Old 04-30-2020, 10:59 AM   #15
Lim
Drives: Scion FRS 2016
For short term memory lose this device usually helps:
Lim is offline   Reply With Quote
The Following User Says Thank You to Lim For This Useful Post:
Tcoat (04-30-2020)
Old 04-30-2020, 11:33 AM   #16
ls1ac
ls1ac's Avatar
Sorry I was no help.
I was just explaining the concept. I got a battery holder from radio shack that held 8 AA batteries. I then soldered a cigarette plug to the battery pack. Then plug it in.
Any 12v battery will do.
A company used to have a small unit with a 9v battery but todays cars need 12v to hold memory. I am sure they are on the market but mine was very inexpensive and easy to put together.
Old 04-30-2020, 11:43 AM   #17
The sockets on these cars are switched anyway. When you shut the car off there would be no power going to anything. You would have to have the key on or at least set to accessories while removing the battery for anything to maintain power up.
Old 04-30-2020, 11:45 AM   #18
ls1ac
ls1ac's Avatar
I would not recommend a battery charger for two reasons: one, most new chargers will not charge a dead battery. this is because they will ramp up the charge voltage to test for a recharge rate and shut down if no battery is found to be chargeable. The peak voltage can be quite high. The out put on the new type of charger will shut off . Two, the older chargers will put out voltage but it is usually full wave rectified and with out the battery acting as a very large capacitor it is 120 cycle AC. and the voltage peaks can be quite high.
Old 04-30-2020, 11:50 AM   #19
ls1ac
ls1ac's Avatar
I think you may be correct Tcoat, I did half put in a non-switched plug for other devices. I guess you could put alligator clips on instead of a plug and clip to the battery leads.
edit: My truck and my wife's car have always hot plugs.
Old 04-30-2020, 03:28 PM   #20
LimitedSlip
Senior Citizen Member
LimitedSlip's Avatar
Drives: Then-1977 Celica GT Now-2017 860SE
If you are of a mind to maintain vehicle settings during a battery swap, any other healthy 12 volt battery you might have (lawn mower, motorcycle, fish locator, trolling motor, etc.) could be temporarily connected to vehicle ground and the positive battery cable end with lightweight alligator clip jumpers. It doesn't require much for the short duration and minimal current draw. If you are of a mind to . . .
LimitedSlip is offline   Reply With Quote
Old 04-30-2020, 06:24 PM   #21
Ernest72
Personally on my 04 WRX, I clean my MAF and reset my ECU with every oil change or at least once a year. I swear by my buttdyno that the car drives better afterwards. Try to do the same on the BRZ but I put more miles on so maybe once a year.
Old 05-03-2020, 03:08 PM   #22
juanlien
Drives: M5
Originally Posted by Lim View Post
I swapped it yesterday on FRS 2016.
Radio (stock FRS Pioneer unit) preset all preserved, BT, call contacts etc.
I let it idle for a few minutes, and I have not notice any issues when driving.
On my Legacy after battery was disconnected for few days it took like 10-15 minutes before it stopped stalling on a shift due idle dropping to much.
On FRS I only lost clock time, and custom setting for dash info (Rev light limit ...)
nice
juanlien is offline   Reply With Quote
Old 05-07-2020, 09:49 PM   #23
dnieves
Drives: FR-S 10 Series
Same here with my 2013's OEM headunit, you only need to set the clock, re-enable the gear/upshift display, and rev limiter setting then you're set.
dnieves is offline   Reply With Quote
Old 05-08-2020, 08:45 AM   #24
Ernest72
Changed my battery yesterday, somehow all presets and clock in my aftermarket HU were fine. Pioneer 2550nex.
Old 05-08-2020, 09:27 AM   #25
It isn't a surprise. Most HUs retain all of the presets. It isn't like they are still powered when you shut the car off.
Old 05-08-2020, 11:04 AM   #26
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Battery change memory savers, do I need it?
Most aftermarket units have an always on 12V and an ignition switched 12V. The wire harness in almost all cars still have both. It’s only fairly recent that most radios actually retain information after a battery swap, it’s probably only been 10 years or so.
The Following User Says Thank You to Yoshoobaroo For This Useful Post:
Tcoat (05-08-2020)
Old 05-08-2020, 11:18 AM   #27
Ahhhh. Yes I should really not speak on the subject of HUs since I am actually pretty ill informed on them.
Never lost the presets in most of my old cars!
soundman98 (05-08-2020), Yoshoobaroo (05-08-2020)
Old 05-08-2020, 01:46 PM   #28
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Just buttons and knobs.
Memory Saver For Battery Replacement DaJo BRZ First-Gen (2012+) — General Topics 7 05-29-2018 08:47 PM
Memory Steer Issue AxisPower Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 01-11-2017 01:29 AM
Earliest memory rookie Off-Topic Lounge [WARNING: NO POLITICS] 27 03-30-2016 11:41 PM
Shorai Lightweight Battery and KCMachine CNC Machined Battery Tray Package KCMachine Brakes, Suspension, Chassis 111 10-08-2014 08:26 AM
Memory seats Frs x3 Cosmetic Modification (Interior/Exterior/Lighting) 20 01-24-2014 05:39 PM
