Drives: 86
What year car? Are there any CELs or codes?
Drives: 2013 frs red
Both valves leaking quite a bit. Head has to come off. I would suspect valve springs as well given the circumstances of the failure
Drives: 86
No audible rattles or other strange noises? A broken or week valve spring could indeed cause a misfire.
Drives: 86
#7 | |
Could be a weak spring but it would be very unusual when outside the recall window.
#8 | |
Drives: 86
Cooling mods like radiator & oil cooler, suspensions, brake, fluids. Nothing to increase stock engine output. |
The only thing that has me really questioning valve spring issues is that they usually show up at higher RPMs but you said it is mostly at lower.
#10 |
Drives: 86
#11 |
Drives: 86
When you say it shows up at higher RPM, does that mean that the misfiring should have started only at high RPMs? or just the symptoms (strange noises as you mentioned)
#12 |
Valve springs generally fail at high rpm when they're under stress but a flawed or overworked spring can fail anytime regardless of rpm.
#13 |
Drives: 86
#14 |
Drives: 2023 Toyota GR 86 Cup
How many miles on the car? Any chance of carbon buildup causing valves to not seat?
2023 GR Cup Car
| Possible recall on the 86 regarding valve spring | tanner | CANADA | 84 | 11-28-2019 09:32 PM |
| Valve float after valve spring recall | mswbrz | Issues | Warranty | Recalls / TSB | 5 | 11-22-2019 07:03 PM |
| Valve spring recall | meadowz06 | Issues | Warranty | Recalls / TSB | 115 | 06-08-2019 11:38 PM |
| valve spring issue? | nikitopo | Issues | Warranty | Recalls / TSB | 1037 | 05-01-2019 10:55 PM |
| Valve Spring Recall | venturaII | New England | 13 | 02-25-2019 07:41 PM |
