Old 04-12-2020, 09:57 PM   #15
soundman98
ProCrastinationConsultant
soundman98's Avatar
Ok, maybe I'll install mine tomorrow. after all, I've had it for a couple years. Any installment tips?
use your hands?
Spuds (04-13-2020)
Old 04-12-2020, 10:04 PM   #16
Have someone else do it.
Spuds (04-13-2020)
Old 04-12-2020, 10:29 PM   #17
soundman98
soundman98's Avatar
Originally Posted by DarkSunrise View Post
Haha I'm the exact opposite from you. I learned heel-toe the classic way on Hondas, but started using the ride side of my toes with my STI hatch because the transmission tunnel blocked my heel from reaching the throttle pedal. I find this method still works best for me on the FR-S. It must be really dependent on how people's feet are shaped...
i call it the toe-toe method. i've brought it up a few times before, and everyone looks at me like i recommended using your elbow.
The Following 6 Users Say Thank You to soundman98 For This Useful Post:
DarkSunrise (04-12-2020), JD001 (04-13-2020), NoHaveMSG (04-13-2020), Spuds (04-13-2020), Tcoat (04-13-2020), Ultramaroon (04-12-2020)
Old 04-12-2020, 11:02 PM   #18
It's how I do it. Toe-toe, I mean. Not my elbow.
Old 04-12-2020, 11:03 PM   #19
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Total FU.
Old 04-12-2020, 11:29 PM   #20
Total FU.
Spuds (04-13-2020)
Old 04-12-2020, 11:36 PM   #21
Sapphireho
Famous Potatoes
Sapphireho's Avatar
use your hands?
That deserves a semi FU.
soundman98 (04-12-2020), Ultramaroon (04-12-2020)
Old 04-12-2020, 11:38 PM   #22
Sapphireho
Famous Potatoes
Sapphireho's Avatar
A Hungarian growth chart.
Spuds (04-13-2020), Ultramaroon (04-12-2020)
Old 04-12-2020, 11:45 PM   #23
lolfu
Old 04-13-2020, 04:31 AM   #24
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
Originally Posted by henry.haden View Post
I’ve been looking into setting up my BRZ for heel toe downshifting. As I am sure you all know, the stock pedal setup is not ideal for this. I am torn between a throttle spacer kit and an Accelerator Pedal. Here are the URLs. Let me know what you all think.
https://www.ft86speedfactory.com/srp...l#.XpORwxZq0lQ
https://www.ft86speedfactory.com/vel...l#.XpOR7hZq0lQ
I have relatively small feet. I wear size 8 shoes, and I often drive with low sole and narrow profile shoes (Vans Classics or Puma Vedano / "Motorsport" style shoes).
I "toe" with the ball of my foot under my big toe, and I "heel" either with the lower part of the ball of my pinky toe and/or my foot arch.
That being said, the only pedal mod that I feel is needed is a pedal overlay. I use the Cusco Sports Accel Pedal. If you are applying sufficient braking and have good foot position, then the pedal overlay should be sufficient.
If you add the spacer to the mix (which raises the position of the accelerator pedal), it will likely be too high for comfortable heel-toe shifting when under hard braking. In other words, the side of your foot might collide with the side of the accel pedal.
Finally, a few other considerations you might want to be mindful of to improve your heel-toe shifting:
  1. Practice, practice, practice. If you have the right technique, your heel-toe method will be consistent, whether on "track" or "street"
  2. The stock throttle map is a bit mushy at the beginning of the pedal throw. That means you really need to emphasize the accelerator blip and give it gas to get the revs you need. I have a "race throttle" map from my Stage 2 tune, which was night and day for heel-toe.
  3. The higher the revs, usually the easier it is to blip the throttle. Generally, I don't do heel-toe unless the engine revs are at least 3k RPM. Lower than that, there is usually not enough time to comfortably rev and shift through the gears.
EndlessAzure is offline   Reply With Quote
Old 04-13-2020, 06:17 AM   #25
NLSP
NLSP's Avatar
Drives: 2014 Ultramarine FR-S
I've had the SRP pedal for about 5 years now. It's been a blessing since the day I've installed it, makes heel-toe so much easier. Much cheaper than the Velox spacer too.
Old 04-13-2020, 09:29 AM   #26
theneptune86
Drives: Neptune Blue 2019 Toyota 86
perfect for 7/10+
THIS.
Also, I feel like I'm ripping myself off by not developing and selling my own pedal spacer kit for the next 86 platform, which inevitably won't have a "good enough" pedal spacing setup when it comes out
2019 Neptune Blue Toyota 86 • Gruppe-S UEL Catless Headers • OFT Stage 2 Plus (91)
theneptune86 is offline   Reply With Quote
The Following 2 Users Say Thank You to theneptune86 For This Useful Post:
Spuds (04-13-2020), Ultramaroon (04-13-2020)
Old 04-13-2020, 10:26 AM   #27
StraightOuttaCanadaEh
Wes
I have the SRP pedal for 3 years now. 2 minute install and heel and toeing is perfect now
Instagram: @gt86ws
Old 04-13-2020, 12:33 PM   #28
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
You can get a 10mm(3/8) spacer under the stock pedal assembly and still use the stock hardware to mount it. Keep in mind you will need to adjust or space out your pedal stop too. I cut a piece of UHMW and used it as a spacer with the Cusco pedal. Works perfect for me, I wear 8.5-9s. I am working on some 3D printed spacers now out of PETG with different offsets.
Trouble Downshifting into 5th MotoX16 Issues | Warranty | Recalls / TSB 19 10-30-2019 02:50 PM
Downshifting in Autocross smg1138 Tracking / Autocross / HPDE / Drifting 23 05-13-2016 10:41 AM
Trouble downshifting to 2nd MT kEnYUnoT Issues | Warranty | Recalls / TSB 4 11-12-2015 07:59 AM
Downshifting jaime3 Scion FR-S / Toyota 86 GT86 General Forum 18 07-24-2013 10:09 PM
Downshifting AT Estey Engine, Exhaust, Transmission 20 11-14-2012 02:20 PM
