Old 04-12-2020, 02:48 AM   #1
Loganp98
Drives: White Subaru brz
Are the rear and front seat belt pretensiors interchangeable??
I was recently in an accident and had to repair both seat belt pretensioners, the pass. Side locked up again and I was wondering, does anyone know if the rear and front seat belts are interchangeable? So that way I can remove the rear and put it in the front, I hardly ever have more than 1 other person in my car at a time so that wouldn’t be much of an issue for me, thanks.
Loganp98 is offline   Reply With Quote
Old 04-12-2020, 11:42 AM   #2
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
They are not, the parts look completely different in the servica manual components view.
*** WARNING ***
Safety restraint components like airbags and seat belt pretensioners and reels are >>> NOT <<< repairable. They are primary safety devices on which lives depend. >>> Replace ONLY <<
The Following 2 Users Say Thank You to RZNT4R For This Useful Post:
JD001 (04-12-2020), Tcoat (04-13-2020)
Old 04-12-2020, 11:44 AM   #3
JD001
JD001's Avatar
Drives: Subaru BRZ
I always thought if seatbelts and associated parts are damaged then they must be replaced, not repaired..
I feel sorry for the 2nd,3rd of 4th owner.. totally oblivious..
The Following User Says Thank You to JD001 For This Useful Post:
Tcoat (04-13-2020)
Old 04-12-2020, 11:47 AM   #4
daskaman
Drives: Burz
Anything can be repaired, it just matters what access to tools you have and skill. That being said, trust the hands that work on your safety systems, or YOLO it
daskaman is offline   Reply With Quote
Old 04-12-2020, 12:33 PM   #5
RZNT4R
No, they are not.
When a pretensioner blows, it actually destroys itself to retract and jam in that position.
The Following User Says Thank You to RZNT4R For This Useful Post:
soundman98 (04-12-2020)
Old 04-12-2020, 03:40 PM   #6
daskaman
Drives: Burz
Originally Posted by RZNT4R View Post
No, they are not.
Everything can be repaired, usually if you have to ask it's beyond your means. this case applies in this context with OP
Old 04-12-2020, 05:01 PM   #7
RZNT4R
A pretensioner uses
an explosive charge
To retract either the seat belt buckle release or (usually) shoot ball bearings into the reel mechanism to retract and jam it.
They are not serviceable components for very good reason, they are both dangerous pyrotechnics and life saving devices.
Old 04-13-2020, 10:18 AM   #8
Opie
Opie's Avatar
Drives: 2020 GMC Canyon Denali Diesel
No, they are not.
There are companies that can, and do, replace the pretensioner, charge and retractor. So they can be safely rebuilt. Not sure it can be done at home by just anybody though.
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
Opie is offline   Reply With Quote
Old 04-13-2020, 10:35 AM   #9
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
Bend over a little more Bo!
Old 04-13-2020, 11:01 AM   #10
Can be and should be are not the same thing!
Old 04-13-2020, 11:07 AM   #11
RZNT4R
Rebuilt SRS parts may be illegal depending on the jurisdiction because rebuilders did a bad job of it and people were injured.
Here, even good-used parts are regulated.
Opie (04-13-2020)
Old 04-13-2020, 07:22 PM   #12
soundman98
ProCrastinationConsultant
soundman98's Avatar
A pretensioner uses
an explosive charge
they make great catapults!
WTB: Rear Seat Belt Tensioner michaelbuccola Want-To-Buy Requests 3 06-28-2022 12:07 PM
How does (very sensitive) passenger seat seat belt sensor work? GrantedTaken Cosmetic Modification (Interior/Exterior/Lighting) 23 10-03-2018 12:43 PM
WTB: Passenger side front seat belt 555 Want-To-Buy Requests 0 09-09-2015 11:53 AM
WTB: Seat Belt Buckles, Driver's Headlight (BRZ), Front Bumper Cover (BRZ) DatApex Want-To-Buy Requests 2 03-19-2014 01:21 PM
