Lantanafrs2 For This Useful Post:
humfrz (05-04-2020), Opie (05-04-2020)
Old 05-04-2020, 03:01 PM   #22
Opie
Opie's Avatar
It's an interesting side effect of direct injection...however since these cars are also port injected, not normally a problem.
The Following User Says Thank You to Opie For This Useful Post:
humfrz (05-04-2020)
Old 05-04-2020, 03:08 PM   #23
mrg666
pessimistic skeptic
mrg666's Avatar
Cylinder 4 started misfiring not too long ago while sitting in traffic jam.
Brought it in to a workshop to have it checked out and they have since changed the spark plugs, coil packs, engine wiring harness and it's still misfiring.
I've check my VIN with the recall range and it's not part of it.
They are reluctant to completely open up the engine but sent me this footage *suspecting* it's the valve springs.
Car is tracked regularly with no power enhancing engine mods
footage #2
That is exactly how my car's symptoms started with single cylinder misfiring and associated CEL. Service started checking with spark plugs, coil packs, and injectors. Then, they said they have to take the engine apart and they found valve springs were bad. It is very expensive if it is out of warranty. I paid $4.5K
BTW I heard the ping at the moment valve spring failed when I was cold starting the car - very subtle sound, can be easily missed.
The Following User Says Thank You to mrg666 For This Useful Post:
humfrz (05-04-2020)
Old 05-04-2020, 04:11 PM   #24
Good to know. So, if hear a ping on startup, I'll let my 2013 coast down the hill to the dealership and trade it in for a green one -
mrg666 (05-04-2020)
Old 05-04-2020, 04:16 PM   #25
Oh, so that's what was going on -
So, I reckon I'll retire my compression gauge, along with my dwell meter and timing light - kinda
Lantanafrs2 (05-04-2020), Opie (05-05-2020)
Old 05-04-2020, 06:52 PM   #26
mrg666
pessimistic skeptic
mrg666's Avatar
Well, if you are not joking, I wouldn't wait for that ping - those green ones will not be around too long and you can have a higher trade in value. Do it!
I cannot do that since I did too much wrenching on this one and I'm kind of attached to it now. I will keep it forever, renewing, replacing parts continuously.
The Following 2 Users Say Thank You to mrg666 For This Useful Post:
AKITA (05-07-2020), humfrz (05-04-2020)
Possible recall on the 86 regarding valve spring tanner CANADA 84 11-28-2019 10:32 PM
Valve float after valve spring recall mswbrz Issues | Warranty | Recalls / TSB 5 11-22-2019 08:03 PM
Valve spring recall meadowz06 Issues | Warranty | Recalls / TSB 115 06-09-2019 12:38 AM
valve spring issue? nikitopo Issues | Warranty | Recalls / TSB 1037 05-01-2019 11:55 PM
Valve Spring Recall venturaII New England 13 02-25-2019 08:41 PM
