Old 10-31-2014, 09:54 PM   #1
AxisPower
Drives: 23 GT4RS
Memory Steer Issue
Recently started having a problem when turning either left or right, the wheel will only return to 11 or 1 o'clock and not all the way to center. I've had an alignment done twice since this started happening, once at an independent shop and the second time after putting in solid rack bushings at the Toyota dealer. I have psm coil overs with rear camber and toe arms, and both times the alignments where almost perfect, 0 toe front and back, -2 camber all around, caster at approximately +6.
At first I thought it was my swaybar end links binding, disconnecting the swaybar did improve the symptoms but there is still some memory steer left. I've tried many different things, including loading the front suspension with the front end in the air to check for binding in the balljoints, upper spherical, but with no luck. Also tried going back to stock and tried different wheels/tires. Can't see any obvious bends in the tie rods or control arms. I've had the car since new and haven't had any accidents, no steering lights etc. Car drives fine, tracks straight when centered, and doesn't behave erratically at high speeds, just doesn't return completely to center and continues to stay that way until I recenter it by hand. Honestly can't remember if its always been like this or I'm just losing my mind. Hope someone can chime in with suggestions.
AxisPower is offline   Reply With Quote
Old 10-31-2014, 10:50 PM   #2
NissanGuy
NissanGuy's Avatar
Drives: Strangely.
Very interesting. How do your front control arm bushings look?
My FR-S has a build thread!
(It's mostly full of Nissans)
NissanGuy is offline   Reply With Quote
Old 11-01-2014, 06:30 AM   #3
Calum
That Guy
Drives: 2013 asphalt FRS MT
Typically memory steer is caused by bad strut mount bearings.
Old 11-01-2014, 12:08 PM   #4
AxisPower
Drives: 23 GT4RS
I thought this would have been the case as well, since my upper sphericals that came with my coilovers were (in my opinion) very tight. I bought a set of Raceeng caster/camber plates which seem to move more freely, but the problem stays the same.
I've tried loading up on the suspension with the front on jack stands by putting a jack and pushing up under each control arm to simulate the car being on the ground, then I try grabbing each wheel by hand and turning it to see if there is any sort of binding in the upper mount and the balljoint, which there isn't.
I have taken the car drifting a few times this season but never went off course or crashed into anything, honestly I'm pretty stumped. My power steering works fine as well and I've never seen the steering light come on, so I think I'd by jumping the gun by saying something is wrong with the rack and power steering motor, but at this point I have no idea. Gonna let the dealer have one more look at it, and if they can't fix it I'll probably live with it. Its more of an annoyance then anything else since it happens when the wheel is so close to center anyways.
Old 11-01-2014, 03:01 PM   #5
wparsons
wparsons's Avatar
Are you getting coil bind from the springs? If you turn lock to lock at slow speeds, do you hear the springs ping at all?
Are you running an upper spring seat with a bearing?
If you pull into your driveway with the wheel not centering and then immediately jack up the front and set it back down, does the wheel center properly?
flickr
Old 11-01-2014, 05:38 PM   #6
AxisPower
Drives: 23 GT4RS
No spring bind on turns, the Raceseng plates came with an upper spring seat bearing.
Old 11-09-2014, 10:34 PM   #7
pitstops
Drives: SC RB FRS
could just be normal.
memory steer is a pull after making a turn. if you make a left turn the car pulls left, if you make a right turn the car pulls right. usually caused by a bad valve inside the steering rack.
pitstops is offline   Reply With Quote
Old 11-10-2014, 10:32 AM   #8
wparsons
wparsons's Avatar
Our racks are 100% manual, with an electric motor boosting input to the rack. Doubt it's a valve inside the rack.
flickr
Old 01-10-2017, 04:02 PM   #9
mokinbird87
BOXER FR
mokinbird87's Avatar
Drives: WRB BRZ Limited
sorry to revive an old thread, but did you ever figure it out? I have the same issue.. I do not have the Raceseng plates anymore either, but it is still doing it..
mokinbird87 is offline   Reply With Quote
Old 01-11-2017, 01:29 AM   #10
Falcon
Drives: WRB BRZ
Minimal Toe In on the Front could help.
Falcon is offline   Reply With Quote
Traction Control memory module installed banzairx7 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 30 06-17-2014 11:13 AM
Memory seats Frs x3 Cosmetic Modification (Interior/Exterior/Lighting) 20 01-24-2014 05:39 PM
Lexar USB memory won`t play in OEM radio speedy racer Electronics | Audio | NAV | Infotainment 10 12-04-2013 11:49 AM
PS Vita w/case, memory stick, + extras Jaylyons1 Miscellaneous 1 02-05-2013 07:47 PM
BeSpoke steer anybody to BRZ? trackmagic Electronics | Audio | NAV | Infotainment 7 05-21-2012 12:54 AM
