Old 07-21-2012, 09:09 AM   #15
phenryiv1
Drives: 2011 WRX
Subscribing...
phenryiv1 is offline   Reply With Quote
Old 07-21-2012, 12:31 PM   #16
xjohnx
Grip>Slip
xjohnx's Avatar
Originally Posted by phenryiv1 View Post
Subscribing...
Old 07-21-2012, 02:22 PM   #17
phenryiv1
Drives: 2011 WRX
Originally Posted by xjohnx View Post
<--------- owned
Old 07-21-2012, 02:54 PM   #18
sickmint79
Drives: bmw
Originally Posted by civicdrivr View Post
I run a Blackvue DR400G in my other car and love it. Parking mode is awesome and the picture quality, even at night, is great.
i ordered one of these a few days ago.
sickmint79 is offline   Reply With Quote
Old 07-21-2012, 04:09 PM   #19
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
The one issue with the Blackvue is the firmware. You cant mix them, so a Korean camera needs to use the Korean firmware. Which means the voice prompts arent in English nor is the software. A member on another forum I frequent posted this:
For those with the blackvue I found this to work on the Korean units. This process will change the software to English & the voice prompts to English as well.
Download the English firmware from pitasoft. 1.40E
Then follow these instructions.....
1. Connect MicroSD card to PC,then format it quickly. Use the SDFormatter as recommended.
2. Choose the english firmware which you want upgrade,double click install to MicroSD card.(During if you want install the english play video software to PC, just do it or no, up to you)
3. After finished install new firmware to MicroSD card, DON NOT take out the SD card from PC, go to MicroSD card, open "\BlackVue\Config" folder, open the "Version" file with Notepad. Change 2 line "language = English" to "language = Korea",then saved the file. It show like below:
[firmware]
version = 1.40
model = 400
language = English -----------------> Korea
[software]
version = 1.40
model = 400
[config]
version = 1.000
model = 400
4. Now move MicroSD card out of PC, insert into BlackVue and power on, first you will hear english, after upgrade done, it restart again,the blackvue start to record video, but you will hear korean again, don't worry, shut down the power, move out the MicroSD, connect ot PC,open MicroSD card "\BlackVue\Config" folder,open the "Version" file with Notepad. Change 2 line "language = Korea" to "language = English",then saved the file. It show like below:
[firmware]
version = 1.40
model = 400
language = Korea -----------------> language = English
[software]
version = 1.40
model = 400
[config]
version = 1.000
model = 400
5. If you want to set up the option of blackvue, you can use MicroSD card "\BlackVue\Application\BlackVue.exe" software or the software in PC to do it and save.
6. Finally move out the MicroSD card out of PC, insert into BlackVue and power on, from now you will hear English again.
I havent tested if that works yet though, but plan on doing so shortly.
Parting out HERE
civicdrivr is offline   Reply With Quote
Old 07-22-2012, 04:21 PM   #20
hansthegerman
Drives: Scion FRS
Just ordered the Chinese one I posted a link to. I'll let you guys know what I think after I get it an test it out. My FRS is finally here, Pickin it up on Wednesday
hansthegerman is offline   Reply With Quote
Old 07-22-2012, 05:19 PM   #21
CSSM
Still Dreamin'
CSSM's Avatar
Drives: 2001 Chevrolet Tahoe
Originally Posted by Fenrir View Post
808 keychain camera is your best bet. I use one in my car, works very well. They're like, $3-4 a piece.
Just bought one, thanks
CSSM is offline   Reply With Quote
Old 07-24-2012, 02:17 PM   #22
otoz
Drives: 2013 Whiteout FR-S
+1 on the Blackvue DR400G, mine is still working pretty well. I've found one thing you should be careful of is turning it on and off too quickly, if it doesn't have a chance to turn on completely before you pull the power again it corrupts the sd card half the time.
The most exhaustive info i've found on it is here:
http://forums.redflagdeals.com/merge...-18-a-1147913/
otoz is offline   Reply With Quote
The Following User Says Thank You to otoz For This Useful Post:
MmmHamSandwich (07-25-2012)
Old 07-25-2012, 02:51 PM   #23
Jlturner
Jlturner's Avatar
Drives: Scion fr-s
Can you share a link to this? For some reason I can't seem to find it?
Jlturner is offline   Reply With Quote
Old 07-25-2012, 03:15 PM   #24
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
Drives: Lexus IS-F Series 2
This what I use, it's awesome and expensive
http://gopro.com/cameras/hd-hero2-motorsports-edition/
2URGSE
JPxM0Dz is offline   Reply With Quote
Old 07-25-2012, 06:31 PM   #25
CSSM
Still Dreamin'
CSSM's Avatar
http://www.ebay.com/itm/150808575232...84.m1497.l2649
Cheapest one I could find
Old 07-25-2012, 06:52 PM   #26
Jlturner
Jlturner's Avatar
Drives: Scion fr-s
Thanks! I might buy one to try out, for the price you can't go wrong.
Old 07-25-2012, 09:08 PM   #27
CSSM
Still Dreamin'
CSSM's Avatar
Exactly, it's a steal! And if it sucks, then it isn't stealing from me
Old 07-25-2012, 10:39 PM   #28
MmmHamSandwich
You know you want it.
MmmHamSandwich's Avatar
Drives: '13 FR-S
If I got a dash cam I'd probably spend the extra coin and get something purpose built and fairly autonomous like this. Does this one start and stop recording automatically when power is applied and removed or do you have to start it up and shut it down each time?
MmmHamSandwich is offline   Reply With Quote
Carbon dash trim Surok Cosmetic Modification (Interior/Exterior/Lighting) 26 01-18-2013 03:59 PM
BRZ Dash Painted xcelir8brz Cosmetic Modification (Interior/Exterior/Lighting) 27 07-18-2012 09:11 PM
Trade my black dash plastic for your silver dash plastic thread. F3dzo Southeast 0 07-17-2012 10:06 PM
Dash Mounts for gadgets smbrm Cosmetic Modification (Interior/Exterior/Lighting) 0 06-28-2012 07:07 PM
What to use on the dash and other cabin plastics russv Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 8 06-16-2012 08:16 PM
