Old 09-16-2018, 12:00 PM   #1
GrantedTaken
How does (very sensitive) passenger seat seat belt sensor work?
If I place my cell phone on the passenger seat,
it thinks someone is sitting there, and starts beeping a warning.
Are there sensors in the mesh?
Or is the seat being weighed?
It's pretty damn accurate!
Impressive
GrantedTaken is offline   Reply With Quote
Old 09-16-2018, 12:36 PM   #2
murdoc
Sometimes I'm wrong.
murdoc's Avatar
Drives: '13 FR-S/'96 240SX
It's a capacitive sensor, so anything with an electric field will trigger it.
murdoc is offline   Reply With Quote
Old 09-16-2018, 12:36 PM   #3
Brink
Drives: 2017 BRZ
You must have a heavy cell phone. I put a backpack or gym bag (cell phone is usually in the gym bag too!) on the passenger seat all the time and it doesn't trigger the sensor.
Brink is offline   Reply With Quote
Old 09-16-2018, 12:40 PM   #4
GrantedTaken
I got lazy and did not search.
It's based on electrical signal not weight.
A cell phone triggers this very easily.
A bucket of paint does not.
Besides keeping the passenger seat belt locked,
anyone have a trick to get around this?
I might place a little container in the passenger seat.
Like the airline TSA "empty your pockets" bins.
Old 09-16-2018, 01:54 PM   #5
amcluesent
Drives: GT-86
You can disable the seatbelt 'ding' using Carista app
amcluesent is offline   Reply With Quote
Old 09-16-2018, 04:14 PM   #6
extrashaky
Drives: 2014 BRZ Limited
A wet umbrella tossed onto the passenger seat can also trigger the sensor.
I put one phone in a phone mount on the dash (of my own design), but I use one of these caddies from the As Seen On TV store at the mall to carry my second phone, my wallet and my beverage:
[ame]https://www.youtube.com/watch?v=BsEqRnlXFkE[/ame]
Old 09-16-2018, 04:22 PM   #7
humfrz
This post is a double er.
First off - search.
Second off - just don't put your cell phone on the seat.
Got it -
humfrz
Old 09-16-2018, 09:28 PM   #8
gravitylover
Don't put a bag of chips on the seat if it's a lined bag, even that will set the stupid thing off. The charger wire will also set it off if it's plugged in and flops over on the seat. Big PITA...
Old 09-16-2018, 10:13 PM   #9
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
amcluesent hit it on the nail, disabling the warning light and beep in an OBD-II app or even a pirated version of tech stream is the best option, no warranty issues or electrical fuckery. Just a simple edit and change and when the battery is pulled it will reset.
Also important note is that if the seat gets wet it will also trigger the sensor, although I'm pretty sure there is a different DTC for the seat being wet vs something being on there internally, but all we see is the beep or passenger seat belt warning light.
Here's a post that explains it best:
https://www.ft86club.com/forums/show...0&postcount=22
Old 09-16-2018, 10:16 PM   #10
FRSBRZGT86FAN
Try just the phone without a case and see what happens, I've had my swiss army school backpack in the seat without it triggering the seat sensor as well, also with a laptop and phone inside. It just blocks the signal from interfering with the seat sensor.
Old 09-30-2018, 08:31 PM   #11
Mach Midnight
MIDNIGHT
Mach Midnight's Avatar
Drives: MY16 Raven
Dealer can shut off these options using their Techstream software. I was quoted $60 to shut off this sound. Or, buy a cable and cracked Techstream ~$20.
Mach Midnight is offline   Reply With Quote
Old 10-01-2018, 09:46 AM   #12
The Carista app can also turn the chime off as well as many other things. Don't know how the cost compares to a legit Techstream but there may be a savings to be had.
https://caristaapp.com/vehicles/scion/fr-s/1st-gen
Old 10-01-2018, 10:12 AM   #13
ermax
ermax's Avatar
My charger cable will even trigger it. I guess it has the advantage of not wearing out like the older membran weight based sensors. Like others, I disabled mine with Techstream.
Old 10-01-2018, 12:09 PM   #14
Dake
Dake's Avatar
A certain amount of weight does activate it as well though. My beagle is 35 lbs and if he sits just right in the seat, he'll trigger the warning. I think it triggers for less though, I'm pretty sure I had a couple gallons of milk there and that was also enough.
Dake is offline   Reply With Quote
Passenger Seat Belt Warning Chime goes on even though there's no passenger. idreamofdrifting Issues | Warranty | Recalls / TSB 58 10-11-2017 10:31 AM
Seat belt sensor? passenger side tigermack Cosmetic Modification (Interior/Exterior/Lighting) 4 10-17-2014 02:12 PM
Sensitive Passenger seat??? Trmx2 Scion FR-S / Toyota 86 GT86 General Forum 5 01-07-2014 07:35 PM
Passenger seat belt warning when I put phone on seat!??? Kayzer Soze BRZ First-Gen (2012+) — General Topics 20 09-13-2013 11:29 AM
Passenger side seat belt frs-guy Issues | Warranty | Recalls / TSB 1 10-11-2012 12:39 AM
