Old 02-08-2018, 03:21 PM   #1
idkwhatimdoing
idkwhatimdoing's Avatar
Drives: 2015 Scion FR-S 1968 Camaro BB402
Ohlins Road and Track Bearings/Spacers?
Hey guys,
I recently bought a set of used Ohlins Road and Track coils w/o camber plates. I want to reuse my stock top hats for both front and rear, but this requires the use of certain spacers.
I have contacted Ohlins numerous times to try and order these spacers, and so far my efforts have been futile.
Does anyone know where I can get these spacers/ what the dimensions are (OD, ID and length) ? Will attach pics and highlight.
Thanks!
idkwhatimdoing is offline   Reply With Quote
Old 02-08-2018, 03:36 PM   #2
idkwhatimdoing
Also, I am running Raceseng 2” rear shock tops and I’m not sure where the 3 spacers and bushings fit in order on the shock shaft, could anyone give me ideas? Thank you
Old 02-08-2018, 03:41 PM   #3
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
ineedyourdiddly
Old 02-08-2018, 03:45 PM   #4
idkwhatimdoing
Unfortunately, I tried that. The shock shaft started pushing out of the top hat while driving. Not good. Also there are 2 more spacer-type things that came with it, one a round spacer and the other a sort of large diameter platform, as well as the flanged bushing shown in the picture.
Old 02-08-2018, 03:47 PM   #5
idkwhatimdoing
@mav1178 I know your thread, I read it all the way through. You still on the forums?
Old 03-01-2018, 08:35 AM   #6
teppei
Drives: 86 GTS
mate, try contact Ohlins Sweden directly for replacement. you want pretty snug fit with those spacers or the shocks could make knocking noise.
Good luck
teppei is offline   Reply With Quote
Old 03-01-2018, 11:17 AM   #7
idkwhatimdoing
Good luck
Yeah I just decided to buy CasCam front mounts and I replaced the rear spherical bearings. No clunkboth old spherical bearings in the shock tops were able to be rotated 360° in any direction, and the one that had the clunking issue the ball could move up and down inside the race.
Old 04-05-2020, 11:45 PM   #8
Cjymiller
Original 2013 Owner
Cjymiller's Avatar
Drives: 13 BRZ, Galaxy Blue Silica
Digging this thread up and probably going to PM you too. I'm having this issue with my rear ohlins shock mounts and am having the hardest time to find spherical bearing replacements. Where did you source your replacements from?
Perrin Headerback, OFH, OFT, Ohlins R&T MI20, 17x9 Weds TC105N, Hankook RS4 (235/40), TOM's JDM Tails, PCV AOS, Perrin Crank Pulley, Perrin Rear Trans. Mount, Whiteline Shift Bushing, SS brake Lines, Hawk DTC60, Bayson R Lip Kit, LED Lighting , Smoked JDM Sidemarkers, Rear Fog Enable, Carsmo Armrest, Grimmspeed Plate Relocater
φφκα
Cjymiller is offline   Reply With Quote
Old 04-06-2020, 02:53 PM   #9
norcalpb
norcalpb's Avatar
Not who you’re asking, but I use Chris Hagen @ Inertia Laboratory to replace my bearings. He’ll know all about the bearings Ohlins use.
chris@inertialaboratory.com
The Following User Says Thank You to norcalpb For This Useful Post:
Cjymiller (04-06-2020)
Old 04-16-2020, 11:46 PM   #10
rixter145
Sleep Chomper
rixter145's Avatar
The endlink spacer! Doh!
rixter145 is offline   Reply With Quote
Ohlins MP20 Cspanner rixter145 Northwest 0 01-15-2018 10:58 PM
Ohlins R&T MP20 $1600 airindia33 Brakes, Suspension, Chassis 10 01-06-2018 09:33 AM
Ohlins MP20 knocking noise teppei Suspension | Chassis | Brakes -- Sponsored by 949 Racing 17 10-13-2017 05:41 AM
Ohlins (SUS MP20) Stage SEITEN Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 07-24-2017 06:01 AM
My ohlins warranty problem!!!!!!see what Ohlins China replies!!!!!!!!!!!!!!!!!!!!!!!! kkman User/Vendor/Sponsor Reviews, Feedback, Comments 18 03-31-2016 11:59 AM
