Old 04-05-2020, 05:05 PM   #18257
norcalpb
norcalpb's Avatar
Originally Posted by NaturallyAspirated View Post
Thoughts on the Cusco vs. SRP pedal in terms of functionality? I like the Cusco since it just bolts on and I think you have to drill into the pedal for the SRP. I heard the Cusco does raise the pedal a bit though.
Both raise the pedal but I’d say the SRP raises it the most. The SRP’s extension is also closer to the brake pedal. Overall it is a larger unit.
You do have to drill, but you can easily remove the whole accelerator pedal assembly so you can really take your time with it. Same can be said with the no-drill installation of the Cusco.
The Cusco unit has a more gloss finish than the oem pedals so it does look off but nothing even close to a deal breaker. The Cusco also has a rubber sticky pad that its pedal compresses onto, so the rubber actually protrudes through the pedal adding grip. Despite this the Cusco is still the more slippery pedal compared to the semi-rough satin finish on the SRP.
I wear a size 12 shoe and found both comfortable. Essential mod imo.
The Following 2 Users Say Thank You to norcalpb For This Useful Post:
NaturallyAspirated (04-05-2020), NoHaveMSG (04-06-2020)
Old 04-07-2020, 08:29 AM   #18258
grumpysnapper
grumpysnapper's Avatar
I like long hard drives, but E85 (or sometimes even 98) can be hard to find in some very small towns in Australia.... so fuel range can sometimes be an issue.
Finished this solution today, that works like a dream.
5mm alloy plate with Rotopax mounts fixed to the rear cross brace.
One simple and secure quick release per tank.
Easily removed when not needed, and can even be doubled up on top of each other for a total of 4 tanks (that would be in an extreme circumstance...).
These are 6.6 litres each ( about 1.75 gal) , which is enough to get out of trouble in terms of range.
Lyndon
grumpysnapper is offline   Reply With Quote
The Following User Says Thank You to grumpysnapper For This Useful Post:
soundman98 (04-07-2020)
Old 04-07-2020, 09:03 AM   #18259
StraightOuttaCanadaEh
Wes
I just screwed my SRP pedal in, no drilling. The OEM pedal has some soft squishy bits so I peeled off the OEM pedal cover with pliers and then just screwed in the SRP pedal with the provided self tapping screws. There was no drilling involved, it was literally a 2 minute install.
Instagram: @gt86ws
The Following User Says Thank You to StraightOuttaCanadaEh For This Useful Post:
norcalpb (04-07-2020)
Old 04-07-2020, 09:59 AM   #18260
JD001
JD001's Avatar
Drives: Subaru BRZ
Took me longer to read and digest what you did in 2minutes..
Old 04-07-2020, 10:18 AM   #18261
Wes
trust me, I typed and backspaced a few times trying to distinguish "pedal" and "pedal cover" etc lol
Instagram: @gt86ws
Old 04-07-2020, 04:12 PM   #18262
norcalpb
norcalpb's Avatar
I should’ve tried tearing off the pedals before “screwing” as I should’ve said haha.
Did the pedal get damaged at all when you removed it? I noticed it was held on by these thick metal taps so I didn’t try to pry it out.
But when I part my car out (In like 10 years) Id like to trade gas pedals with someone without giving them the whole assembly.
Old 04-07-2020, 05:03 PM   #18263
JD001
JD001's Avatar
Drives: Subaru BRZ
Jeez, is this still going.. Come on change gear...
Old 04-07-2020, 07:24 PM   #18264
norcalpb
norcalpb's Avatar
Well quarantine is certainly getting to someone.
The Following User Says Thank You to norcalpb For This Useful Post:
JD001 (04-08-2020)
Old 04-07-2020, 08:50 PM   #18265
Wes
Here’s what happened to the original pedal cover
Instagram: @gt86ws
The Following 2 Users Say Thank You to StraightOuttaCanadaEh For This Useful Post:
JD001 (04-08-2020), norcalpb (04-07-2020)
Old 04-07-2020, 09:38 PM   #18266
soundman98
ProCrastinationConsultant
soundman98's Avatar
was there bubble gum inside of it?
The Following 2 Users Say Thank You to soundman98 For This Useful Post:
JD001 (04-08-2020), StraightOuttaCanadaEh (04-07-2020)
Old 04-09-2020, 03:33 PM   #18267
Deardorf
Deardorf's Avatar
Drives: 2016 BRZ Series Hyperblue
installed new trunk lid/wing/sequential tail lights
So-it turns out the donor car I've been getting upgrade parts for my 2016 Series Hyper Blue, was the Toyko Auto Salon Concept STI BRZ Subaru built for the show. It was parted out and shipped to US after the show w/only 400 miles on it.
I bought the 18" STI gloss black wheels, w/Michelin Pilot Sport 4 tires, and all 4 Brembo brakes, calipers/rotors/larger backing plates. Swaping out the rears were a pain, as the axle nut, hub/bearing assembly need to come off to remove the smalller OEM backing plate Parking brake assy, shoes, springs, etc need to be dis-assembled, then the Brembo parking brake parts have to be disassembled, then re-assembled on the car w/new larger rotors.
Not too hard but time due to the process.
Now all installed and the brakes feel super! My parts source let me know the trunk w/updated 2017-on wing was available. I love my hyper-blue but the original spoiler/wing bugs me. It's too thick and not as graceful as the updated one. So I've been looking for a 2017 or newer trunk to swap with and will have it painted hyper blue to match.
But after installing it-and the special silver Subaru used for the concept car looks more like raw Stainless Steel than silver paint and I like the two tone look-to my surprise. So for now, I'm leaving it silver-and may paint it later to match car. BTW-wheels, car really dirty-it's been raining a lot here and I'm lazy. Here's some pics.
PS-Also installed from F86 speed factory the sequential tail lights. Super easy install and I like them alot.
New Sequential turn signal tail lights installed below
Here's 2017 STI Concept car my parts came off of-at Toyko Auto Salon
Deardorf is offline   Reply With Quote
Old 04-09-2020, 07:43 PM   #18268
soundman98
soundman98's Avatar
how much did the brakes run you? i'm still debating just getting the gt kit through brembo...
Old 04-09-2020, 09:09 PM   #18269
TagMaster11
TagMaster11's Avatar
Drives: 2014 Subaru BRZ Aimgain GTF
I received my Aimgain GT F
TagMaster11 is offline   Reply With Quote
The Following 2 Users Say Thank You to TagMaster11 For This Useful Post:
Kiske (04-10-2020), soundman98 (04-09-2020)
Old 04-10-2020, 11:40 AM   #18270
Grady
Grady's Avatar
Did it come with a Lexus badge?
The Following User Says Thank You to Grady For This Useful Post:
JD001 (04-10-2020)
